Moloko Bars- extensions?
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Love my Surly Moloko bars on my Salsa Fargo. I use the front "horns" a lot.
Like them so much, I'd really like to extend them out a bit. Anyone know of a good solution to do the following sketched below? Any off- the shelf solutions that can be ordered online or thru my LBS?
Ideas:
Ideas:
- Wood Dowels- not a great solution
- Hollow aluminum or steel tube- possible if I can find the right size and wrap the diameter with tape
Likes For Toadmeister:
Quoted: 1364 Post(s)
Liked 1,677 Times
Toadmeister You could add clip-on areo bars just inboard. It may be inelegant, but that's what came to mind first.
Quoted: 198 Post(s)
Liked 332 Times
Liked 1,677 Times
Likes For BobbyG:
Likes For tyrion:
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,990 Times
I could agree with a hornier Moloko bar I have a set and wouldn't mind a bit more length, the girth is fine though.I suspect someone who is able to weld or braze could probably do a fine job. However I remembered quickly that Control Tech does these: https://www.controltechbikes.com/products/item/150.html
https://www.controltechbikes.com/products/item/151.html which might be just the ticket.
Likes For veganbikes:
Quoted: 198 Post(s)
Liked 332 Times
Clark W. Griswold
Liked 3,990 Times
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Maybe one of those Jones bar narwhal things?
Genesis 49:16-17
Genesis 49:16-17
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
How about get someone to 3D print a cylinder with a smaller diameter section at one end that will have an interference fit inside the bar. Wrap some bare tape to secure. The 3D print could be low density/porous to keep weight down. You could even put an inward curve on them as you show. Wish I had a 3D printer.
Quoted: 198 Post(s)
Liked 332 Times
i had thought about that but 3D printed stuff is probably too brittle/not strong enough. Heck, I’ve broken aluminum bar extensions before!
3D printing can work nice for prototypes however. I’ve done several for work.
Clark W. Griswold
Liked 3,990 Times
