Disengaging from SPD-SL pedals
Bikes: Giant TCR SL3 and Trek 1.5
Quoted: 12 Post(s)
Even though I’ve been road cycling since 2008, I only recently made the switch from SPDs to SPD-SL pedals. I wanted a wider pedal platform and needed to replace my existing shoes anyway, so I figured now was the time.
Since making the switch, I’ve noticed they seem much harder to disengage from than SPDs. Even after loosening the pedal tension as much as possible, they still don’t seem nearly as responsive. It’s interesting to me that they’ve become so popular given this issue, but I realize it could just be the adjustment and that some people may find it more challenging than others.
Interested in hearing other’s experiences.
TIA.
TIA.
Quoted: 3221 Post(s)
Liked 2,043 Times
Correct, the release tension is higher than SPD. You either get used to it or stop using it and go back to SPD (is what I did).
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I use both spd and spd-sl. I do feel like the spd-sl are a bit harder to disengage, but not bad. I find both types have their advantages over the other. My biggest drawback on the spd-sl is the lack of durability for the cleats. It does not take many steps before they start being destroyed. I purchased a pair of covers for them to take with me on rides, but I have not used them yet. I get off my bike considerably more than I used to, even shorter rides.
Likes For delbiker1:
Quoted: 18397 Post(s)
Liked 15,485 Times
Tour with SPD. Road bike uses SL. No problem unclipping with either.
The relative force required is irrelevant unless it causes problems.
Quoted: 2952 Post(s)
Liked 3,106 Times
They certainly take an intentional and definite heel rotation. Much more so than SPD in my experience.
Quoted: 645 Post(s)
Liked 797 Times
TIA.
TIA.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Likes For rubiksoval:
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
I used both SPD and SL, probably equally. SL pedals require marginally more force, but has never presented a problem for me. Perhaps OP set the SPD tension super low, or the tension on the springs is faultily low.
Quoted: 12 Post(s)
I didn’t have the SPD tension set that low. To me, spring tension should only be enough to have a firm connection with the pedal and no danger of coming unclipped unexpectedly. My initial impression on these SPD-SLs is there’s so much tension not only is there no way I could come out unexpectedly, but a great deal of force is required to come out when I want to. If you’re in a higher traffic area, it becomes a bit of a pain.
Quoted: 12 Post(s)
To me, it’s all about functionality. The only thing that you could say is less than optimal about SPDs is the decreased surface area can lend itself to “hot spots” on the feet of some. Otherwise, they’re cheap, simple and functional. That’s not exactly*****.
Likes For cafzali:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
After a 1000 mile week with my touring shoes on I switched back to my road shoes. Fell off right outside my house because my legs forgot about the extra force needed to unclip.
Quoted: 6934 Post(s)
Liked 10,938 Times
Huh. After 15 years on SPD-SL, I bought some SPDs for a bike, and find them trickier to get out of. Maybe it's just what you are accustomed to?
Either way, they are both very usable.
Quoted: 850 Post(s)
Liked 344 Times
Something sounds off here. I've never used SPDs before, but I've never felt like my SLs required too much force to unclip - except for when I first got them and their tension was set to the maximum. Nearly dislocated my knee (is that a thing?) trying to get my foot out.
At the lowest tension level, especially once the cleats wear a bit, I have absolutely no issue getting my feet out. I don't even need to do a special twisting motion. I can just kick sideways and the twist happens automatically. That's saved me a couple times.
I actually run my tension somewhere around 20-30% of max. More for races. Any less and I'd be afraid of an accidental unclip.
I've used 105 (5800) and ultegra (R8000) pedals and both seem similar. My crappy old R540 pedals were probably a bit lighter, but also a bit "stickier" if that makes sense. What pedals are you using?
Quoted: 12 Post(s)
It's funny, but where I lived when I first started cycling, I wouldn't have worried about this much because I could go an entire 20-30 mile ride and barely, if ever have to disengage. But now I'm in a more heavily populated suburb with much more frequent red lights and it's more of an issue.
Bikes: Shmikes
Quoted: 10147 Post(s)
Liked 5,840 Times
Give your foot a slight twist in the other direction (heel in) before disengaging. They also get easier as the cleats and pedals wear.
SPD-SLs seem to have a higher minimum tension than SPD pedals in general, and newer models seem to have a higher tension than older ones. Going from PD-5700 to PD-R8000 I was surprised to how much stiffer the release felt on the new ones even though it was set to minimum tension. I adapted after a couple of rides, but I still find it a bit unnecessary. It is not a big enough issue that I would want to switch to another system over it.
Bikes: two blacks, a blue and a white.
Quoted: 444 Post(s)
Liked 844 Times
I use the 105 pedals on all the ponies. early on, after a couple reeeeely embarassing, um, events ("FRED DOWN IN ASILE FIVE"), I started visualizing my foot rotating before trying, as though my heel was just circumscribing a "6pm to 3pm" circle (almost always left foot first, so I can rest it on the curb at stops). "throw the heel out hard" is the thought, and I think of it moving in a rather not-true-to-life way. gets me out clean on time all the time now. my tension is about as low as I can set it, feet never release unexpectedly.
Quoted: 645 Post(s)
Liked 797 Times
senior member
I recently got DuraAce SPD-SL pedals with blue cleats and set the pedals at the middle of the tension range and find that the dis mount is as easy if not easier than with my former SPD Look cleats (red) with LOOK SPD pedals .
Likes For SapInMyBlood:
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, my SPD-SL cleats/pedals have a bit more release tension and friction than my Look Delta. It's a combination of spring tension and friction from the rubbery bits that make SPD-SL cleats a little better for walking or setting down a foot at stops. Makes clipping/unclipping feel a bit spongy compared with the old Look Delta cleats/pedals. Other than that, the two systems are very similar.
Try a bit of wax on the friction surfaces on the cleat and pedal. A candle will work fine, or a bit of leftover scented candle wax -- that stuff is soft and easy to dig out with a finger. Smear it around the external surfaces of the cleats, and mating surfaces on the pedals. Clip in and out a few times. It'll help a little.
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 579 Times
TIA.
TIA.
Also, what do you mean by ''responsive''? I tried both and I prefer SPD-SL even if they're a little harder to disengage. In fact, I feel safer that way. I wouldn't call it an issue.
