Fuji 1981 S-12 Triple - Spindle length?
Quoted: 5 Post(s)
Does anyone know what the length of the bottom bracket spindle that came in a Fuji 1981 S-12 with a triple chainset?
Thanks.
Thanks.
Quoted: 3803 Post(s)
Liked 3,324 Times
might help readers to help you if you could post image of cycle and or chainset
did a check just now and could find no 1981 Fuji catalogues
the classic fuji web site is down/gone
Quoted: 5 Post(s)
Well I can't post any picture or links just yet since I am still new. I bought the chainset off ebay recently. I asked the seller if he remembered the length of the spindle. He said the bike had been apart for quite a while now. The spindle was pitted thrown away. He thinks it was perhaps around 122mm or 127mm judging by the sunken interface of the drive side crank. So he didn't have an exact answer.
Liked 3,324 Times
you can upload images right away without waiting to make ten posts
there is at your member page here on the forum a place where you can create a photo album
you can upload images there without a minimum post requirement
visitors to you page can put the images into the discussion thread
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Classic Fuji site here: https://classicfuji.posthaven.com/
1981 S12 Triple
Sugino Super Maxy 2D
Starting point at least
1981 S12 Triple
Likes For AJI125:
Quoted: 5 Post(s)
Ok, I was able to create an album in my account area and added the pictures of the crankset to it. I called the album "Fuji S12 1981 Triple Crankset".
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Sheldon Brown’s classic bottom bracket guide: https://www.sheldonbrown.com/bbsize.html
I would start with a 127mm, see how you like the clearances, and go from there. It doesn’t cost a lot to buy a handful of sizes to have on hand so that you can easily check these things. I use any “official” bottom bracket specs as a starting point and usually end up going shorter.
Likes For ThermionicScott:
Liked 3,324 Times
thanks very much @AJI125
site was not working when attempted visitation - perhaps a browser issue
pic assist -
the stock bottom bracket assembly here is a "Type II" or nutted spindle design
according to Sutherland workable spindles would be model 3T, or if you would like slightly more clearance, model 3U
i would suggest going with the 3U
pic assist -
Quoted: 5 Post(s)
Thanks, for identifying the assembly. My copy of Southerland is packed somewhere.
So looking online I see in JIS and Clone Spindles for Triple, that the spindle length for a 3T is 126mm. And the spindle length for a 3U is 124.5mm.
Liked 3,324 Times
the copy of Howard here lists the model 3U at 127.5mm in length
Quoted: 151 Post(s)
Liked 303 Times
Likes For AJI125:
Liked 2,563 Times
I see that's a 110mm BCD crank, with all three rings sharing the same bolts. If you wished, you could easily rebuild it as a compact double, which would make sourcing bottom brackets easier.
Quoted: 5 Post(s)
The * noted that conflicting manufacturer’s specification, use either 32 or 35mm left end width. So I guess that’s the 3mm difference. The important measure is the right end width which is 40.5mm. All of the center measurement for the Sugino spindles is 52mm.
I think someone mentioned Sheldons site already, but note the 3T and 3U are both offset to drive side, so the symmetrical equivalent (if buying most modern options) would probably be longer to get the DS far enough outboard. https://www.sheldonbrown.com/bbsize.html
How would setting it up as a double make sourcing bottom brackets easier?
Liked 2,563 Times
Mainly I wanted to put the idea out there since the OP's crank is limited to a 34T smallest ring anyway.
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
Here's an old photo of my S-12S. If I can unearth it, I'll try to pop the crank caps and get you a measurement.
Last night I tried to do it with the cranks in place, but my calipers won't clear the large chainring and insert into the openings on both sides to get an accurate value. I'll have to get it up on a stand and pull the chainring side off to get you numbers that have any validity. I'm about to send my kid off to college (freshmen), and all hell has broken loose in this household! It may take me a few days to be able to help you.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
Not to hijack the thread, but at my local co-op in Toledo Ohio there is a super clean S12S double for sale. Newer panaracers on in and looks like the 23” size. If anyone is nearby, it is $225. I know this bike is desirable for a 650b build, so I would graciously take those 27” panaracers .
Quoted: 5 Post(s)
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 691 Times
As an extra data point (Fuji-branded double crankset, so not quite what you're looking for), but my S-12 has the original Sugino BB with spindle length of 120mm. Drive side is 35mm and NDS is 30mm, as measured from the outboard ridge on each spindle race.
Quoted: 5 Post(s)
I saw this in a Sugino 1978 catalog a few days ago. I will have to post the diagram when I am able.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I'd start with the 124.5mm spindle, asymmetric with the drive side 3mm longer.
Quoted: 5 Post(s)
Here is that Super Maxy info from a 78 Sugino catalog I found online. The NJX-2d is the type for the Sugino Fuji from the S-12. And it does seem to use a 124.5mm spindle for the triple. And 120mm for the double.
Likes For Bytesurfer:
