Impact of Tire Quality on Ride Comfort
My wife has terrible hands, truly. She's already had carpal tunnel surgery on both. I'm attempting a whole suite of interventions in order to make her comfortable on the road bike that she loves. To that end, I would like to replace her 25c tires with 28c tires, the maximum that I believe will fit her frame. I would exploit the larger tires from a comfort perspective by running them at a lower air pressure of course.
My question is this: what effect does tire quality have on ride comfort? Are there certain tires that should be avoided or sought when one wishes to optimize comfort?
Please keep in mind that comfort is the only parameter that matters with respect to my tire choice in this situation. My wife is very much a recreational rider so things like high speed handling, wet weather performance, and rolling resistance are of little importance. Even puncture resistance isn't a big deal.
The bike in question currently has the Schwalbe Lugano 25C that came stock with the bike. Presently, I could purchase a pair of Schwalbe Lugano 28C for $16 each plus shipping. That would make for a pretty cost effective "larger tire" experiment. That said, I would like to avoid a future where I find out that we didn't really give larger tires a shot in earnest because we chose cheap tires.
Thank you, all, for your assistance.
Expired Member
Quoted: 3635 Post(s)
Liked 5,311 Times
The GravelKing slick is the most comfortable 28mm tire I've tried. Noticeably smoother than GP5000 28s I have on another bike.
Likes For shelbyfv:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'd go with the fattest tires that will fit. Measure the gaps around the tire at the chain stays and fork crown and guestimate how fat you can go.
Also consider raising the handlebars.
Likes For Flatforkcrown:
Thanks for your input. Both of those exercises have already been undertaken, along with numerous others. For the purpose of this thread, I'm interested in nothing other than the relationship between tire quality and comfort.
My budget is, effectively, unlimited so long as I could realistically expect the cash outlay to provide a meaningful comfort improvement. If my wife wouldn't notice the difference between the $16 Luganos and a $200 tire, I'd certainly want the Lugnos.
Also, tire inflation is really the biggest factor here. Going wider doesn't make things more comfortable by itself, it allows the tires to be pumped squishier while still behaving well. Here's a calculator for establishing a reasonable starting point on inflation pressure:
https://info.silca.cc/silca-professi...ure-calculator
If she's not already running her tires problematically low, she could try reducing inflation pressure and seeing to what degree that helps with comfort. Some hand comfort issues are caused by excessive inflation pressures, but many are more an issue of fit.
Likes For HTupolev:
Sunshine
Quoted: 10897 Post(s)
Liked 7,384 Times
A higher quality wider tire will feel even better than either of the above.
Tire width trumps tire quality when it comes to comfort. A cheap 2" MTB tire will provide more cushion/comfort compared to a high quality 23mm road tire.
Veteran, Pacifist
Quoted: 3874 Post(s)
Liked 4,779 Times
Unlimited budget?
Get her a bike that takes 32/35s, the expensive ones.
edit: Let her choose a new bike for fatter tires, easier to brake. Even e-powered.
Likes For Wildwood:
Liked 2,011 Times
Thin wall tires (e.g. Rene Herse) tend to remove all the little bumps and vibrations more so than thicker wall tires, and bigger bump smoothing mostly comes down to tire volume. To me, the thin-wall small bump smoothing is a relatively minor increase in comfort, but it might be significant to someone with CTS.
Likes For Harold74:
One of the interventions currently in play is a Redshift Shockstopper stem. I suspect that dampening will overshadow some of the other possible interventions but it's difficult to know with certainty how that will play out. I definitely want to exploit anything that one might consider low hanging fruit which is why I'm exploring larger tires and lower air pressure. If the "bang for buck" on thin wall tires in this combination would be minimal, than I may leave that option on the table for now. The Luganos are not high end tires but, at the same time, they are slicks with only nominal puncture guard. It's not like they are Schwalbe Marathon's or anything.
In some reviews of the Redshift Shockstopper stems, folks expressed their opinions that the system worked but expectations should be modest, on par with the switch from a 25c tire to a 28c tire. If it makes sense to do so, I seek stack the benefits of the stem combined with a larger tire.
Veteran, Pacifist
Liked 4,779 Times
My smoothest riding tires at @ 28mm are VeloFlex and Vittoria tubulars. Conti 5000s at 25mm ride like Gatorskins compared to the 320tpi casings from other manufacturers.
Bikes: N+1
Quoted: 94 Post(s)
Liked 417 Times
https://www.probikekit.com/bicycle-t.../12344796.html
Get her these. I have the tubular version and they are the best riding tires I’ve had.
Expired Member
Liked 5,311 Times
I haven't tried the Rene Herse in 28 but I recently had some extra light 35s and the ride was astonishingly smooth. They were too flat prone for me but definitely the nicest ride I've experienced. If budget is truly irrelevant (about $90 each) and you don't mind a flat every few hundred miles, might be an option.
I’m a little Surly
Quoted: 698 Post(s)
Liked 1,292 Times
Tires and saddle have the largest effect on ride comfort
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2512 Post(s)
Liked 5,423 Times
If she doesn’t have tiny hands, you also might want to consider double wrapping her bar tape too.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 418 Post(s)
Liked 689 Times
Recently purchased Michelin Pro4 Service Course tires, don't have a lot of miles on them yet, but so far I'm very happy with them. Seem to isolate me from bumps in the pavement. Note though, if considering, my old tires were 700 x 25, so ordered the same size. The Michelins are a little larger than spec'd. The 25s measure 27, but I had clearance and like that they are a little larger.
Ordered them here, don't know if other sites might have them for less $$: Michelin Pro4 Service Course Tire at BikeTiresDirect
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1346 Post(s)
Liked 1,235 Times
Fred "The Real Fred"
Zircon Encrusted Tweezers
Quoted: 260 Post(s)
Liked 127 Times
IME, the effect you are asking about is real and perceptable, but still fairly subtle. I tend to doubt it will make an important difference for someone with CTS.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Higher quality tires give handling characteristics, like liveliness, that don't really translate into comfort at all. And usually only more seasoned riders can experience the difference.
Likes For Phil_gretz:
Quoted: 1935 Post(s)
Liked 2,148 Times
If your wife is hurting as bad as you indicate, and she loves to ride, I think you are just chasing the wind with a 25mm to 28mm tire change as your solution.
Both Fox and Rockshox have come out with low travel suspension forks for gravel bikes. I don’t know much about them, but that is where I would put my effort.
John
John
Likes For 70sSanO:
