Cycling and hand signals
#76
Quoted: 6193 Post(s)
Liked 4,808 Times
I don’t think so. That does not say what motorcyclists must do, but rather is an advisory to drivers for what to look for in hand signals from a “motorcyclist, scooter operator, or bicyclist.”
As stated by the MI Secretary of State which oversees licensing and endorsements, right hand up for right turns is the “proper” signal for motorcyclists:
https://www.michigan.gov/sos/0,4670,...7468--,00.html
I’ve not had a motorcycle endorsement since 1996, FWIW.
Michigan Legislature - Section 257.648
Interesting that there isn't an exception for those in motor vehicles being driven from the right side. I doubt my state has an exception either. But it's time for lunch.
#77
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Likes For livedarklions:
#78
Tragically Ignorant
Liked 9,098 Times
BTW, one of the times I use the 'right arm pointing' to signal a right turn is when I have to cross a freeway off-ramp, when traffic coming off is crawling. Pretty sure that the drivers I'm signaling that I want to pass in front of them wouldn't have a clue what I wanted if I raised my left arm.
This is pretty close to being the only time I bother to signal a right hand turn.
#79
Quoted: 5224 Post(s)
Liked 3,581 Times
might be related to what controls are on which bars. I don't ride but do they have rear brake & clutch on right bar?
#80
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Throttle and front brake IIRC, both of which probably come in handy when setting up for a right turn.
Likes For genejockey:
#81
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Nope. Rear brake is usually a pedal on the right side. Clutch is on the left. Throttle and front brake are on the right. Kind of important not to let go of the right because it keeps the go juice flowing and the front brake accessible if you need to stop the go juice.
Stuart Black
Stuart Black
Likes For cyccommute:
#82
Tragically Ignorant
Liked 9,098 Times
So, let's get back to my question. Does anybody on this thread actually use turn signals on a MUP? Right turn signals in particular?
#83
Habitual User
Quoted: 4944 Post(s)
Liked 8,085 Times
I have before. I pointed right with my right hand/arm because it's a clear way to let other users know what I will be doing.
Likes For Eric F:
#84
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Geez ....people will argue all day on the smallest of things....Here is my contribution.
I have no idea what Indiana law is for bicyclists. I use my left hand as that is what I learned and still use on my motorcycle when I feel a hand signal is warranted. Yes my motorcycle has turn signals but sometimes it is about being as visible as possible.
I feel that on a bicycle either method is acceptable but those who think that a driver will "get" that a right arm pointing is any clearer than a left arm bent at a right angle is deluding themselves. Most driver's probably have little to no idea what any hand signal means in the first place. My belief is that most motorists have no idea what you are doing if they even see you in the first place.
I still signal because I am a dignified cycling gent and believe that it is proper courtesy : )
Likes For Rdmonster69:
#85
Quoted: 20810 Post(s)
Liked 9,456 Times
I tend to avoid MUPs, but sometimes they're a lesser/necessary evil. In those instances, yes, I'll signal if there's someone nearby that would possibly be affected by my change in speed and/or direction.
#86
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
#87
Liked 11,896 Times
I tend to signal all turns regardless, so I don't have to remember to do it under certain circumstances. I don't signal stops unless it's the situation I described above, where not doing so might lead to being run over by cyclists unaware of the habits of San Mateo County deputies.
#88
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
^^ I love MUP and it takes up the most of my riding. I can easily go 60 miles and rarely have to ride on regular roads. I can't recall ever using a hand signal on a MUP as I have never really turn off the path. When I am on the few surface streets I need to traverse to get back to campus I will use hand signals. Thankfully I only have a left turn to make thus avoiding the dreaded left arm bent/right arm controversy : )
#89
Liked 9,456 Times
#90
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Sounds like you ride in some unique settings not common for most people, so your habits and rules won't work outside of your parameters. Any pack that rides 2 or more wide may encounter a situation where they have to split to go around a hazard. It's totally cool that you only ride single file and never pass each other, and that you expect all the drivers around you to be educated, but I don't see that working where I ride.
It's like riding a bicycle
#92
Liked 11,896 Times
#93
Thread Killer
Liked 1,704 Times
Likes For chaadster:
#94
Liked 9,456 Times
#95
Liked 9,456 Times
#96
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
if we’re two abreast, the one on the left calls out on their right…which is to the left of the riders at the fog line. We ride the same way in IN, OH, and KY aswe do at home and it mostly works fine. If it’s something real serious on the left, it gets called with the right hand, but that’s an exceptional circumstance, because the baseline flow is to the right.
#97
Thread Killer
Liked 1,704 Times
#98
Liked 4,218 Times
It depends. I don’t signal all the way through the turn. I will usually give a signal before a turn for a few seconds, then I get my hands back on the bars so that I have control of the bike in the turn. There’s no hard and fast rule and even if they were, I’d ignore the rules if my safety is going to be compromised.
Stuart Black
Stuart Black
#99
Liked 4,218 Times
Stuart Black
Stuart Black
#100
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Our pedestrians are oblivious and would be as bad as drives. One section I ride on is crushed packed limestone ..... lightly trafficked. Our major rail trail has some little villages on it that have lots of foot traffic to be aware of. Half the time a bike bell attracts them into your path. I just use abundant caution. Little kids and inattentive pet owners worry me the most. I do ride the rural roads around where I live but the state of todays distracted drivers as well as country bumpkins who think messing with cyclists is good sport deters me somewhat.
