Suntour Superbe Pro RD cable clamp bore hole stripped
Quoted: 236 Post(s)
Liked 171 Times
Anyone ever see the bore hole for the cable clamp bolt strip? Kinda surprised given this groups reputation. Can it be fixed?:
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
Tap
Tap it for a larger diameter bolt
Barry
Barry
Likes For Barry2:
Quoted: 4201 Post(s)
Liked 3,857 Times
Or try a button headed bolt inserted from the back side so the threaded portion sticks out. Use a nut, and the clamping washer as usual. Andy
AndrewRStewart
AndrewRStewart
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
You might be able to salvage a button bolt from a donor derailleur along with the nut and clamping washer.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Quoted: 836 Post(s)
Liked 1,061 Times
SE Wis
Liked 3,390 Times
This,^^^ which is perfect for your situation. Or if you don't want to spend $15 for five of them you could make your own with a drilled out and tapped stainless set screw for under $1 that is of course if you already own the tools which you would still need for the EZ lock threadserts. I say use a set screw as it already has an allen head to use as the center guide for drilling out the screw You could use any stainless bolt though.
Likes For dedhed:
Quoted: 836 Post(s)
Liked 1,061 Times
Liked 3,857 Times
Having done a few thread insert type repairs I'll say that this one's not the best to try. The amount of threads that the der's anchor bolt fitting will engage the insert is rather lacking. The insert's pitch at 1.25mm/t makes for only a very few threads of overlap. Expanding holes for over sized threads or inserts is not attempt 1 in my book in this case. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1303 Post(s)
Liked 1,910 Times
I tap the hole out to a 6 X 1.0 mm thread and use a stainless button head screw available at my local hardware store. You may have to ream the fixing plate out a bit but the repair is as good as the original bolt. Just my $.02 worth on the subject. Smiles, MH (The same repair I do for Campy record FD's that have stripped.)
SE Wis
Liked 3,390 Times
You'd think a rivnut could also be used here.
https://www.amazon.com/Flat-Aluminum.../dp/B00NGK6UBY
