Down tube shifters
Quoted: 3352 Post(s)
Liked 1,056 Times
Down tube shifters
What is the highest number of gears that that an indexed down tube shifter will handle?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Currently, 11.
It depends on the specific shifter's cable pull. I had suntour power ratchets (awesome) on a vintage frame into which I stuffed a 9 speed cassette. The shifters did not pull enough cable length to cover the entire cassette, which meant adjusting out either the top or bottom cog.
Later model DT shifters - anything circa post-freewheel - will cover up to 11.
Dia-compe and Rivendell make vintage style DT shifters with outstanding fit and finish, though for the price you could score Dura Ace.
Worth noting: Shimano DuraAce downtube shifters in the 10- and 11-speed flavors do not swap over to friction shifting, they are index shifting only.
Quoted: 569 Post(s)
Liked 581 Times
For me DT is limited by my skill level, 9 cogs. I just struggle with 10 and can not imagine trying 11.
Quoted: 443 Post(s)
Liked 27 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
Yep, a little comprehension deficiency, maybe.
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
Quoted: 59 Post(s)
14, a Rohloff grip shifter can also be mounted sticking out from the side of the Downtube.
not the most convenient location , but it is an option. .. just takes a 22.2-7/8" tube being added..
by the same method a NuVinci CVR hub has an infinite number of "speeds" with in its range of ratios..
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
I'm looking for a socket wrench and you want to tell me the value of a hand wrench. Don't think that I've forgotten about the hand wrench, but I've graduated to socket wrenches. Hope to see you guys in the Fall! Haha
However, a successful analogy would have been to use ratcheting and non ratcheting box wrenches.
All friction for front shifting as far as I know, no index option, will still work for double or triple front chainring setups.
I only mentioned the friction thing because in the past, DT and Bar End shifters were usually referenced in the same context as being simpler and less fragile than brake/shifter setups. Especially where touring is concerned, the ability to convert to friction shifting was seen as a benefit to such shifters, in the event of some emergency or if indexing got out of whack for some non-adjustable reason.
And so I commented about friction shifting, even though the OP specifically queried about index shifting. It might answer someone's unasked question, it's also a data point regarding the features of Shimano 10 and 11 speed DT indexing shifters being discussed here.
For those worrying about reading comprehension, I even prefaced the information I shared with "Worth noting:", a modifier very distinct from something more along the lines of, "Critical information regarding the OP!!!", or no modifier at all, which might imply that it directly answers the OP. Truly, said modifier could rather be read as, "Tangential but still somewhat pertinent to the OP" by those with any kind of nuanced reading comprehension, rather than the bludgeon of grammar/thread discipline Nazism displayed here.
