Interesting stems...any idea about these two?
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
I obtained several vintage stems the other day and a few I have not had luck identifying...any ideas?
Ava death stem I know...two cracks means no way!
Edumacator
Liked 3,122 Times
The crack...
Quoted: 3811 Post(s)
Liked 3,336 Times
# 1
expander and binder bolts are by ALGI so that pretty much means a French origin. bears resemblance to some patterns from Philippe.
appears it may be Brit. take a measure of the head of the expander bolt and the nut of the binder bolt. check the threads. you may discover it to be fractional.
# 1
Edumacator
Liked 3,122 Times
Quoted: 3809 Post(s)
Liked 6,684 Times
The steel one looks like the model that commonly came on a Raleigh Sprite.
Edumacator
Liked 3,122 Times
https://www.bikeforums.net/classic-v...rite-27-a.html
Liked 6,684 Times
Likes For nlerner:
Liked 3,336 Times
pic assist -
images from ebay listing posted above
"quacks like a duck"
pic assist -
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
The french stem is begging for some paint infill on the final build.
#1 could also be Pivo. I had a Pivo handle bar and stem set up looking much like it.
#2 most likely a Raleigh offering even though their is no markings
#3 if the expander slot has not cracked you can drill a relief hole at the top.
Edumacator
Liked 3,122 Times
Excellent sleuthing all!
and the death stem may already have a hairline fracture... if not, I will do the drill, but you can see in the images that one side seems out further...
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
I would say the cracked stem is unusable, the other two are OK.
Likes For 3speedslow:
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
That death stem, with some curly bars, would make a great coat rack!
Edumacator
Liked 3,122 Times
Exactly!
Edumacator
Liked 3,122 Times
What’s a three speed?
Quoted: 912 Post(s)
Liked 515 Times
