Why do tubulars lose air?
I love my tubulars and I don't even mind pumping them up before each ride but it puzzles me as to why?
Most performance-oriented tubulars use latex inner tubes, resulting in fairly quick loss of pressure. (You can get latex inner tubes for clinchers as well, and this similarly results in faster pressure loss than if you use standard butyl tubes.)
Likes For HTupolev:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Air is not very clever, but latex is easy to trick.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Likes For dmanders:
Quoted: 6193 Post(s)
Liked 4,809 Times
If the rubber were thick enough and made with stuff to make it harder for air to pass through it, then you'd be riding something about the size of your car tire. Do you really want that much weight on your bike?
All tires clinchers, tubeless and tubular let a little air pass through their thin material. Till technology gets a cheap enough fix for that, we have to put up with it if we want something comfortable enough to ride.
Thanks you guys took care of that question,just the way it is.
As has been stated, Latex tubes' structure (physical properties) are much more permeable than vulcanized/butyl tubes. They leak air at a higher rate. It's a trade-off. They deflated faster but provide better road feel, better cornering and handling than standard rubber tubes and clinchers.
FWIW, I run "Open Tubular" tires (Challenge Strada Biancas) with latex tubes. I find the ride almost the same as traditional tubular tires with the convenience of clinchers. And yes, they leak air fairly rapidly and need to be topped off before every ride.
Liked 2,969 Times
Likes For Troul:
