Snapping the little nub on the end of the chain link?
Old 08-16-20, 09:06 AM
Canadianguy57
I just dropped a new crankset and bottom bracket and chain on to my mountain bike. When I installed the chain, there was a small part pretruding out, having hard time trying to get a grip on it to snap off?
Any suggestions or ideas would be appreciated!
Thanks
Canadianguy57 is offline
Old 08-16-20, 09:07 AM
Canadianguy57
Hi....New to the forum hoping to learn some new things!
Thanks
Old 08-16-20, 09:32 AM
_ForceD_
Sr Member on Sr bikes
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 1016 Post(s)
Liked 781 Times in 413 Posts
Protruding out of where? You need to be a little more descriptive.
Dan
_ForceD_ is online now
Old 08-16-20, 09:39 AM
Canadianguy57
Pretruding to the outside of the bike direction, about 3/16 it's on a shimano CN 93 chain.
I tried to add the pic but not allowing me yet!
Old 08-16-20, 09:58 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
Grab it with Needle Nose pliers and snap it off.
Shimano pins are designed to press in, then be snapped off.
topflightpro is offline
Likes For topflightpro:
Old 08-16-20, 10:13 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Use a Quick-Link of some kind. Messing with pins is obsolete.
Homebrew01 is offline
Likes For Homebrew01:
Old 08-16-20, 11:25 AM
Canadianguy57
I know....but it's in and there not a lot through the other side, maybe 3/16th
Old 08-16-20, 11:29 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,378 Times in 2,730 Posts
I think you are describing the special pin that comes with some Shimano chains. If so, just break if off with pliers as in post #5 . Even Shimano is now moving to quick links and you can add one if you like to make removal and installation easier. Any brand will do if it's the proper "speed" for your chain.
shelbyfv is offline
Old 08-16-20, 11:35 AM
shelbyfv
Expired Member
shelbyfv's Avatar
shelbyfv is offline
Old 08-16-20, 11:42 AM
topflightpro
The pointy end is the part you snap off. Are you sure you pushed it far enough in?
Old 08-16-20, 12:05 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I agree quick links are superior ..
fietsbob is offline
Likes For fietsbob:
Old 08-16-20, 12:07 PM
Canadianguy57
Usually the pin is sticking out a lot farther, not this one. I just found a KWC quick link, i didn't see it in the chain breaker container! I'm good now!
Thanks
Old 08-16-20, 12:13 PM
shelbyfv
Expired Member
shelbyfv's Avatar
I've seen chains that come in OEM or bulk packaging with a bit of pin stuck in one end. Not the same as the Shimano assembly pin and should be pushed out and discarded. Maybe that's what OP had. Glad it's resolved.
shelbyfv is offline
Old 08-16-20, 06:31 PM
Doug64
Doug64's Avatar
Quoted: 1182 Post(s)
Liked 833 Times in 435 Posts
If the errant pin is in one of the links at one of the chain's ends, establish your chain length, and adjust your chain length at that end. I never installed a chain that I didn't have to remove 2-4 links. Installing a "quick kink", as mentioned in a previous post, is good advice.
Doug64 is offline
Likes For Doug64:
Old 08-16-20, 08:24 PM
veganbikes
Clark W. Griswold
Quoted: 4323 Post(s)
Liked 3,944 Times in 2,637 Posts
If the pin is in properly just use some needle nose pliers or in a pinch I have used cable cutters to snap it off. Though yeah use quick links they are awesome.
veganbikes is online now
Old 08-17-20, 09:26 AM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
Most chains these days have swagged pins and are not designed to be reused. As a couple others have stated, use a quick link.
rydabent is offline
