Rear triangle keeps getting more off center every time I ride.
Old 09-01-22, 01:54 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
Liked 346 Times in 204 Posts
I posted this to r/bikewrench where the neckbeard council told me that I was basically being stupid and that I didn't know what I was talking about and that it was the wheel that was the problem and that I am just stupid for believing that the frame is bending.
I would really like to keep riding this bike and I want to see if the people here have any helpful advice on how to fix this. I'm pretty sure that it can be bent back due to it being a steel frame but I am not an expert on materials. I have seen the local shop bend back steel frames with a large piece of wood and it was successful. Would that work in this situation?
grant40 is offline
Old 09-01-22, 01:58 PM
smd4
Quoted: 3482 Post(s)
Liked 2,902 Times in 1,763 Posts
Did you determine that the frame was bent using any method other than the wheel itself?
smd4 is online now
Old 09-01-22, 02:00 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
I have not used a frame checker, but with the event I have gathered, I am sure it is bent.
grant40 is offline
Old 09-01-22, 02:03 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
Hard to believe, but if it is actually bending while riding, why do you think it would stop?
Bending it back on a regular basis is just going to result in metal fatigue/breakage.
It's your skull.
Bill Kapaun is offline
Likes For Bill Kapaun:
smd4
You don't need a tool to get a rough measurement:
smd4 is online now
Likes For smd4:
Old 09-01-22, 02:06 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
It's your skull.
I assume that if it is bent straight once, won't bent back again due to equal pressure. I am pretty sure that the frame was bent from factory as it is a pretty cheap one with bad quality control. I got the whole boke used for $75 at a co op.
grant40 is offline
Old 09-01-22, 02:09 PM
Bill Kapaun
ASSume all you want.
I don't care.
As I said, it's your skull.
I'm done.
Old 09-01-22, 02:10 PM
smd4
How is the pressure going to be equal when the torque from the chain is on only one side?
smd4 is online now
Old 09-01-22, 02:25 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
The pressure from sitting on the frame.
grant40 is offline
Old 09-01-22, 02:47 PM
wheelreason
Quoted: 493 Post(s)
Liked 617 Times in 364 Posts
So it's always been bent, AND it bends when you ride it, and whatever you've checked makes you sure it is bent? I'm thinking it's mostly the wheel, and the dropouts may be out of alignment. Take the wheel off and mount it backwards, or take a few measurements, or run a string on the triangle, then you'll know. If it's steel, getting it close to straight is easy, but if it has been indeed bending while riding, it is toast other than for brazing practice.
wheelreason is offline
Likes For wheelreason:
Old 09-01-22, 03:07 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
I did the string test and I have flipped the wheel around on multiple occasions to check and both the frame and the wheel are straight. I guess because it is a cheap frame it is kind of deformed due to bad QC. Probably it bending even more is just my imagination as I've never measured it.
I measure the distance from the string to the seat tube with a tape measure and it was the exact same on both sides.
grant40 is offline
Old 09-01-22, 03:14 PM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 694 Times in 433 Posts
Have you measured the axle distance before and after riding in those horizontal dropouts? The axle slipping in a dropout seems more likely than the frame bending.
freeranger is offline
Likes For freeranger:
Old 09-01-22, 03:33 PM
pdlamb
Quoted: 2588 Post(s)
Liked 1,919 Times in 1,203 Posts
Yup.
Either crank down on the wheel nuts or get a new frame. If the frame is bending (although wheel slippage seems more likely), you'll just fatigue and weaken it bending it back until the whole thing snaps.
pdlamb is offline
Old 09-01-22, 03:38 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
The frame isn't bent.
cxwrench is offline
Likes For cxwrench:
Old 09-01-22, 03:55 PM
Desert Ryder
Henderson, NV
Desert Ryder's Avatar
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 313 Post(s)
Liked 584 Times in 283 Posts
Add a pair of cheap rear wheel/chain tensioner adjusters. Then see if it cures the rear axle slippage.
Desert Ryder is online now
Old 09-01-22, 04:10 PM
Koyote
Quoted: 6927 Post(s)
Liked 10,930 Times in 4,667 Posts
The "neck beards" are correct: the frame is not bent. Most likely, your wheel needs to be re-dished.
Koyote is online now
Likes For Koyote:
Old 09-01-22, 04:17 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
Originally Posted by pdlamb
Yup.
No wheel slippage.
grant40 is offline
Old 09-01-22, 04:18 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
There is no wheel slippage.
grant40 is offline
Old 09-01-22, 04:36 PM
himespau
himespau's Avatar
Quoted: 4217 Post(s)
Liked 2,940 Times in 1,800 Posts
I wouldn't be so sure about that. One side slipping more than the other would lead to exactly what your early pictures show (also see the missing paint in the dropout).
himespau is online now
Old 09-01-22, 05:12 PM
smd4
Wheel slippage would tend to force the wheel to the left inside the frame. In the initial photos the wheel looks like it’s canted to the right.
smd4 is online now
Likes For smd4:
Old 09-01-22, 05:23 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4334 Post(s)
Liked 2,977 Times in 1,614 Posts
Exception if it's on the fixed cog (likely, since there's no brake) and OP likes to skid... wheel would slip the other way.. like the photo.
DiabloScott is offline
Likes For DiabloScott:
Old 09-01-22, 07:12 PM
CliffordK
CliffordK's Avatar
Quoted: 18347 Post(s)
Liked 4,497 Times in 3,344 Posts
Are you sure? I don't ride a fixie.
But logically, pedaling forward, one gets tension to the top of the chain and loose on the bottom, but pulls the right side of the hub forward (and throws the wheel to the left).
Braking, one gets tension to the bottom of the chain and loose on the top. that should still pull the right side of the hub forward (and still throws the forward edge of the wheel to the left).
Now, skidding might pull the left side of the hub back, but the forward edge of the wheel still goes left.
Nonetheless, chainstay rub would be worse than steatstay rub in both cases. The OP seems to indicate seatstay rub.
CliffordK is offline
Old 09-01-22, 07:21 PM
CliffordK
CliffordK's Avatar
Ok, a couple of things... when you mount the wheel, are you doing it with both wheels on the ground? The wheel should naturally generally center between the seat stays with the upper dropouts resting on the axle.
My guess is the OP is actually trying to force the wheel to lean when mounting the wheel. Then when riding, it just settles back down.
A couple of things to look at.
  • Are the dropouts perfectly level? That may be hard to measure. If not level, it would be a construction problem.
  • Is the wheel properly dished (locknuts centered on the hub). That might not be as easy to measure on a bike with horizontal dropouts, but try putting the wheel in backwards, and sit on the ground. Does the wheel still lean to the right, or does it lean towards the left?
Actually, the flipping the wheel experiment may help determine both uneven dropouts, or dishing.
There is a dishing tool that you can use, but it may not be practical if you aren't doing quite a bit of bike work and wheel work.
A good bike shop should have it though, and it would take less than a minute to check the wheel.
Likes For CliffordK:
Old 09-01-22, 08:14 PM
Koyote
This. Flip the wheel. If it's now closer to the other side, 90% probability the wheel needs to be re-dished. Until OP takes five mins to do this, there's little point in further speculation.
Likes For Koyote:
Old 09-01-22, 09:45 PM
grant40
grant40's Avatar
Quoted: 259 Post(s)
Wheel is not slipping.
grant40 is offline
