Replacing Nuvinci gear hub with derailleur?
Quoted: 573 Post(s)
Liked 118 Times
Hello,
I'd like to remove the Harmony + Nuvinci N330 on a cargo trike with disk brakes front+rear, and replace it with a plain 3-8 speed derailleur.
I've never done this before.
1. Does any derailleur fit that kind of drop-outs on the frame?
2. Its handlebar is the basic "single bar" model. Are "revoshift" shifters available for all derailleurs? If not, can I use some extra contraption to install it?
Thank you.
Thank you.
Quoted: 581 Post(s)
Liked 921 Times
First, what is the dropout spacing (Over Locknut Dimension - OLD)? Aluminium frames don't like to be bent to match the hub so you need to find a hub that matches the frame. Most disk-brake compatible hubs with axles that will fit that bike have an OLD of 135mm. If that's the spacing of your frame then you just need a wheel with that size of hub.
Second, you need to find a 'claw' style derailleur hanger, or a derailleur with a built in derailleur hanger, which are often the inexpensive style.
You also need a front derailleur and triple crankset, although there are frame designs where mounting these might not be straightforward.
I don't know about 'Revoshift' in particular, but you can definitely get 'gripshifters' to match your drivetrain. Sram makes those.
Quoted: 573 Post(s)
Liked 118 Times
It's 135mm.
There's no need for a front derailleur since it has a Bafang mid-drive.
I'll read up on those types of derailleurs and shifters.
Thank you.
Thank you.
Quoted: 2337 Post(s)
Liked 2,813 Times
out of curiosity/education what is the driving motivation for this change?
Likes For squirtdad:
Quoted: 573 Post(s)
Liked 118 Times
The cranks get stuck when the user rides uphill. Turning the motor off and on doesn't solve the problem. Enviolo says the N330 isn't a good choice for use "with a powerful motor" (it's just a 250W Bafang Max Drive).
So we'lll just remove that thingie and see it solves the problem.
Likes For Winfried:
Liked 2,813 Times
good luck what size rear wheel?
and here is good write up on derailer hangers https://www.redclovercomponents.com/blog/1
