Manufacturer - Tern vs Dahon and alternatives
So I am looking for my first folding bike. Mainly for use on weekend trips and domestic vacations - so taking a train somewhere and then cycling (I have a Cross / Hybrid bike for day to day in the city. I'm living in Tokyo - so for 20 inch bikes (discounting Brompton) I was looking at Tern or Dahon (because of good availability to try in local shops, reasonable prices and good model range - Birdy or BikeFriday are a bit too expensive).
I'm looking to spend around $1000 local equivalent, but could go bit more - main question is which is the better manufacturer, I have read the reports on these forums about racking on Tern frames - it seems rare now, but Dahon seems less affected by this issue.
So I wonder advice on choosing between Tern and Dahon?
Quoted: 573 Post(s)
Liked 118 Times
- Tyrell (IVE) https://www.tyrellbike.com/en/products/
- Iruka https://www.iruka.tokyo/en/overview/story
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Check out Loro Slow Spot and Y's Road Ueno for a broader range of folders. Relative to the scale of Tokyo they are close to each other, so in practice require one expedition.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Chromoly will be dependable and, in the context of folding bicycles, at least, will be no heavier than aluminum. For those reasons among others, I chose the Dahon Speed.
Also, beware of the psychological draw of disc brakes. Unless the frame and fork are made for thru-axles (no mass-production folding bicycles that I know of are, yet), disc brakes are a scam, resulting in disappointment for the life of the bicycle.
Quoted: 573 Post(s)
Liked 118 Times
Likes For Winfried:
Quoted: 194 Post(s)
Liked 204 Times
Because discs are nowhere near as good as coaster brakes
There is actually a whole ongoing battle on the subject of disc/no-disc, but as an R&D engineer I have yet to see any convincing data for the pro or con camps, other than the usual model specific issues one would expect to occur. Lots of hearsay, of course.
55+ Club,...
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 847 Times
Lower cost, excellent alternatives are as follows (I still might miss something, so please forgive me):
Zizzo folding bikes: ZiZZO folding bicycle | Lightest folding bike | Max load 300 lbs
Origami folding bikes: Lightweight Folding Bicycle & Folding Travel Bike for Sale (origamibicycles.com)
DownTube folding bikes: Downtube Folding Bikes with suspension & carbon belt drives
These are just 3 alternatives, all providing cost effective bikes, and great customer service. The Origami and DownTube bikes have their owners as members of the forum.
Likes For tds101:
Quoted: 573 Post(s)
Liked 118 Times
Since it'll be used mostly in urban settings, if available, I would choose one with an internal gear hub instead of a derailleur.
Check out Dahon's K3, and its 14" wheels and… derailleur — At 84,150JPY (~USD$850), it's within your budget.: The 2021 model has a lug, so a Brompton bag can be used with the Minimod adapter:
Palmer
Quoted: 1666 Post(s)
Liked 1,819 Times
The 2021 model has a lug, so a Brompton bag can be used with the Minimod adapter...
https://klickfix.com/en/products/detail/variants/0211R
Quoted: 573 Post(s)
Liked 118 Times
However, the Dove i3 has no lug, although a fork-based solution is available.
The Curve might be bigger (Check train operators' requirements for folded bikes).
Klickfix takes less weight (max 7kg vs. Brompton 10kg), there are more bags for the Brompton, and (I find they) are more convenient.
Too bad the K3 doesn't come with a gear hub + chain protection.
Thanks for the shop suggestions in Tokyo - I have been to Ys Shinjuku (the ebike / folding bike dedicated shop - is the Ueno shop even better?).
Big question on bike shops in Tokyo (or around) - where can I get an actual decent test ride? Ys only have very few test drive models, I went to Asahi Bicycle and they let you ride it outside for about 50 metres. For me I would like a 5/10 minute ride so I can determine the fit would work and also to check how the different models and tyre thicknesses respond to uneven road / pavement surfaces.
Is there anywhere in Tokyo like that or just outside Tokyo - I heard Hasirin in Kashiwa is good - but quite a trek (1.5 hours).
'm considering going there as they have a great number of models I could test drive - though assuming I find something I like I would feel obliged to make the purchase there, which may make going back for maintenance in future a bit of a chore.
Wonder if any alternatives closer to Tokyo.
Quoted: 840 Post(s)
Liked 336 Times
This is the page of Y's Ueno. I am not sure about riding at Y's. Also, I do not know how your Japanese is, but at Y's Ueno it may be hard to find someone speaking English. At Loro Slow they will let you ride and nearly everybody speaks decent English. However, I do not think they have Dahon or Tern. Loro may give you a package deal when you buy accessories together with the bike.
Just bought a 2009 Dahon MU SL, original MSRP is $1500, bought for $200, a super light 19lb 20" folding bike, and the thing is practically new... Definitely look for used Folding bike and you can get way better value.
I bought a brand new Dahon Vybe D7 last year for $480, and had to sell it last month for $350.
As soon as the bike leaves the lot, it depreciates... The exception would be Bromptons, as they retain value exceptionally well over the long run if that's what you are after. Its worth investing new.
