700 x 48-50 slick/semi-slick road/gravel
Old 04-25-22, 08:49 PM
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
Was looking at tires in this size range to replace my Panaracer Gravelking SK 50. I have a second set of wheels with Rene Herse Fleecer Ridge for more off-road/rough road. Wanna stay in the 48-50mm range. No wider or narrower.
I’m thinking the Hatcher Pass Tubeless might be the best in class for this size for primarily road and light gravel/dirt. I tried the G-One Speed tires years ago and they were honestly not that great for a slick tire. Other than those two I struggled to find a more road oriented tire in that size range.
If anyone has any other thoughts or suggestions I’d greatly appreciate it.
DarKris is offline
Old 04-26-22, 05:46 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
Schwalbe is probably your best bet, although most of them are cruiser type tires. I thought the fat S-one was amazing when it came out (well ahead of its time) - curious as to what you didn't like about it?
chas58 is offline
Old 04-26-22, 05:57 AM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
I ran them on a ~ 20 mi. Group ride a few years back and they felt super draggy the entire ride. When I looked into it, turns out the g-one speed had way more rolling resistance compared to similar or mor knobby tires
DarKris is offline
Old 04-26-22, 07:41 AM
chas58
chas58's Avatar
Odd. I'd consider giving them another try if you wanted an alternative. They fell super fast to me (I'm using the 60mm version). They have always been way below everything in rolling resistance on BRR web site for about 6 years now.
Here is a custom graph comparing it to the fastest MTB tires tested. They are the line at the bottom of the graph with the super low rolling resistance. Back in the day the original version of the G-one Speed was called "big one"
chas58 is offline
Old 04-26-22, 07:56 AM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
The big one uses a different rubber compound and casing which has been attributed to the lower rolling resistance . New ones are significantly slower and my experience reinforced that for me
DarKris is offline
Old 04-26-22, 07:57 AM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
DarKris is offline
Old 04-26-22, 10:21 AM
chas58
chas58's Avatar
That bites. But apparently your comment applies to the whole G-One range. Those tires were the one's to beat when they came out (I loved them), but something went sideways with the latest generation.
chas58 is offline
Old 04-26-22, 04:45 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 90 Times in 74 Posts
Soma Supple Vitesse SL 48mm will be the second fastest to the ReneHerse 48mm.
The 48mm is tubeless compatible.
tangerineowl is offline
Likes For tangerineowl:
Old 05-02-22, 07:27 AM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
This was a great find! Ordered them in Terracotta. Thanks!
DarKris is offline
Old 05-02-22, 09:09 PM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
My tires came today. Significantly less of a cost compared to the RH tires and these are still a huge weight savings. Tires weight ~410g each which is ~160g less than the Gravelking SKs I had.
Now I have a dedicated road wheelset and gravel/trail wheelset
DarKris is offline
Likes For DarKris:
Old 05-03-22, 03:06 PM
tangerineowl
Quoted: 257 Post(s)
DarKris,
If you have calipers, would you be able to measure the tyre width on your 25mmInner rim?
I've been considering these for a while, but don't want to have too tight a fit in my frame rear.
thanks
Old 05-03-22, 03:24 PM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
DarKris,
thanks
i measured 48.5 mm when I mounted them at 45 psi. I don’t see it stretching past 50 mm long term.
The tread is stiff and has a very rounded profile. That probably won’t stretch too much either
DarKris is offline
Likes For DarKris:
Old 05-03-22, 04:02 PM
Fletch1969
The Conti Urban Contacts have had some very good reviews. Not sure on grip levels but as semi slick seem to be a good choice. Fast rolling, decent puncture protection and not too heavy
Fletch1969 is offline
Old 05-04-22, 07:09 AM
chas58
chas58's Avatar
Conti just announced these (just for you! ;-)
https://www.bikeradar.com/news/conti...erra-hardpack/
45mm Terra Speed if you want a lighter, faster tire.
chas58 is offline
Old 05-13-22, 06:56 PM
tangerineowl
Quoted: 257 Post(s)
I'm sad Conti dropped the ball here, not going the 'Racesport' treatment on that 50mm variation of the 2.2inch Speedking
