Any ideas on these weird noises my car is making?
Old 07-09-21, 04:25 PM
EJ123
djentleman
EJ123's Avatar
Quoted: 44 Post(s)
Liked 37 Times in 28 Posts
Not super up to speed with car mechanics, but I think I have a bad starter (makes this screech noise about 60% of the time on ignition), and also now have some resting cyclical clicking up at the hood (made the noise even w/ the AC off).
Any ideas on this 04 Jetta? Assuming the first noise is the starter, these things are like $600+ to replace at the shop!
Noises
EJ123 is offline
Old 07-09-21, 08:41 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 666 Post(s)
Liked 486 Times in 358 Posts
sounds like it could be a bad pulley bearing. which pulley i couldn't tell you. you'll just have to pull the accessory belts off and turn all the pulleys by hand to see if any are dry
or a/c clutch. it spins even with the a/c off
is the power steering working right? ie. no spots where it gets stiff when you're making a hard turn?
could be a dry water pump bearing, too. any idea when it was last replaced?
start with the belt pulleys and the a/c clutch
thook is online now
Likes For thook:
Old 07-09-21, 08:50 PM
SkinGriz
Do cats eat bats?
Bikes: BigBox bikes.
Quoted: 271 Post(s)
Liked 202 Times in 154 Posts
Find a mechanic who is good with a stethoscope.
SkinGriz is offline
Old 07-09-21, 08:55 PM
SkinGriz
Do cats eat bats?
Quoted: 271 Post(s)
^ There’s that. If the accessory belt has never been changed or been a long time, getting that changed would allow a mechanic to check the play on all the pulleys.
Best case would be idler pulley.
But again, a good troubleshooting mechanic is your best bet.
SkinGriz is offline
Old 07-09-21, 09:08 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 666 Post(s)
right!! a stethoscope. those are cheap at an auto store. i have one, very handy
thook is online now
Hondo Gravel
es ist mir egal
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 2169 Post(s)
Liked 2,265 Times in 1,462 Posts
2 blowouts and a cracked windshield in just 2 weeks Anyways if there is a noise that sounds bad or not normal for your car it’s probably not good.
Hondo Gravel is offline
Old 07-09-21, 09:15 PM
downtube42
downtube42's Avatar
Bikes: Soma Fog Cutter, Volae Team, Priority Eight (for sale), Nimbus MUni, Trek Roscoe 6, Focus Mares.
Quoted: 464 Post(s)
Liked 975 Times in 493 Posts
Some years ago I was in an engine company innovation group, and we investigated the feasibility of collecting engine sounds via smartphone, and comparing them to an online database of known failure sounds. We were somewhat surprised to find it seemed feasible for many really common failures. Pretty cool project. It turns out smartphone microphones were not really up to the task though. More importantly, neither the suits nor the service guys were terribly interested. I think it will happen eventually... if it hasn't already. I'm out of that industry.
Is this the noise:
Description of a DIY fix. There are many others.
https://forums.tdiclub.com/index.php...starter.90249/
No clue on the cyclical clicking; need more info.
downtube42 is offline
Old 07-10-21, 07:41 AM
EJ123
djentleman
EJ123's Avatar
Quoted: 44 Post(s)
Yup power steering works OK. It's not the smoothest and effortless like in newer rental cars I've driven, but never felt like anything was off. I think I had the water pump replaced about 4 years ago with the timing belt at 96k miles (it's 116k miles now). Have to make some long road trips here soon, so hoping no car issues
EJ123 is offline
Old 07-10-21, 08:41 AM
StupidlyBrave
Chepooka
StupidlyBrave's Avatar
Bikes: 1990 Trek 1400 7spd; 2001 Litespeed Arenberg 10 speed
Quoted: 623 Post(s)
Liked 445 Times in 280 Posts
Yeah, I think it is a bearing somewhere on the accessory drive. A common issue. Since it is a VW, you must disassemble everything - probably start in the back seat.
Here, I am replacing front struts. Starting in the back, of course.
StupidlyBrave is offline
Likes For StupidlyBrave:
Old 07-10-21, 08:44 AM
EJ123
djentleman
EJ123's Avatar
Quoted: 44 Post(s)
This sounds priceeey
EJ123 is offline
Old 07-10-21, 08:57 AM
StupidlyBrave
Chepooka
Quoted: 623 Post(s)
I was kidding. Mostly.
I did have two Passats at the same time and an Audi tech asked me if I thought I could do the heater core faster the next time. I told him that I am never doing that job again.
The pic below was when I was prepping the car to give away to my daughter's husband. I did put new struts, new brakes and new bearings on that evening. It still needed tires for inspection. So after I gave it to him, it sat at his grandfather's barn for 2 or three years and has now disappeared.
That car did have an idler pulley explode (it was plastic!). Fortunately, some of the aftermarket parts are better - I replaced it with an aluminum one.
Old 07-10-21, 09:06 AM
SkinGriz
Do cats eat bats?
Quoted: 271 Post(s)
My brother had 2 VWs (Passat then an A8). Both were gotten rid of due to premature failures.
Then he got a turbo golf.
He’s a slow learner.
SkinGriz is offline
Old 07-10-21, 04:07 PM
thook
(rhymes with spook)
thook's Avatar
Quoted: 666 Post(s)
i think downtube42 has you covered. ie. it's the starter
thook is online now
Old 07-11-21, 06:43 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1706 Post(s)
Liked 1,352 Times in 874 Posts
Last heater core I did I was impressed I had only 2 leftover screws when I was done
dedhed is online now
Likes For dedhed:
Old 07-12-21, 10:07 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 20 Post(s)
Liked 1,380 Times in 1,022 Posts
Noises
I have an 02 GTI VR6, it goes through periods of making that post-start screeching noise (sometimes like your recording, usually much less) after starting. I was able to reproduce it for my mechanic (he owns a an independent VW shop) and he said it's common with VW of that era and nothing I should worry about. This car did have the starter die a few years back, so this is a 'new' starter (maybe actually 50K old by now)
RubeRad is online now
Old 07-19-21, 10:35 AM
xiaoman1
Awaiting Parole
xiaoman1's Avatar
Bikes: A few too many
Quoted: 973 Post(s)
Liked 1,075 Times in 627 Posts
Still a lot of plastic in these VW's as well as other modern vehicles...I know we need weight savings but plastic water pump setc? I haven't learned my lesson yet and replaced a few, but have not spent 40+ to buy another plastic plastic equipped car that has the same problems I am trying to avoid.
Best, Ben
xiaoman1 is offline
Old 07-19-21, 10:42 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 20 Post(s)
Best, Ben
I had to have my plastic 'crack pipe' replaced
Likes For RubeRad:
Old 07-19-21, 11:28 AM
xiaoman1
Awaiting Parole
xiaoman1's Avatar
Quoted: 973 Post(s)
HAHA, Well I hope the change of the pipe at least made you "Not worry and be Happy"....
Best, Ben
xiaoman1 is offline
Old 07-19-21, 11:46 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 20 Post(s)
It was apparently the last straw that triggered a whole-cooling-system replace. I might have gotten ripped off by the shop, about $2k is close to the BBK value of the whole car. It's a good strong engine and I bet will go for years more, but other things are dying. AC is dead, headliner is propped up with headliner pins, driver's side door handle basically ripped off the door, clearcoat is peeling in many places, trip computer display is only legible in temps under 60F, etc.
Old 07-19-21, 02:38 PM
SkinGriz
Do cats eat bats?
Quoted: 271 Post(s)
Bummer. I hate spending money on cars.
I enjoy bikes and motorcycles. I need a car.
SkinGriz is offline
Old 07-24-21, 08:03 PM
EJ123
djentleman
EJ123's Avatar
Quoted: 44 Post(s)
Part of me never wants to get rid of that bad boy. Cheap insurance, reliability, and boxy.
EJ123 is offline
Old 07-24-21, 09:59 PM
Hondo Gravel
es ist mir egal
I have noticed people are holding on to their cars much longer. Waste of money drive a new one off the lot there goes thousands FRIKIN rip off. I know this one person that will by like a Honda Civic with over 100K miles trick it out run it another 100K then by another 100K + car for next to nothing take the tricked out parts off the previous car then run that on the next car 100K + … Smart if you ask me. And fun fixing up those sporty small cars that get over 30mpg.
Likes For Hondo Gravel:
