Peugeot bike identification and rebuild
Hello everyone!
I was given an old peugeot bike (could be 80's or 90's, maybe older) and it is missing the rear derailleur and some other parts before I get it working.
Could you help me identify my bike so I can find the correct parts for it?
The Serial number on the rear stays that I found is Y702 15688, it doesn't seem to match any peugeot serials I have found on the internets.
I would like to post some pictures, but the forum won't let me since I'm new.
Quoted: 3803 Post(s)
Liked 3,324 Times
you shall be able to determine the model and year of your example by browsing the catalogues posted here -
bikeboompeugeot.com
bikeboompeugeot.com
thanks for the info, but there are A LOT of brochures on there... any tricks into narrowin it down?
It has some Mafac brakes... but other than that I cannot find any other names or clues on the bike.
Quoted: 1088 Post(s)
Liked 1,205 Times
The last three paragraphs of this page should have a clue: https://mrvelo.weebly.com/peugeot.html
I would start with the 1987 catalog and see if your bike matches any pictures.
How accurate can the decals be?
based on them, it would be a late 70s AO8 (on bikedecals .net) White lettering with red white blue accents on each side, gold/black on the fork and top tube. The tube decal is also the same.
it looks very much like the USA 1977 AO8 brochure from bikeboompeugeot but blue
Liked 1,205 Times
And how would I go about and find a rear derailleur for this bike? I have no idea how the compatibility goes on those things...
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,568 Times
Why do you need a new derailleur?
Quoted: 1372 Post(s)
Liked 1,749 Times
If the bike is a UO8, you might want to check the front derailleur also. If it is Simplex, there is a better than fifty-fifty chance that it is cracked and/or broken, as is the case on this recently acquired Carlton...
One last thing and I may be stating the obvious. But your new bike is French. Everything about it is a little different. Seat tube diameter, threading, bottom brackets, headsets, etc. That's not going to effect the rear derailleur too much, but it will impact the front derailleur if you need to replace it. The idiosyncrasies of french bikes are described very well here: Sheldon Brown's French Bikes. Proceed cautiously and don't strip any of the french threaded nuts and bolts.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
For a modern, but vintage looking rear derailleur, try this: A Sunrace RD-M10 https://www.rivbike.com/collections/...r-rear-kls-lkn. It is currently out of stock at Rivendell. They have them on AMazon, but make sure if buying online that it includes the rear deraiilleur hanger, but it should work with an older Japanese hanger...
My UO-8 came with a Simplex Prestige RD which was upgraded by the bike shop at purchase to a Suntour GT (steel) and later to a Suntour V (alloy) as they shifted far, far better than a Simplex.
French bikes are fun, but French stems and seatposts are not common if you decide to change bars I still ride my blue UO-8 when I want a retro-back to the roots day.
Quoted: 4722 Post(s)
Liked 3,036 Times
The subject bicycle is a 1977 Peugeot A08, with modifications. Based on the minor frame variations, it appears to be a foreign market model, possibly Canadian.
The largest "field mark" (a term from birdwatching for quick identification) of an AO-8 vs. a UO-8 is the front fork blades. It the front fork ends are chrome it is a UO-8, if painted, it is an AO-8 (or other less common variant)
For a modern, but vintage looking rear derailleur, try It is currently out of stock at Rivendell. They have them on AMazon, but make sure if buying online that it includes the rear deraiilleur hanger, but it should work with an older Japanese hanger...
Thank you so much for all the info! I don't mind the old school or modern look, it is mostly a budget driven rebuild. I like the downtube friction shifter, I like the low maintenance factor. Looks like I have a Simplex front derailleur and it's probably the original one so I will replace that too!
The wheels on them are probably not original. They seem to be aluminium alloy. They are in good shape.
