Aluminum tubing thickness?
ok, so i noticed there are ZERO people viewing the framebuilders forum, so for the cross-post...
how thick is the tubing of an aluminum frame, specifically the chainstay tube? i scraped it hard on a curb, and it scratched a pretty thick chunk out of the tube. no dent, but a deep gash. should i be worried? it's a Specialized road frame built in 2004, in case that info helps (Specialized Langster to be exact). i'm not sure exactly how deep, but i'll try to measure it when i get a chance.
Quoted: 2026 Post(s)
Liked 1,095 Times
There is no specific thickness as frame builders use thick wall tubes of a weaker low-cost alloy for low line frames and thin but stronger alloy tubes on more expensive frames.
Chainstays have heavier walls than the main tubes but will still vary in diameter and wall thickness based on the frames cost and intended use.
Likes For HillRider:
Quoted: 476 Post(s)
Liked 427 Times
I'd guess in the region of 1.5 mm depending on what grade alloy Specialized chose to use, they seem to be deliberately vague about that. Tube thickness is chosen for strength in the heat affected zone, so away from that it can be significantly thicker than it needs to be (higher spec tubes may be tapered or butted to compensate for that) so the middle of the stay may be thicker than it needs to be. The direction of the defect is also relevant - I'd expect a longitudinal scratch to be potentially less of a problem than one that creates a lateral stress riser. I'd just ride it and check frequently for cracks - take the wheel out and squeeze the dropouts together while looking for movement and listening for creaks.
Likes For grumpus:
Quoted: 4340 Post(s)
Liked 1,528 Times
So you can either ride your perfectly functioning frame, or preemptively throw it in the trash. But there's no good reason to do the latter, and there's no repair that is going to help matters.
Likes For Kontact:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Not sure as it can vary but more to the point are you the original owner and do you happen to have your receipt or can reach out to the shop and see if they have it you can file a claim. If you go to your local Specialized dealer they can help filing a crash replacement which can get you a discount on a new frame unfortunately they have stopped making the Langster a while back (my warranty replacement after a bottom bracket crack was one of the last remaining ones and I got lucky as it was the Rio edition) however you could put it towards something else in the line up. They can also look at the frame and help determine the viability of the frame in their eyes.
Like others have said it could last and be fine or it could fail. It is up to you if you want to take that risk or not, nobody else could make that decision for you.
Last edited by veganbikes; 01-11-23 at 12:26 PM. Reason: important note about zombie thread.
Liked 1,528 Times
Every time I went through this with a customer they usually just took the discount on a new disc bike and maybe replaced the old frame because they had all those rim brake parts. And that was with actually trashed frames - not little scrapes that might amount to nothing.
Keep in mind that most manufacturers are perfectly happy drilling holes in their aluminum tubes for cable stop rivets and bottle cage rivnuts. You have to remove an lot of material before a homogenous metal like aluminum becomes so weak that it begins flexing and stress hardening.
Likes For Kontact:
Clark W. Griswold
Liked 3,958 Times
Crash replacement discounts are nice, but since it's a 2004, Specialized is not going to have a rim brake frame to offer him. Which means that he'll need to buy - at a minimum - new wheels and calipers just to get a crummy mechanical disc set up.
Quoted: 4195 Post(s)
Liked 3,837 Times
AndrewRStewart
AndrewRStewart
Liked 1,528 Times
And, being a chainstay it is much less worrisome than a downtube/headtube junction. 4 tubes hold the back end together.
Quoted: 4792 Post(s)
Liked 3,918 Times
On steel, I've broken the right chainstay completely just behind the bridge and on a bike I bought used and abused, discovered both chainstays were about to break in the same place. First one I learned of while riding. Felt a little funky so i looked down and watched the chainstay waving around. (Yours is much stiffer. It won't wave.) Second I'd been riding a few weeks. Did notice that it was awfully easy to align the car displaced dropouts and rear end but missed the cracks. (I think that bike tried to stop an SUV.)
I'd just ride your bike and look at it periodically.
Likes For 79pmooney:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
How thick the tubing is will depend on which frame member it is, and what price point the bike inhabits.
The chain stays and seat stays will always be thicker walled than the main triangle, and a less expensive, recreational bike, like the Langster, will have thicker walled tubing than a high -performance bike like the Allez Sprint or a CAAD-13
either way, I echo the sentiment that bicycles are far more robust than they’re often given credit for around here
Quoted: 6944 Post(s)
Liked 10,944 Times
The original post is 15 years old. I'm guessing that, by now, the frame has failed catastrophically and the poster is dead.
Likes For Koyote:
Likes For grumpus:
Clark W. Griswold
Liked 3,958 Times
