Adaptor for old Park stand for Carbon Frames?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,636 Times
Have a perfectly good Park but the new fat frame does not fit. Any adapters or solutions?
As a result for cleaning I had to resort to a new stand which is at a good height but doesn’t allow me to turn the cranks:
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Any top tube can at least be rested in the clamp. Clamping a carbon top tube is always risky with this type of clamp. I cut the spring shorter, but really a much weaker spring is needed. My newest Cinelli superstar frames have a TT that's skinny near the seat tube, so it works, with the shorter spring.
I often clamp the seat post.
Randomhead
Liked 3,696 Times
Silca has a solution but it's a bit expensive https://silca.cc/products/hirobel-clamp
not as expensive as a new frame though
You shouldn't be clamping the frame anyway, that's why people have been clamping the seat post for quite some time now.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Clamp the seatpost instead of the frame. It's much stronger.
Likes For genejockey:
Grupetto Bob
Liked 5,636 Times
Good suggestion. It doesn’t help me be as lazy as am since it will take me 30 seconds to remove the scrotul bag and another minute to unscrew the flashy-flashy, but you probably saved me $150! So thank you.
Laziness is so under-rated and under-paid.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Cheaper to replace a cracked seatpost than a cracked frame.
Liked 11,896 Times
It's a trick I learned 25 years ago when I brought my Cannondale to a shop and the wrench clamped the seatpost instead of the tube, and explained why.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Randomhead
Liked 3,696 Times
The OP dodged a bullet by not being able to clamp the bike in his stand, or he would be exploring how generous the makers damaged frame policy is.
I don't know when people started using the seatpost. I crushed the seat tube of the first frame I ever built in a park stand back in the '70s, and still didn't think to use a seat post. Now I have one sitting around for use on frames.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Park made a tool for just this application but they have discontinued it. It called the ISC-4. You can find them on Fleabay occasionally.
Stuart Black
Stuart Black
Likes For cyccommute:
Grupetto Bob
Liked 5,636 Times
Excellent ideas, and rationale, the seat post is it. Thanks to the brain trust.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
A cheap metal (steel or aluminum) post of the proper diameter can avoid that problem as well. Mark the height position of your current post, pull it out of the frame, and insert the cheap post for clamping. If you routinely service bikes with a variety of post diameters, something like the Park ISC-1 might be better than keeping an inventory of various cheap posts on hand.
