Mystery frame - supposedly a Woodrup.
Bikes: a Fully restored 52cm Italian build Benotto Modelo 850.
Quoted: 11 Post(s)
Hi to you all out there. Is there anyone out there that can help me identify a frame that I am considering purchasing.
It has been listed as A Woodrup and when I asked the frame number I was told it was TD 5313.
The lugs are not what I was expecting to see albeit they did not consistently use Nervex - the lugs are nice but rather plain and a little like the ones that used to be on my 1937 Hetchins 2 day Vibrant Track Frame.
Your help would be great-fully appreciated.
Quoted: 18354 Post(s)
Liked 4,502 Times
More photos would be nice, but outwardly, I don't think it has very great workmanship. The seat stay ends look quite plain. So, without seeing any stickers, I'm guessing basic High-Ten steel.
Quoted: 11 Post(s)
I have had difficulty in even getting basic information from the seller - he is not responding to my questions in good-time and seemingly only part answering them;so I am guessing the additional images would be a real problem.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
That would trip my trust limit switch. I'd pass. But if you've always wanted a Woodrup frame and this is the first you've seen in ten years or something, ... maybe.
Try the C&V forum.
Quoted: 11 Post(s)
The E'bay seller has 'allegedly' sold the frame after seemingly had it advertised 'Else Where'
I pointed out to him that the lug-work was not what I expected to see on a Woodrup frame and that the frame number would not otherwise have a Prefix of alphabetical letters.
Liked 4,502 Times
Is your "original" photo better resolution than the one here?
Is this a local purchase, or an internet purchase?
How much?
What are your intentions with the bike?
It appears as if Woodrup made a variety of frames.
The features that stand out to me include:
Of big concern... And, I wouldn't go out of my way before verifying.
How much?
- Rear dropouts appear to be pressed steel without a derailleur hanger. Usually found on low-end bikes.
- There also appears to be an odd cable stop, about 6" above the bottom bracket on the downtube. This also is a feature sometimes found on low-end bikes.
- Odd hole in fork? Certainly not a "racing bike", but perhaps designed for a generator or rack.
- Top of seat stays appear to be simply crimped, and brazed. It is hard to tell from the photo.
Many of the premier "English" frames had wrap-around seat stays. This isn't one of those. - This is a very small frame. Make sure it fits your intended purpose.
- Seat Clamp looks wacky. Probably due to a poor photo, but it is just hard to tell.
- It almost appears to have a hole where the brake bridge should be. It may also be a photo artifact, but it is odd.
- No chainstay bridge (not all bikes had them), but also an odd rust spot just behind where one should be.
Quoted: 11 Post(s)
How much?
How much?
Yes,I had also taken notice of some of the other things that did look a bit odd - but without good images it is near-on impossible.
It is apparently;now,no longer available but the listing finished without a single bid.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Next time post a link to the actual eBay listing...
Today, I believe my jurisdiction ends here...
pdougie1
0
01-08-15 05:38 PM
sergsucks
8
01-30-12 08:36 PM
