no display
no display
Hello
A year ago I fitted a Bafang rear wheel motor to my Fuji MT. the installation went well and I have enjoyed my bike. However, recently I am not getting any response with my 850C display. I checked all the connections three times and still no response. I think the problem may be with the display or the controller. Hopefully no more than that. How can I check these items: controller and display. Or do you have other suggestions. The battery is fully charged and I get full 52 volts when checked after the battery at the first lead. How can I check voltage down the line at every connection? Thank you for your attention. Ron
Quoted: 2026 Post(s)
Liked 1,096 Times
There are two forums here:
Electric Bikes
Electronics, gadgets, etc
Either is more likely to get you proper help.
Electric Bikes
Quoted: 18373 Post(s)
Liked 4,507 Times
Hmmm, was it dropped?
Do you still get power assist without the display working?
It looks like the display is supposed to have a USB output port. Can you get power out, such as charging a phone?
https://custombuilt-ebikes.co.uk/wp-...ser_Manual.pdf
It looks like the displays aren't hugely expensive. About $85 or so. I don't know about the controller. I'd probably take it apart and see if I see anything out of place. Check various connectors. Check any capacitors to see if they look flat on top. Also, does it have some kind of internal battery?
Quoted: 836 Post(s)
Liked 1,061 Times
Try shooting Bafang an email. Maybe covered under warranty or they might have a suggestion to troubleshoot/fix the problem. BAFANG | After Sales Support | (bafang-e.com)
