Micro adjusting electronic derailleur
Quoted: 106 Post(s)
I have a Red etap on a road bike. Today I felt some gear were getting stuck and not shifting. So I started playing with the microadjuster which is super easy to do while riding.
I then realized the rear hub was a bit lose and that was doing it. So after I tightened up the hub I had to adjust again.
That got me thinging. Should it ever be needed to micro adjust electronic group-sets? With cables is expected considering they stretch..
Also, I wonder how to find the perfect "sweet spot"
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Cables don't 'stretch'. And, from page 79 of the SRAM AXS user manual:
79Align the upper pulley with the center of the 2nd-largest cog by adjusting the rear derailleurress and hold the shifter AXS button (1a) while pressing the shift paddle inward (1b). The left shifter will adjust the derailleur inboard, and the right shifter will adjust the derailleur outboard.The rear derailleur may not appear to move. Watch for the derailleur LED to flash to confirm the derailleur executed the command.
Quoted: 313 Post(s)
Liked 679 Times
I think I've had to micro-adjust the rear derailleur on my original 10-speed Ultegra Di2 once in 5-6 years.
Bikes: lots
Liked 2,932 Times
Try all 3 and go w/ whichever one seems to work best. I know what you're talking about, you can easily be off 1-2 clicks either way and it will shift just fine. Don't overthink it, if it starts acting up or bother you go a click or 2 in the other direction.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
If your electronic shifting needs adjusting, it's almost certainly a sign that something is bent or loose.
The way to find the sweet spot is to set it so neither upshifts nor downshifts happen slowly. Find the point on each side where you can tell it makes a difference and go in between. Or just use your eyecrometer and make the chain go straight onto the cog.
Yeah, what 3/4 of everyone calls stretch is just ferrules bedding in and the cable taking a set around any tight bends. It can be largely avoided by pre-stressing the cable upon fitment.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have Red eTap since February 2016 and have put over 28,000 miles on it, i've done the micro adjustment exactly 1 time. This was after it's "winter" cleaning where I R&R the wheels, cassette and RD to be disassembled, cleaned and reassembled. I also R&R the chain, chainrings and crank.
Otherwise it's dead on all the other times i've taken the bike apart.
bike whisperer
Liked 716 Times
BTW, you just clocked up 8k posts
On Your Left
Liked 2,433 Times
Likes For GlennR:
Bikes: lots
Liked 2,932 Times
^That's pretty cool!^
Likes For cxwrench:
[QUOTE=cxwrench;22113333]Cables don't 'stretch'. And, from page 79 of the SRAM AXS user manual:
Cables don't stretch but housings wear. I thought you were a mechanic.
Bikes: lots
Liked 2,932 Times
[QUOTE=cxwrench;22123482]One sentence ramble?
Cables will wear grooves in the housing where the cable bends and will be accelerated
if you are stretching against the lower limit screw.This from a real CX mech:
https://www.cxmagazine.com/
Nov 15, 2017 — Cable and housing maintenance is essential for effective shifting and braking. ... bikes after each race as well as before to monitor wear and tear and note ... Some cables will groove the liner and cause it to crack prematurely, ...
________________________________________________________________
I have never seen one crack but if the shift cable still drags after replacement the housing probably has a groove and needs to be replaced. Me
Ask the Mechanics: All Things Cables, Housing and Cable ...
https://www.cxmagazine.com/Nov 15, 2017 — Cable and housing maintenance is essential for effective shifting and braking. ... bikes after each race as well as before to monitor wear and tear and note ... Some cables will groove the liner and cause it to crack prematurely, ...
quite being able to be modified to racing spec so I told them to get as close to 48 deg advance at 2800 dist rpm (crank speed /2).
as they could. Well they were able to get it to 4800 which was a little more than I wanted and a bill for $700 labor.
Bikes: lots
Liked 2,932 Times
[QUOTE=popeye;22124004]
What is your deal? The OP asked in post 1 about ETAP...I copy/pasted the instructions for ETAP. You start talking about housing wear. What does that have to do w/ this thread? That's right...nothing.
As for me being a CX mechanic my time working for pro/elite level racers started in '03/'04. I've built and maintained numerous bikes for a bunch of national champions. You can trust me when I say 'been there, done that'.
[QUOTE=cxwrench;22124344][QUOTE=popeye;22124004]
I'm replying to your comment "Cables don't 'stretch'. And, from page 79 of the SRAM AXS user manual:"
I agree it has nothing to do with ETAP.
bike whisperer
Liked 716 Times
Cables don't stretch.
Bikes: lots
Liked 2,932 Times
[QUOTE=popeye;22124365][QUOTE=cxwrench;22124344]
