Branding Shimano 600ax aero bikes.
Old 01-14-19, 03:03 AM
Hubertus
Quoted: 8 Post(s)
Liked 9 Times in 4 Posts
600 ax groepset
Aero cover!
Shimano 600ax and Tange aero frame
I own a nameless early aero bike with a special Tange frame and a Shimano 600 ax group on it. I have seen these being branded as: Jan Janssen, Norta, Diamant and Plum.
No doubt there are many more.
Show me yours ! Do they qualify for Eroica events as the year is 1982?
Hubertus is offline
Likes For Hubertus:
Old 01-14-19, 03:39 AM
CliffordK
CliffordK's Avatar
Quoted: 14432 Post(s)
Liked 2,416 Times in 1,802 Posts
Hmmm, Here is @Hubertus' Album.
https://www.bikeforums.net/g/user/493655
https://www.bikeforums.net/g/album/12422088
But, alas, no Shimano 600AX bike.
Here is my thread about the SR Semi Pro.
https://www.bikeforums.net/classic-v...-aero-way.html
I haven't had a chance to do much with the bike yet. Another project for "soon".
I have acquired some replacement brake hoods, and do plan to try to clone them sometime.
CliffordK is offline
Old 01-14-19, 11:29 AM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1829 Post(s)
Liked 973 Times in 655 Posts
A recent gift to me was this partial Belgian Superia Gemini ax. Dressed up in Guerciotti clothing. The catalog shot after.
File Type: jpg
File Type: png
clubman is offline
Old 01-14-19, 11:49 AM
T-Mar
Quoted: 4041 Post(s)
Liked 1,592 Times in 1,143 Posts
The last time I looked, they still had the rule prohibiting aero brake cable routing and aero levers.
T-Mar is offline
Old 01-14-19, 11:59 AM
CliffordK
CliffordK's Avatar
I think the Italians were a bit repressive with their Eroica rules, but I believe those are changing to be more accepting. And, they did have exceptions for parts vintage before their "cutoff".
I doubt many people would be turned away at the gate.
Old 01-14-19, 12:08 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1555 Post(s)
Liked 1,002 Times in 468 Posts
Aero brake levers have been permitted at Eroica CA for the last several years.
rccardr is offline
Old 01-14-19, 01:14 PM
Hubertus
Quoted: 8 Post(s)
Tange frame
The SR is very much like my own bike. The guerciotti frame isn't.
I still have to find out how this site works. Can you look at the pictured in my album?
Hubertus is offline
Old 01-14-19, 03:09 PM
T-Mar
The OP's bicycle is one of the quasi-aero frames with the down and seat tubes formed to an elliptical profile only in the mid-section. This was a cost concession that permitted conventional lugs to be used, as well as standard, clamp mount front derailleurs and round seat posts. If desired, they could also use the clamp mount shift levers. These are more common than full aero frames and were offered in more brand names. Given the Tange tubing, it is likely Japanese in origin, in which case the serial number may disclose the manufacturer and build date. Photo assist...
T-Mar is offline
Old 01-14-19, 03:47 PM
CliffordK
CliffordK's Avatar
There are several differences between my SR and your "unknown" bike.
  1. Cone Shaped headset on my SR-Semi-Pro
  2. Aero (AX) shifters on the SR-Semi-Pro
  3. Non-round seatpost on the SR-Semi-Pro (note the seat tube is round at the bottom).
  4. Non-round lower headtube lug.
  5. rear brake cable routed below the Top Tube.
  6. I like @Hubertus' front cable clip.
There are also quite a few similarities between the bikes. It is possible they are the same, but different years.
However, I would imagine there is a common tube set, and lugs. I need to move my pump peg, and I'll verify my tubing type.
Old 01-15-19, 09:27 AM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,374 Times in 888 Posts
Wasn't there a Lotus with AX?
RobbieTunes is offline
Old 01-15-19, 09:48 AM
CliffordK
CliffordK's Avatar
Oh, Huffy made an AX based bike too.
Although, that one was the Huffy Aerowind based on the Shimano Adamas AX groupset. But, it would be important to note that Shimano made a full line of "aero" groupsets from simply "AX" to "Adamas AX" to "600 AX" to "Dura Ace AX".
And, of course, these were built into a range of bikes.
Old 01-15-19, 05:41 PM
Hubertus
Quoted: 8 Post(s)
Tange frame designed by Shimano.
As I understand it. Shimano designed the entire aero bike, including the Tange frame and all the Little details. This complete bicycle then was sold by various manufacturers under their own brand.
I wonder how many there are. I spotted a Shogun recently on Pinterest.
Hubertus is offline
Old 01-16-19, 11:49 AM
T-Mar
The only aero bicycles that Shimano had direct input on, were the show models that they had contract built to display their AX component groups. The majority of Asian manufactured brands aligned with Shimano had aero models. Among those not already mentioned, that immediately come to mind, are Araya, Miyata, Nishiki, Panasonic, Tsunoda, Takara, Univega and Velosport. Many of these were contract manufactured by other companies, so the best indicator of origin is the serial number.
T-Mar is offline
Old 01-19-19, 07:00 AM
Hubertus
Quoted: 8 Post(s)
Serial number.
The only aero bicycles that Shimano had direct input on, were the show models that they had contract built to display their AX component groups. The best indicator of origin is the serial number.
The serial number is: 2B12795. Can anyone make Sense out of that?
Hubertus is offline
Old 01-19-19, 07:06 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1624 Post(s)
Liked 1,047 Times in 627 Posts
Sorry for the OT question, but can anyone else confirm this? I just watched part of the '86 TDF where Lemond won it using aero brakes (and clipless pedals!). Seems kinda silly to ignore facts like that in deciding which pre-1988 equipment to allow and which to forbid. I would definitely be OK with clipless pedals if they were pre-1988, but it's not my ride.
Lemond1985 is offline
Old 01-19-19, 08:30 AM
T-Mar
The serial number format is consistent with that used by M-a-t-s-u-s-h-i-t-a of Japan. They are best known for their Panasonic brand of bicycles but also contract manufactured for other companies, including Schwinn. The frame was manufactured in very early 1982..
T-Mar is offline
Old 01-21-19, 03:59 PM
RobbieTunes
Quoted: 378 Post(s)
Old 01-23-19, 02:20 PM
T-Mar
Putting aftermarket 600AX calipers on a Comp TA does not make it an 600AX aero bicycle.
T-Mar is offline
Old 01-23-19, 03:35 PM
RobbieTunes
Quoted: 378 Post(s)
I had to mount them on something. Nice catch on the model.
I have the seatpost, too, so I'll swap that in to further the heresy.
One quickly forgets any aero advantage when trying to actually stop the bike with these calipers/angled rims.
You have to understand, my reality is, well, different.
I was actually just showing the brakes, that's all.
Old 01-25-19, 03:01 AM
Hubertus
Quoted: 8 Post(s)
Agree
I must agree with T-mar, but these brakes look good on any bike.
Hubertus is offline
Old 03-04-20, 08:35 AM
Dieptriest
Dieptriest's Avatar
Bikes: Batavus Professional '84 , MEKK Poggio '14, Peugeot PX8 '78, Koga Miyata Roadracer '83, Concorde Colombo 1987-88, Jeunet Captivante 190 '70, '70 Presto
Speaking of branding. A case of aftersale branding.
Pick-up a bike build with a Tange Aero 600 tubeset branded Colnogo??
I think just a Shimano Aero 600 AX frame with a dishonest brand sticker on it.
Norda, JanJanssen, Miyata and more used a Aero 600 Framsets or Tubesets.
and the Tommasini Air Prestige look like it.
Dieptriest is offline
Old 03-04-20, 08:37 AM
Dieptriest
Dieptriest's Avatar
Old 03-04-20, 06:09 PM
embankmentlb
embankmentlb's Avatar
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 63 Post(s)
Liked 88 Times in 46 Posts
There were Suntour equipped aero bikes also!
embankmentlb is offline
Old 03-04-20, 06:19 PM
embankmentlb
Quoted: 63 Post(s)
lt is not about an actual date but rather a spirit of the old verses the new.
Campy C-record was a bit late to the aero game but it IS the pinnacle of the aero group sets. How many grand tours were won with it?
Old 03-04-20, 09:51 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Bikes: 1985 Trek 620
Quoted: 1276 Post(s)
Liked 1,010 Times in 558 Posts
@embankmentlb has finally shown us a large picture of his Vista Aero Course! I have one, too (that I am selling to thin the herd--not advertising it, just saying)--1982 in 64cm form. Bought it with this nicked up powder coat job and was able to shine it up a little. Heavy frameset at 3500g for frame/fork/headset. Rides strongly.
RiddleOfSteel is offline
Likes For RiddleOfSteel:
