Best all around tire?
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
No...but, at 15mm internal width, less than a decade ago, most tire companies advised against going any wider than 32mm. Depending on how low he runs the tire pressure, he could run into potential for significant sidewall deformation when turning, which would in turn lead to a some squirrely handling.
Likes For Badger6:
Quoted: 532 Post(s)
Liked 621 Times
Did a 100k gravel race yesterday on the 42mm Pathfinder Pros, they performed fantastically. Also noticed that most of the front pack I was with were riding Pathfinders, they were all on the 38s. We were pacelining on the pavement at 28-30mph, and no one had grip issues on the gravel, it was pretty loose and dry and we were hitting it hard.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
I love the Donnelly Strada USH in the 32 size. Great on hardpack, loose whether wet or dry, and fast. Great all around tire in my opinion. There are lots of great options in fast gravel tires.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I concur. The center tread ridge on the Nano 40s makes them feel pretty "fast" on pavement IMHO. I have them on my 700c bike and ride plenty of dirt and I'm impressed with how well they hook up (in my case, mostly dry, loose over hardpack, rocky--not too much mud here).
Quoted: 532 Post(s)
Liked 621 Times
thank you. I decided to just sell them. And already did. I was not sure if I would end up using them. Reading all of you, it seems like if I ever upgrade, it will be to Pathfinder Pros. For now, Pathfinder Sports are perfect for the job. My riding is 50/50 city/gravel and dirt paths.
I have a Jamis Renegade Expert with 38c Panaracer Gravel King SK tires on it. I ride both on the road and on trails... maybe 70% road 30% trails. The tires are great on dirt/muddy trails, but sluggish on the road.
If you are mainly on the road and want to be fest there, I’d go with the Pathfinder Pro2Blis for example or the Conti Terra Speed. And just accept not rivalling an MTB off-road.
I’m looking for something that rolls faster on the road but can also handle some mud, dirt, and gravel. Should I be using a slick tire? A thinner tire? I’m interested in the Gravel King slicks, or some of the slick Rene Herse options, but I’m not sure what my best option is.
Anyone have any input? Thanks.
Well yes and no, Knobbly tires on smooth wet asphalt are not just sluggish - can get you wiped out while cornering at speed.
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Likes For Rolla:
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
I ride roughly the same ratio of gravel/pavement as you, and really like the Rene Herse Barlow Pass. This is on the one bike that I do all of my paved and unpaved road riding on. Yes, it does struggle in mud, but in the grand scheme of things, that is a tiny fraction of the miles I put in, and I just go slower there, or just go around it. I guess it comes down to how much of the time you are actually needing to ride in mud.
I have considered one of the RH knobbies for a more gravel/light trail use.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I've read good things about and have on order the 650b x 45 Challenge Gravel Grinder. I'll report back after some use.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Quoted: 1975 Post(s)
Liked 232 Times
The Pathfinder looks pretty similar to the clement ush/mso hybrid. Anyone compare the directly? I've had good experience with msos and even raced dry cross courses on them
Quoted: 83 Post(s)
Liked 64 Times
I’ve been riding 38mm Graveling SS (non-plus) for a few weeks including backcountry & gravel touring. They’re quick on pavement and were fine even on stuff like this and a dozen rocky water crossings. On 25mm interior rims they measure 41mm. I was concerned about durability on the rocks but they were fine. I’ve used several tires mentioned above and these are my new favorites.
Likes For veloz:
