BB overhaul help: Raleigh DL1 Tourist
Quoted: 86 Post(s)
Liked 78 Times
Hearing a squeak, I resolved to overhaul the bottom bracket of my '75 Raleigh DL1 Tourist. Glad I did since this is what I found:
Top: adjustable cup. Bottom: remains of ball bearing cage.
My question is: how do I put it back together? Do I try to find a new cage for the bearings, do I try to find more ball bearings to fill the gap, or something else?
Any help is appreciated, thanks!
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
thorstein
Toss the old broken cage. Fill space with two more bearings (for 11 total) and waay more grease. repeat on opposite side. 11 loose bearings is the standard set per side of a BB
Ps. Some oddities out there allow only 10 bearings (if 11 they rub). In that case, stay with 10.
Ps Unsure what size bearings for headset of DH-1. Might ask before you rebuild....l.l
Likes For WGB:
WGB
Liked 2,334 Times
Some Raleigh's have different BB bearing sizes (I've never handled one though I did get caught with a Raleigh headset (takes 5/32nd bearings) and 3/16 will not work!!
Simply pointing this out because 15/64" versus 1/4" is only 1/64th of an inch difference and DH-1's haven't been made in many years
Per Sheldon Brown:
By far the cheapest option is to keep the original 26 TPI Raleigh cups, and install a new spindle with the tapered square ends needed to fit cotterless cranks. Because the inside diameter of the bearing cups is slightly smaller than for other brands, not all spindles will fit, unfortunately, unless you replace the standard 1/4" bearing balls with 15/64" or 6 mm bearing balls. Bicycle shops do not usually stock these sizes, but Internet vendors carry them.
Per Sheldon Brown:
Quoted: 86 Post(s)
Liked 78 Times
thorstein
Yes, more grease is needed, I just put in enough to hold the bearings in place.
I'll try to figure out the size of the bearings or are you saying they're 6mm / 15/64"?
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Original bearings should measure out to be 1/4" and they should not be caged from factory.
Check the bearings you have with a caliper, and replace them if they're smaller than 1/4". I don't recall how many go in each cup, but just fill them on the raceway surface until you run out of space. Use nice sticky synthetic grease to hold them in the cups, and don't let the spindle dangle once you've bottomed it against the drive side; have the left-side cup ready in your other hand to spin it on.
-Kurt
-Kurt
Quoted: 86 Post(s)
Liked 78 Times
I think my reading skills were a little suspect. Seems clear he was saying 1/4" is the correct size.
Odd about the cage being in there if it's not original.
Likes For thorstein:
Uff Da!
Quoted: 68 Post(s)
Liked 180 Times
Also from Sheldon Brown, don't just add bearings. Replace them all.
Bearings from different batches vary slightly in size so if some are a bit larger, they are going to take all the force & wear.
Fill the cups with as many balls as will fit, then remove one.
Likes For Sierra:
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Not odd at all. It's a much easier way to do it, and it normally functions just fine.
Quoted: 3810 Post(s)
Liked 6,692 Times
Yeah, either that's all Raleigh had on hand in 1975 (it's probably cheaper to do caged bearings) or someone o'hauled it along the way and made that replacement. As long as your cups are good, it should all button up fine.
Liked 4,395 Times
My guess is that at some point in the past, a mechanic who'd never worked with non-caged bearings overhauled it - and installed a caged unit thinking it should be there. Most caged units for conventional 24tpi Japanese/US/EU bottom brackets won't fit the Raleigh BB cup and spindle correctly and I dare say that's what happened here.
The cage was probably bent out of shape by the bearings trying to squeeze in on it. Eventually, the bearings caught the cage itself, tore it apart, and spat the remains it into the BB shell.
-Kurt
Quoted: 86 Post(s)
Liked 78 Times
sad turn with an upshot
Sad turn of events, the spindle is pitted!
The upshot is that my LBS is retiring a DL-1 frame for wall art & they let me nab the spindle & the wheels.
Old wheels:
Notice the chrome has been worn through. It is also bent out of round so hard breaking resulted in stuttering.
New wheels!
They need to be cleaned up, but are in great shape!
The spindle is also in amazing condition, so this ’75 Tourist (with some '68 Tourist parts) will be on the road for many more years.
Old wheels:
New wheels!
