Recommended tire pressures
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
After looking for a set of tires for my DX5000. I had a buddy that had a couple low mileage gatorskins he took off his bike and
sold them to me for $38 for the pair.I was hesitant because I have 2 other bikes that have gatorskins on them and
they ride pretty harsh. The one I have now are 700X25 and the ones he sold me are 700X28 so I figure these will
be a little softer and for $38 I can't lose .Now I'm wondering what tire pressure do you think I should run them at?
They are mounted on Araya 700C rims which are 20mm wide. I am 185 lbs and the bike weighs in the neighborhood or 22 lbs
Quoted: 3807 Post(s)
Liked 6,676 Times
Quoted: 677 Post(s)
Liked 459 Times
I weigh 195 and run my 700x30c Grand Bois Cypreses at 70 and 80 and have had zero problems. IMO (and IME), most people put far too much air in their tires.
mycocyclist
Quoted: 910 Post(s)
Liked 812 Times
Quoted: 767 Post(s)
Liked 1,898 Times
I see a pressure rating of 116 psi on their website for 700cx28. You could try them fully inflated and then adjust down to see if you have a preference for a certain pressure. The rating should be molded into the sidewall.
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
I used to ride 28mm Gatorskins on my Surly Cross Check as a commuter. I weigh 160-165 and I never put more than 80 psi in either tire. It was usually 70 F, 80 R. I moved on from them seeking an easier ride and I'm glad I did.
If you put 116 psi in those you will fuse every bone in your body together.
Okay, maybe a bit hyperbolic, but see what you like. If the Gator's don't cut it, try the Grand Prix 4 Seasons. They're the bee's knees!
Likes For bargo68:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3880 Post(s)
Liked 6,468 Times
Required road pressure is directly related to total weight and inversely related to tire width.
Quoted: 1856 Post(s)
Liked 664 Times
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
I follow this tip of the day - which turns out to be 84 psi front and 93 psi rear. Yours will differ due to weight. My tire width is 25.
Liked 6,676 Times
If I can’t feel every micron of gravel in the road, my tires are too soft.
Likes For P!N20:
Likes For BFisher:
Quoted: 1372 Post(s)
Liked 1,751 Times
For someone the OP's weight, closer to min pressure should be OK, providing that he or she rides light. Riding light means taking it easy over harsh roads, bumps or cracks in the road. At close to 200 pounds, myself, I used to go max rated pressure on a given tire. I used to opt for skinny but these days prefer the ride quality of 28mm or even greater. I went from 28mm to 32mm on my Jamaica ride and there will be no turning back for me. Go wide and ride more is now, sort of, my moto.
The wider tire and lower pressure means a bit slower for me, but the ride quality is so much better that I do not mind a bit more of a work out as I enjoy the ride.
Likes For randyjawa:
Quoted: 1559 Post(s)
Liked 1,733 Times
I have a quarrel with the calculator which uses the static weight over each wheel to determine the recommended tire pressure. When the bicycle is rolling forward, the front tire needs higher pressure. The reason is that the front tire hits a bump, the full weight of the bike and rider are behind it. The front tire in effect crashes into the bump. By the time the rear tire hits the bump, most of the weight of the bike and rider are already ahead of the bump. So in effect the rear tire is just dragged over the bump.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
Lighter pressures and as others have said, “ride light”. I have a mental block convincing myself that 60 front an 65 rear is probably fine on my 32s and 165-170 weight. I just go 65 front and 70 rear and call in good on 28-32 and plus or minus 5 on the 25s and 35s. As a youngster I put 85 in the Kendas and Schwinn approved tires and it seemed faster in my mind. 32s and 35s at 70 or less make me happy now.
Quoted: 590 Post(s)
Liked 445 Times
I'm the same weight as the OP and run my Conti Grand Prix 4-Seasons 700x28's at 80/84psi
If that doesn’t do it, ask someone who rides stoker on a tandem. That rear wheel hits bumps pretty hard, even though it has 2 riders in front of it.
Likes For jon c.:
Liked 6,676 Times
In the 70s we also wore bell bottoms.
Likes For nlerner:
Quoted: 1946 Post(s)
Liked 2,008 Times
Most pinch flats could have been avoided if there was more air in the tires. My 22-23s have 110 pounds in them. 85-90 in 28s should be good.
Quoted: 288 Post(s)
Liked 329 Times
I’ve been using the Berto chart (and other info from this Rene Herse page) for awhile. I think the pressures may be a bit low compared to other recommendations, but they work for me.
