How to transfer old brake hoods without ripping the bejeebers out of them?
Bikes: '62 Schwinn Continental, '69 Schwinn Paramount, '74 Raleigh International, '75 Peugeot PX-10LE, '76 MKM Dominator, '80 Holdsworth Mistral, '81 Woodrup Giro Touring, '87 Bianchi Brava, '89 Schwinn (Waterford) Paramount, '94 Trek 1400
Quoted: 5 Post(s)
Liked 17 Times
I'm restoring a Raleigh International, and the Carlton hoods were long gone. I actually have a pair of white Carlton hoods in decent shape on regular Weinmann levers (not the fancy drilled ones the RI came with). Is there a way to get the Carltons off the old levers and onto the RI levers without tearing them? I'm concerned that 50 year old rubber just isn't that flexible or forgiving. Gentle heat from a heat gun, maybe?
The only other solution I came up with was to cut the Carltons on the underside and then glue them onto the RI levers, but I'd rather transfer them whole if that's feasible.
Thanks in advance for any insight or advice.
Z
69 Paramount
75 Peugeot PX-10LE
76 MKM Dominator
81 Woodrup
89 Waterford Paramount
and other bikes
Z
69 Paramount
75 Peugeot PX-10LE
76 MKM Dominator
81 Woodrup
and other bikes
Quoted: 1106 Post(s)
Liked 1,327 Times
These are those white sort-of hard rubber hoods, correct?
Hot - HOT water. So hot you need gloves to hold the hoods after they've been in it 5 minutes. Dump the whole lever in to get them off, then the hoods alone to get them on the other levers.
And a spray lube with one of those little red straws to get it under the hood (works great on those black poly handlebar sleeves as well).
Quoted: 3810 Post(s)
Liked 6,690 Times
I use hairspray for such applications.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,473 Times
Good advice above. A couple drops of dish soap in the hot water will help lubricate.
Remove and install from the end of the lever housing that contacts the handlebar, not from the lever end, which requires excessive stretching and bending.
There was recently a thread over on CR in which it was suggested to use rubbing alcohol as a lubricant. I've not tried it, but a couple folks swore by it.
Brent
Brent
Quoted: 5 Post(s)
Liked 17 Times
Worked perfectly!
^^^^ This ^^^^ worked a treat. I used the hot water out of my hot water dispenser (about 190 degrees Fahrenheit, not the regular faucet hot water) and after a few minutes picked them up using Mechanic's gloves and popped those suckers right off. Very little effort required; no damage done. Will clean them up while they're off the bike, then install using same technique. Thank you for the advice!
Likes For Zumkopf:
