Headset damage from wet riding without fenders?
Old 07-12-16, 06:28 PM
ADAP7IVE
Bikes: Surly Disc Trucker, Blue "mamachari" 3-speed, Kona Explosif
Quoted: 71 Post(s)
I am just about to pull the trigger on a 'cross bike I like, for everyday commuting across terrain (roads of various upkeep, unpaved dirt roads) and variable weather (it rains very often where I live, and heavy rain from June to September--typhoon season). I just came across some articles about protecting bicycle parts with fenders, including the headset. Having ridden in relatively dry areas before now, I never considered this, and wonder how serious an issue it is. The bike I'm looking at has a carbon fork with no eyelets or mounts for a front fender, so clip-on/limited coverage ones seem my only option for front fenders.
Will wet riding without full-coverage fenders kill the headset parts noticeably quickly? I'd rather not get a bike that's not fit for purpose, even though in every other respect that I've thought of (there always seems to be something else) it seems good.
Here's the bike, for reference:
CXG Muddy Fox CX Gravel?ARAYA Bicycle Project
ADAP7IVE is offline
Old 07-12-16, 07:05 PM
2lo8
Quoted: 252 Post(s)
It's not that big of a deal with some sort of sealed bearings in the headset. If your headset has bad or no seals, it's probably cup and cone and it just means you need to rebuild it more often.
2lo8 is offline
Old 07-12-16, 07:17 PM
trailflow1
Quoted: 131 Post(s)
Liked 21 Times in 17 Posts
Not a serious issue no.
Pack it with grease and service it regularly.
Ignore magazine/internet articles.
or fit one of these lizard skin headset protectors from the 90's. Take it off and clean and dry it every so often
https://www.wiggle.co.uk/lizard-skins...eal-protector/
trailflow1 is offline
Old 07-12-16, 07:19 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1429 Post(s)
Liked 1,064 Times in 711 Posts
People have been riding bikes in the rain for a very long time and have managed to survive somehow; you will be fine.
dsbrantjr is offline
Old 07-12-16, 07:29 PM
ADAP7IVE
Quoted: 71 Post(s)
Thanks all for the help. I'll remember a bike is still a fairly simple tool with a loooong history, and the internet brings problems to the fore.
I also went digging for more information about the bike because the manufacturer site doesn't have great pictures (Japan doesn't know about web design), and found that there is a hole on the BACK of the fork for mounting fenders!
Sorry for the Japanese page, but there's a clear image of the hole there:
Bici Termini ??? **********??? 2015 ARAYA CXG **********????
ADAP7IVE is offline
Old 07-12-16, 07:33 PM
2lo8
Quoted: 252 Post(s)
But I like Japanese style 1998 no-nonsense web design.
2lo8 is offline
Old 07-12-16, 07:36 PM
79pmooney
79pmooney's Avatar
Quoted: 3855 Post(s)
Liked 2,720 Times in 1,776 Posts
You could put on one of those mini fenders that extend about 6" either side of the fork. Won't help you, but it will keep the headset a lot cleaner and drier. If you want to go the lizardskin route but cannot find them, cut an innertube to a ring and install it over the headset. If the headset is not sealed, repack at least the bottom bearing with the grease used in boat trailer hubs. (In the US, we call it marine grease and it is usually sky blue. Available at all auto parts stores and not very expensive.) Use lots. So much that it oozes out and makes a mess. Water and the grit in it cannot get past that grease if you use enough.
Ben
79pmooney is offline
Old 07-12-16, 07:38 PM
ADAP7IVE
Quoted: 71 Post(s)
LOL. Very efficient. It's the 2016 go-through-10-text-heavy-pages-to-complete-your-task ones that get difficult. Buying anything online that isn't Amazon is a slog. I can read Japanese, but I don't think I'll ever get used to the uniform size and tight spacing of Japanese print.
ADAP7IVE is offline
Old 07-12-16, 07:44 PM
ADAP7IVE
Quoted: 71 Post(s)
Ben
Thanks for the tip! I'll keep that in mind for all my bikes.
ADAP7IVE is offline
Old 07-12-16, 08:09 PM
dsbrantjr
dsbrantjr's Avatar
From Google Translate: "has dowel holes in consideration of the mounting of the fender is available."
Old 07-12-16, 08:29 PM
ADAP7IVE
Quoted: 71 Post(s)
Thanks. I can read it, but not sure how many others on the forum can. For anyone else who came to help, thanks! The problem of fender attachment is not actually a problem. The real problem was my own failure to go digging for more data before now.
ADAP7IVE is offline
Old 07-12-16, 11:44 PM
Sangetsu
Sangetsu's Avatar
Quoted: 565 Post(s)
Liked 23 Times in 14 Posts
I use fenders to keep myself dry, my bike doesn't care one way or the other. My oldest bike has been ridden in all kinds of weather for 18 years now with no fenders, no service, not even a re-lube, of the headset. I should get around to doing it, whenever I find the time.
Sangetsu is offline
Old 07-12-16, 11:53 PM
2lo8
Quoted: 252 Post(s)
I want to cycle in Nippon
2lo8 is offline
Old 07-13-16, 09:17 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,343 Times in 850 Posts
What Kind of head set?
Why get a fork inappropriate for the kind of rides you Plan?
BITD, we pulled the fork slipped a section of old inner tube over the lower bearing cup, then Put the fork Back in.
fietsbob is offline
Old 07-13-16, 09:25 AM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2357 Post(s)
Liked 29 Times in 25 Posts
The fit between that fork and that headset is excellent. Exposure is reduced to almost nothing. It will probably be problem-free for a long time.
SquidPuppet is offline
Old 07-13-16, 09:27 AM
GerryinHouston
Bikes: Novarra Randonee 2016, Trek Verve 2 2015
Quoted: 97 Post(s)
Planet Bike SpeedEz fenders, require no eyelets
GerryinHouston is offline
Old 07-13-16, 09:32 AM
corrado33
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Do you have ADD? ADHD perhaps? Such relevance to this thread. Good job.
OP: You'll be fine, stop worrying about it. If you're going to use the bike for commuting you're going to want fenders anyway, especially if it rains a lot. You wouldn't have problems even if you didn't use fenders. Go ride, have fun!
corrado33 is offline
Old 07-13-16, 09:34 AM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1174 Post(s)
Liked 115 Times in 81 Posts
Headset will be OK but the bottom bracket will have a significantly reduced life span.
Spoonrobot is offline
Old 07-13-16, 11:30 AM
fietsbob
Bikes: 8
If You take the wheel out and take a picture of the underside and back side of It maybe people can see .
Is there a hole thru the fork crown in either direction ?
fietsbob is offline
Old 07-13-16, 03:47 PM
readability
Wiggle | Lizard Skins Head Set Seal Protector | Frame Protectors
Or use a piece of inner tube
readability is offline
Old 07-13-16, 07:40 PM
jimc101
Quoted: 433 Post(s)
Liked 84 Times in 72 Posts
Why? it's got an Octalink BB, haven ridden a lot of distance with a few of these off & on road since the came out int he early '00, have never had any issues with them, have found Octalink BB's to just be a fit and forget product.
jimc101 is offline
tweekfreekdX
Commuting
78
10-04-19 11:49 AM
Narhay
Classic & Vintage
28
07-26-18 05:35 PM
coolkat
Bicycle Mechanics
1
11-03-13 04:27 PM
jowilson
Bicycle Mechanics
7
09-24-13 07:31 AM
trek330
Bicycle Mechanics
11
10-05-10 06:33 PM
