A frightening look inside of a BMC Road Machine RM01
#101
Quoted: 1096 Post(s)
Scholarship and quality are not comparable. If you read up on the definition of quality, you will find that I am correct. A Chevy that meets its specs is higher quality than a Beemer that doesn’t. That is just the nature of the beast. Common lingo usage is often very different from real meaning.
What you are actually saying is that there is only one right specification, the highest one imaginable. If you meet that spec, then you have high quality. If not, then you don’t. That isn’t how quality works. Every level of a product range can exhibit high quality if it delivers what it promises.
If all a product offers is crap, even if it's 100% crap 100% of the time, it's still crap. If you think 100% crap is higher quality than a flawed masterpiece, you should be interested in a deed for the Brooklyn Bridge I have to sell you; it's perfectly valid, and you'd have to say it's quality is impeccable. I, however, would not say it's quality was very high.
If something meets a spec, it's not high quality, it simply has that quality. In the sense of an attribute, the notion of a quality exists independently of standards, but yes, the establishment of a standard is what determines the extent to which something has it or not, and standards are either dependent on context or essentially arbitrary.
What you describe as "the way quality works" pertains when one is comparing things that are supposed to be similar. For instance, "tall" is a quality in the sense of being an attribute, for which standards are typically contextual, e.g., a hill is not tall if it only measures nine feet, but if a man measures only eight feet, he is VERY tall. The same holds true for things that are somewhat, but not entirely similar, and standards are arbitrary. For example, if all Huffy bikes met their spec all the time and all Argonaut bikes met their spec all the time, it would be unreasonable to say they were therefore of equally high quality, simply because there is the notion of an ideal bike, a sort of over-standard beyond the arbitrary specifications that the manufacturers set for themselves. Both makers set standards above garbage, and both set attainable standards, but they didn't set them at the same point, and it is the point at which they set their standards that determines whether one is higher quality than the other when they both meet their own specs as you describe.
#102
Quoted: 600 Post(s)
Liked 778 Times
+1 my thoughts exactly. I only have 1 CF bike and hope Cervelo has better fabrication. I was also considering a BMC and was told they do not warranty the frames which is why my LBS stopped selling them.
#103
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
If anyone in this thread is looking to unload their BMC frame for cheap let me know.
#104
So probably not Shimano going too thin, and probably not a manufacturer defect at all.
But it sure is fun to speculate...
#105
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 158 Post(s)
Liked 138 Times
Edit: I would speculate that if someone cut open an R3 it would look pretty similar to the BMC.
#108
Quoted: 6556 Post(s)
Liked 58 Times
That's not what I was saying at all.
#109
For disclosure I did not watch the video, but I did read a number of posts here.
This is a professional frame. Regardless of wrinkles or voids, it was designed to be ridden by a pro in races and not to be ridden by a person who wants it to last forever. And this is exactly what I tell customers. If you want uber light pro stuff, it's like a racing engine (light components to go fast, not to last forever). It's designed to be ridden hard for a short period of time. If you are gentle, you can get many years of riding pleasure out of it...same with wheels and the groupset. What you saw on the inside really does not matter.
I do not think any of us have seen a BMC frame fail in a race, or heard about such occurring. But understand, you go through a lot of stuff as a professional. You guys want stuff to last. I tell this to customers, and suggest if longevity is their goal buy something less expensive that will last. Add a few grams and add fun. Save money.
My point is when people understand the goal is not longevity (lifetime warranty...yours or the frame's?...and your usage of such) then all this becomes a bit less important. If BMC loses a frame or it gets too flexy for a pro rider they get another one.
Again...this is something I explain to a customer if they are looking at a pro bike.
Your mileage may vary.
It's all about priorities.
#110
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1244 Post(s)
Liked 1,272 Times
But I later found out that this discrepancy had more to do with European liability laws than the manufacturer's confidence in their product. At that time (and perhaps still?) no European frame manufacturer offered a >5 year warranty.
Likes For Bob Ross:
#111
Quoted: 4339 Post(s)
Liked 1,526 Times
Framing it like that you wrote the conclusion too. We know that driving around with only three of five wheel lugs installed is dangerous. Do we know that a sloppy inside to a frame is dangerous? Do we know it makes the safety margin smaller? This thread is full of dire analogies and impressive credentials, but no "a sloppy inside makes the frame unsafe to ride". Note I said "unsafe" not "has less of a safety margin than otherwise, meaning it would only take an abusive 400lb rider to destroy it instead of an abusive 500lb rider".
Without resorting to analogy or declaration, does anyone know that that frame was unsafe to ride? I'm not asking for speculation that it might have been more likely than a different bike to fail under arbitrary abuse; was it dangerous to ride? BMC sold a lot of bikes and I haven't heard horror stories about them failing any more than any other brand, so I'm inclined to believe they're fine.
The statistics of failure rates are pretty immaterial if you are in the hospital after your seat sheared on hard bump. Quality control is not an engineering variable that can be controlled for other than by paying insurance premiums.
#112
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
A few comments, even though this is deep into the thread.
- The BMC frame looks significantly worse inside than a Cannondale frame and a Giant Defy I saw in person. The section where the top tube and head tube join looks like my 1st grader built it.
- I have 0 idea if the inside at all affects performance or reliability. If it doesnt, then it just isnt important.
- The fact that other frames are able to be much cleaner inside shows its possible and if the bikes cost comparable amounts, then comparable quality is expected.
- I find it deliciously ironic that the OP has made unsubstantiated claims about quality and declared unknowns to be known at various points in the thread, all while hedging that he hasnt.
Carry on with the Engineering speak.
#115
Liked 1,526 Times
I don't see how you could produce those kinds of internal voids consistently. Can you? That one area looks like a sectioned snail shell.
#116
Thread Killer
Quoted: 3129 Post(s)
Liked 1,697 Times
The guy in the video has probably a dozen frame cut-up videos. Go watch 'em. You can clearly the see the differences in production quality...well, some of you won't know you're seeing differences in production quality (some of you have no idea what quality even is), but that's what it looks like.
If a carbon fiber expert cutting up a variety of frames in the same way from different manufacturers and explaining to you what you're seeing doesn't substantiate the notion of production quality differences, then you really have a problem with understanding. If your only critique of his process and findings is that you've never heard of the guy, that really says more about your shortcomings than his.
As a favor to everyone in this thread, I'm offering custom bike paint jobs at a real great price. Just send me your bare frame and I'll paint it for $100. Any Krylon color you want! It's gonna look like crap, but it'll be to spec, i.e. covered in paint, so real high quality. I probably won't miss a spot, I promise!
#117
I'm willing to learn. I don't know how many miles that bike has on it. I don't know if it's been in a crash. I don't know if the void was there when it came from the factory or developed later. I don't know if the wrinkles matter. I don't know if the inconsistent wall thicknesses are by design, or if they matter.
If someone can answer those questions then I will know if this video means anything. Until then I remain skeptical.
#118
Liked 1,526 Times
Lowering QC is not like increasing a tolerance - you aren't settling on a known decrease in layup compression, for instance. You are settling for an increase in random flaws of unknown impact.
So you can control your level of QC in terms of increasing it, but you can't control how lower quality manifests in the product.
Another way of looking at this: If you can't control every process, you can't have expectations of quality for those uncontrolled processes. Not having any expectations, you can just buy insurance and hope the number of failures is low enough to not affect your bottom line.
To my eyes, the seat cluster looks like the tooling design does not effectively match the frame design, and the layup ends up a random mess of unconnected layers.
#121
Bikes: TST, Anvil, Eisentraut
Quoted: 8 Post(s)
The workmanship I was talking about in my post above. I used to be a laminator making very light off-shore racing sailboats. We did such good work that we used almost no sand paper and no power tools to clean up our work. (The final layup got one hand swipe of 36 grit sandpaper to get the tiny glass hairs that if not sanded, become very sharp splinters after the final paint. The edges of each layer were left entirely visible and got two swipes. We took real pride in doing good work that always be visible.
Rather unrelated except not entirely - I go to see a TiCycles steel fork that had been cut up for a forensics study. So I got to see the braze at the top of the fork crown at the fork blade end. The braze had a perfect radius like it was machined except that until the blade was sawn in half, tools and human eyes had never seen it. (And the finish was matte; ie raw braze, not a polished machined surface.) My point? High quality and good looking work can be done in places that can not be seen but it does take skill and care.
If I am going to trust my life to a two pound frame of plastic as I go 50 mph down a mountain road, I want work that looks like it is up to the job. Yes, I know well from my fiberglass experience that you can do good looking work with fatal flaws but on the poor quality work, you cannot even look for those flaws.
Ben
Ben
#122
Thread Killer
Liked 1,697 Times
And you're not understanding what I mean:
#123
Quoted: 18883 Post(s)
Liked 10,646 Times
#124
Quoted: 4790 Post(s)
Liked 3,916 Times
[QUOTE=95RPM;20051467]What kind of forks do you use? What do you trust? It is hard to find a good metal fork, and carbon forks have that same trust issue as the frame.[/QUOTE
Steel. Two 531, two unknown (but probably 531) and a mid-range ~'83 Trek. Trek has a good record with steel forks, three of my 531 or maybe are custom and the last is a 531 Raleigh. I did not trust the workmanship on the Raleigh so I had the paint stripped and inspected carefully by a good frame builder.
Steel forks may not be sitting in every shop but in the US there must be several hundred framebuilders who can crank out exactly what you want for not much more than a high end carbon fork. (And you get to choose the type, crown, geometry, braze-ons and paint or chrome. And it will be compatible with your favorite headset. Threadless or quill. Any carbon forks offer so many choices?
I will never own a carbon fork. I've had a non-steel fork do the sudden/no warning fail and it cost me a lot. Knowingly chancing that again when I have a choice? Nah. (And carbon steerers? Wrong material for the job. Yes it is strong enough in ideal conditions and much lighter. But in the real world, stuff happens. Makes no sense to me to not use a material as perfect and idiot proof reliable as steel. (Though I would consider titanium as part of a well made and engineered titanium fork. I loved the ride and feel of the aluminum fork that cost me so much. I think the right titanium fork could get close to that feel and keep the reliability of steel.
Ben
Ben
#125
Quoted: 600 Post(s)
Liked 778 Times
It rides great. Im pretty sure it will not last longer then my columbus frames from the 80s but its the best short term for riding fast. I will be sad when it cracks from an accident that would only scratch paint on a metal frame.
