New crank arm not fitting tapered axle
I recently bought an old bike (around 2009 specialized tricross) online. It needed a new crank shaft, I got the setup from a local shop however it doesn’t seem like it fits in properly. I thought the gap was normal until the crank arm almost wobbled off during a ride this weekend. Any idea how to fix this? The local shop has a three week wait time to get in
The site won’t allow me to upload any pictures but it’s out quite a bit. Maybe half an inch?
Quoted: 18373 Post(s)
Liked 4,508 Times
Liked 4,508 Times
Ok,
Do you have a photo with the crank installed, but the bolt removed?
I would probably remove the crank arm. Lightly grease the spindle, and put it back on. And, keep tightening the bolt if you can.
I think the crank should go about 3/16" further down on the spindle. Ultimately the bolt will be fairly tight. I do most of my personal work by feel rather than torque, but someone should have torque specs.
If you ride the bike with the crank arm loose, you risk hogging out the arm, and permanently ruining the crank arm.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
It's a 'bottom bracket' not a 'crank shaft'. How tight did you get that bolt? It's supposed to be very tight, old man strength tight.
Likes For cxwrench:
Does the spindle have the correct taper for the crank arms? I'm thinking the new BB might be ISO taper and the arms JIS or vice versa?
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quoted: 2604 Post(s)
Liked 1,928 Times
The possible ISO/JIS mismatch was my first guess.
Looking at the pictures, though, I think some grease and a torque wrench might be the answer. There's always been some back-and-forth over greasing the taper of a BB, but that crank looks like it needs some help. So grease the taper, grease the crank bolt, tighten it to the torque spec (50 Nm is flashing in my head, but better to look it up than rely on a possibly faulty memory). That sequence should seat the crank on the bottom bracket, and with adequate torque, it's unlikely to go anywhere.
Quoted: 1088 Post(s)
Liked 1,024 Times
I would bet money that it isn't tight enough. Skip the whole torque spec on a crank and just tighten it. When I tighten I start with the drive side, I use an 8mm allen socket in a 16" long ratchet and use the wheel as my leverage. I tighten till it really just doesn't want to tighten more, then I use the drive side pedal as the leverage for the non-drive crank arm. Again till I can't tighten more. Then go ride. I've never seen a crank bolt break so don't worry about that. But it really is one of those tighten like crazy spots since you want it to never come loose.
Likes For Russ Roth:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Having information from a torque wrench is good if you (like the OP) don't know what you're doing, though. 30 ft-lbs is 30 ft-lbs.
We have no idea what he'll get from telling him "Just tighten it like a man!"
Bikes: lots
Liked 2,932 Times
Don't do this, ever. A square taper is a friction fit, grease is an anti-friction lubricant and does not belong on a square taper.
With or without lubricant, in use, cranks will make metal-to-metal contact with the spindle, causing fretting erosion of the steel spindle for all but the lightest riders. Lubricating the spindle for assembly assures a predictable press fit for a given torque. Without lubrication, the press is unknown, and galling (aluminum transfer to the steel spindle) may occur during assembly. After substantial use, spindle facets may show rouge and erosion from aluminum oxide from the crank, showing that lubricant was displaced."
As far as greasing the tapers and torque, Campagnolo recommends putting grease on the taper and 28 ft-lbs of torque.
Likes For Generald1sarray:
Quoted: 1324 Post(s)
Liked 927 Times
Likes For Miele Man:
