Drilling a tire.
Drilling a tire.
Old 12-31-22, 12:45 PM
car5car
car5car's Avatar
Bikes: Dead Mongoose XR100, Roadmaster
Quoted: 108 Post(s)
Liked 19 Times in 18 Posts
Drilling a tire.
Solid tires feel like 110 PSI, it is too hard, I am going to drill it after installation
car5car is offline
Old 12-31-22, 12:50 PM
Kontact
Kontact's Avatar
Quoted: 2968 Post(s)
Liked 482 Times in 312 Posts
Might make your worn tire disintegrate in a turn, or make the tire vibrate as it rolls over the stiff spots between the holes.
Sounds like a terrible idea, so I hope you do it and report back.
Kontact is offline
Likes For Kontact:
Old 12-31-22, 01:22 PM
Steve B.
Quoted: 2749 Post(s)
Liked 1,480 Times in 860 Posts
Maybe solid tires just suck ?. Best option is new tubeless wheels and tires, you could likely run 70-80 psi and be super comfortable.
If not just get some tubed clinchers in a 28-32 and run less air.
Steve B. is offline
Likes For Steve B.:
Old 12-31-22, 01:30 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 3844 Post(s)
Liked 2,321 Times in 1,256 Posts
For best responses, please be specific -
How many holes?
What size drill bit?
All the way through - or just drillium dents?
Are you going to do the contact surface or just the sidewalls?
What about from underneath? You could kind of hollow out the inside for some kind of air chamber in there!
Have you considered HTFU?
DiabloScott is offline
Likes For DiabloScott:
Old 12-31-22, 01:52 PM
phughes
phughes's Avatar
Quoted: 871 Post(s)
Liked 1,016 Times in 581 Posts
phughes is offline
Old 12-31-22, 01:54 PM
Kontact
Kontact's Avatar
How many holes?
Do you have some data that will determine which size and number of holes are acceptable/unacceptable?
Kontact is offline
Old 12-31-22, 01:56 PM
alcjphil
alcjphil's Avatar
Quoted: 1595 Post(s)
Liked 1,332 Times in 780 Posts
I believe that the OP is talking about drilling the rim so as to accept a schrader valve
alcjphil is online now
Old 12-31-22, 02:04 PM
smd4
Quoted: 1805 Post(s)
Liked 1,356 Times in 854 Posts
His attached image clearly shows that he intends to drill into the sidewalls.
smd4 is offline
Likes For smd4:
Old 12-31-22, 02:05 PM
car5car
car5car's Avatar
Quoted: 108 Post(s)
How many holes?
I ordered solid tire from ebay and wanted to cancel it next day, but it was shipped already. My rear tire is cracked. I have youtube channel, so I'll install it, ride it and, if it is hard, like people say, I'll drill it and post video on youtube. I don't know drill bit size, which I'll use, probably I should start with small, maybe 1/8". Let us say, I invested $19 in youtube video.
https://www.ebay.com/itm/125643061126?var=426672946793
car5car is offline
Old 12-31-22, 02:19 PM
alcjphil
alcjphil's Avatar
The tire in the picture is clearly a pneumatic tire. Would like to be there during the drilling of the first hole
Likes For alcjphil:
Old 12-31-22, 02:21 PM
veganbikes
Clark W. Griswold
Quoted: 3550 Post(s)
Liked 2,872 Times in 1,923 Posts
You can probably re-sell it on ebay pretty easily just keep it in the package and re-sell and probably make your money back. Drilling it out is not a great idea if they didn't drill it out there is probably a reason. Nobody will want a used solid tire but someone would want a brand new one because they keep making them so someone is buying them.
Solid tires are great for extremely infrequent riding for very short distances on really good pavement like say at the beach on a beach bike at a house I am at for like a week or less. Like I have said they are probably a huge massive improvement over iron tires but you cannot beat pneumatic at least not with todays technology.
veganbikes is offline
Old 12-31-22, 02:24 PM
DiabloScott
It's MY mountain
No, but I have an approach ("you" means "OP" here, not you):
Start with four equi-distant holes, 1/16 bit. Ride and evaluate.
If you want softer and lighter, add more holes of the same size and same pattern. Ride and re-evaluate.
When you get up to the same number of holes as you have spokes, start reaming out the 1/16 holes with 1/8" holes.
Also - keep the crumbs from the drilling because if you decide you did too much you can superglue the crumbs back in place.
You should be aware though, that holey tires aren't very aerodynamic - way too much turbulence and you might not like the way your bike handles.
Old 12-31-22, 03:02 PM
Iride01
more daylight today!
Iride01's Avatar
Quoted: 5127 Post(s)
Liked 3,613 Times in 2,509 Posts
Solid tires seem like a lot of trouble in the few threads I've just recently read about them.
Iride01 is offline
Likes For Iride01:
Old 12-31-22, 03:15 PM
car5car
car5car's Avatar
Quoted: 108 Post(s)
Are you sure? Really? Thanks!
Read previous post!
car5car is offline
Likes For car5car:
Old 12-31-22, 03:17 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 883 Post(s)
Liked 502 Times in 292 Posts
And if you drill different size holes front and rear they will whistle at two different pitches.
Dan Burkhart is offline
Likes For Dan Burkhart:
Old 12-31-22, 03:20 PM
Kontact
Kontact's Avatar
Sure, that's a methodology. But that suggests that you know drilling holes in the OP's tires isn't going to lead to a serious accident.
Kontact is offline
Old 12-31-22, 03:24 PM
smd4
He didn’t say he was going to drill THAT tire. He said it wasn’t even mounted yet.
smd4 is offline
Likes For smd4:
Old 12-31-22, 03:47 PM
DiabloScott
It's MY mountain
Well no, it suggests that since it's obviously a potential problem, best to start with the minimum and go from there. And as a corollary, I think this whole thread is a joke anyway.
Now we're talking! I suggest aiming for a perfect 5th to avoid a disharmonious cacophony that might frighten children... unnecessarily.
Old 12-31-22, 04:07 PM
Kontact
Kontact's Avatar
Maybe giving dangerous advice isn't a great joke.
Kontact is offline
Old 12-31-22, 04:47 PM
phughes
phughes's Avatar
Quoted: 871 Post(s)
My 2 cents is this. First off, drilling fairly small holes most likely will not have much of an effect. If you drill large enough holes to affect the ride, the ride will most likely then be rougher, since part of the tire will be hard, until you get to a section with a hole, then it will be softer. The net effect will be, bump, bump, bump, bump. I say ride it the way it comes, and use it as intended.
phughes is offline
Likes For phughes:
Old 12-31-22, 04:50 PM
squirtdad
squirtdad's Avatar
Quoted: 1949 Post(s)
Liked 1,907 Times in 1,108 Posts
There is a reason people don't use solid tires, they ride hard, don't corner and in general are not suitable for any thing than a toddler tri-cycle or red wagon.
I will be direct: IMHO this is a dumb idea. any amount of drilling that will make a difference in ride will involve large holes into what is clearly cheap material, risking failure (23mm tires probably would need almost probably 15 mm or large holes all the way around the tire to make any difference (base on recent flat proof tire concepts in news)
doing in and promoting for sake of youtube channel just adds to the dumbness.
P.S 110 psi can be a super smooth ride, depending on the bike, the person, the rim and the buil
(looking for Torpado Super light frame/fork or whole biked 57,58)
squirtdad is offline
Likes For squirtdad:
Old 12-31-22, 04:57 PM
sweeks
sweeks's Avatar
Quoted: 886 Post(s)
Liked 419 Times in 309 Posts
Assuming the solid tire is to prevent flats, maybe something intermediate like THIS might be suitable.
sweeks is offline
Old 12-31-22, 04:58 PM
HillRider
Quoted: 1973 Post(s)
Liked 984 Times in 679 Posts
Any chance this entire thread was started as a joke?
HillRider is offline
Likes For HillRider:
Old 12-31-22, 07:30 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3246 Post(s)
Liked 2,649 Times in 1,540 Posts
Not to mention, he explicitly states it is a solid tire:
JohnDThompson is offline
Old 12-31-22, 07:47 PM
SoCaled
Bikes: 1988 "Pinalized Rockma", 1983 Trek 720, 1984 Trek 510, Moulton custom touring, Schwinn Circuit, 1960's Paragon, 1980's Peugeot - City, US & Canyon Express & (6), 87 Sirrus
Quoted: 431 Post(s)
Liked 1,329 Times in 745 Posts
Based on your handle, I would have guessed you would go with the diminished 5th? but that would scare the children . . .
SoCaled is offline
Likes For SoCaled:
