Shimano OT SP41 VS. SP41 Housing
All Ass No Gas
Location: Azusa, Ca "Everything from A to Z in the U.S.A."
Bikes: 1988 Peugeot St. Laurent, 1974 UO18 Peugeot, 1985 P16 Peugeot, Roadmaster Ground Assult Mtn. Sport, Schwinn Traveler, 1986 Iseran Peugeot, Junet Mixte
Quoted: 50 Post(s)
Working on front derailleur need to install new housing. I looked up specs and figured out I need SP41 ok......can not find anywhere at a reasonable price. Can I use the OT SP41? From what I understand the only difference is the silicone lube already in the OT version.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You can use whatever shift housing you want. SRAM, Jagwire, Shimano...doesn't matter.
Likes For Kabuto:
Quoted: 114 Post(s)
Liked 119 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
I do the same thing for either Shimano or Jagwire housing. Having a long roll allows you to cut the exact length needed for each housing run and encourages you to change the housing as needed and not try to get "one more season" out of the old stuff.
Likes For HillRider:
Liked 1,096 Times
