Andrew Ritchie pattern tri-folders
Old 12-25-21, 07:49 AM
Ev0lutionz
Quoted: 76 Post(s)
Liked 11 Times in 7 Posts
I'm based in Singapore, Mobot is just a Pikes re-brand. Am using a pikes personally.
Ev0lutionz is offline
Likes For Ev0lutionz:
Old 12-28-21, 11:13 PM
pinholecam
Quoted: 230 Post(s)
Liked 146 Times in 96 Posts
Originally Posted by Schwinnsta
No, I would call that a bi-fold with an extra hinge. The ideal would be not having a hinge in the main beam or triangle (if there is one). If you look at the bicycle as a structure, the wheels are its supports. The bi-fold is like a beam spanning wheel to wheel with a hinge in the middle. Structurally, that is the worst spot. For cost of production and practicality, it may be the best spot. Can you overcome that shortcoming? Yes. The only folder I had that was a bi-fold that was stiff was the Raleigh 20. it was way heavy, had a huge fold, and it had an antique threading system. I had had two Dahons. Both were relatively cheap and both way too flexy. I had two Moultons. I liked them, but they are not folders. On balance, I do like front wheel shocks (just my opinion but too much compromise). My current 20" bike is a Xootr Swift. I love the ride, but the fold is huge. That is its only downside. Later this year I will try another folder, maybe a bi-fold.
The bi-fold also offers a quick fold into roughly half the bike length as a practical aspect and no need to roller wheels/rack to push around after fold (provided it was catered for in the design of course).
The ChangeBike does have a design that isn't too bad a compromise (esp the flat bar version), stiff turning joint (maybe even over spec'ed for my weight).
It can use a standard 26" or 27.5" fork depending on model.
Not the smallest fold, but in reality, it occupies a imaginary space when folded that is really more or less the same as a 20" folded bike.
pinholecam is offline
Old 12-29-21, 05:02 AM
Jipe
Quoted: 800 Post(s)
Liked 247 Times in 211 Posts
For me the cleverest solution is the one of the Birdy: no additional folding axle, one piece main frame, the front and rear suspension axles are also the one used to fold the bike.
Jipe is offline
Old 12-29-21, 09:07 AM
tcs
Palmer
tcs's Avatar
Quoted: 1657 Post(s)
Liked 1,803 Times in 1,050 Posts
Originally Posted by Jipe
For me the cleverest solution is the one of the Birdy...
Very clever, yes. The compromise of the 'no hinge in the main frame' design approach is of course a larger fold.
tcs is offline
Old 12-29-21, 03:50 PM
Jipe
Quoted: 800 Post(s)
Yes, larger fold but only slightly larger.
The above picture is an old one of a Birdy I.
The Birdy has been improved step by step and the current Birdy is only slightly bigger than the Brompton.
Jipe is offline
Old 12-29-21, 07:15 PM
pinholecam
Quoted: 230 Post(s)
The Tyrell IVE uses the same folding concept.
That said, nothing 'tucks' the wheels better than the Brompton when folded, so width wise, its still the neatest and most narrow.
Its really all about compromises and what one prefers and decides what he/she can accept more of.
I am not big nor heavy and to me a bi-fold bikes work well enough and can be lighter on the wallet too.
I can also appreciate the compact fold of the Brompton (though I really dislike the poseur cult that is built around it ); also I am willing to sacrifice some fold compactness for good gear spacing, better efficiency with other folding bikes
Birdy/Tyrell IVE type fold is a reasonable compromise to me too (and the middle ground really depends on where is middle for the user)
Old 12-30-21, 08:54 AM
tcs
Palmer
tcs's Avatar
State of the art Andrew Ritchie trifolder Dahon Curl: 54x27x58cm
Birdy factory folded dimensions: 62x34x80cm
tcs is offline
Old 12-31-21, 05:16 AM
Jipe
Quoted: 800 Post(s)
Birdy factory folded dimensions: 61x33x72cm
Just like for the Brompton, the folded length of the Birdy depend of the saddle mounting.
Both bikes have a seatpost with an offset (on the Brompton, the offset comes from the pentaclip).
With the offset to the front, the folded length is smaller than with the offset to the rear (the same apply for the folded height of the Brompton that also depends of the pentaclip adjustment)
.Birdy seatpost with offset to the front:
Birdy seatpost offset to the rear
The Dahon Curl has (or had ? at least some models had it) a clever folding saddle mounting system that reduces the folded size.
Jipe is offline
Old 01-10-22, 04:52 PM
kraftwerk
my nice bike is at home
kraftwerk's Avatar
Bikes: 2011 BMC Race Machine / 2012 BMC Road Machine / Trek 2300 / '90's Merlin/ '70's Raleigh 20/ Ti-'swift' folder / Erickson w/S&S couplers
Quoted: 66 Post(s)
Liked 34 Times in 24 Posts
This guy figured out a pretty good fold, takes a few ingredients from Bromptom but has 20' wheels, so better on those Belgian cobbles.
Nice guy, he was VERY impressed w/ mi Ti-Swift folder.
https://www.ahooga.bike/
Analog model looks good to me, there are also two models w/ electric motors.
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
kraftwerk is offline
Old 01-11-22, 04:41 AM
Jipe
Quoted: 800 Post(s)
Brompton just announced the T-line bike claimed to be the "Brompton reinvented".
If this claim is true, it should be more that a Brompton with a titanium frame like the existing titanium Brompton clone.
Jipe is offline
Old 01-11-22, 07:09 AM
Pinigis
Pinigis's Avatar
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times in 241 Posts
It's an interesting compromise between folding and disassembly. Personally, I don't like the idea of having to remove the front wheel to "fold" the bike.
Paul Pinigis
Owner of Origami Bicycle Company
Pinigis is offline
Likes For Pinigis:
Old 01-11-22, 08:52 AM
tcs
Palmer
tcs's Avatar
Yeah, the Ori (&Mezzo) method of folding the front wheel back away from the forks is far more clever.
tcs is offline
Old 01-11-22, 09:08 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
I was told by one of the co-founders that IRL, people don't often need to fold the bike completly, so leaving the front wheel on isn't that big a deal.
Winfried is offline
Old 01-11-22, 09:32 AM
tcs
Palmer
tcs's Avatar
Another Andrew Ritchie pattern tri-folder, branded 'Harry Quinn'. The ebike version is interesting.
tcs is offline
Old 01-11-22, 09:40 AM
tcs
Palmer
tcs's Avatar
If this claim is true, it should be more than a Brompton with a titanium frame like the existing titanium Brompton clone.
We'll know on the 19th, I suppose. Until then,
tcs is offline
Old 01-11-22, 11:13 AM
Jipe
Quoted: 800 Post(s)
https://youtu.be/wCv37frpPbs
The exclusive virtual launch event is announced for Tuesday 18th January 2022 4pm UK time.
Jipe is offline
Old 01-11-22, 04:42 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
No fenders for the folding bike => No interest on my part. It is not about the art of folding for the sake of art, in the end, but about utility, and the fender question is from the list testing the latter.
2_i is offline
Old 01-11-22, 06:21 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
They are "rollable" fenders.
Considering how rainy its native city is (Brussels), I assume they know what they're doing.
Winfried is offline
Old 01-11-22, 09:48 PM
2_i
Quoted: 840 Post(s)
Even if the protection is limited, it is good that they consider the issue .
2_i is offline
Old 01-13-22, 01:15 AM
CEBEP
Quoted: 226 Post(s)
Liked 64 Times in 45 Posts
Front fender provides no protection to the drive train and I too find having to remove front wheel to fold being much less practical. Probably not a big issue for whose who don't need to fold it every day but occasionally. Interesting concept.
CEBEP is offline
Old 01-16-22, 12:46 AM
Ev0lutionz
Quoted: 76 Post(s)
This my Pikes !
Old 01-16-22, 01:15 PM
kayakindude
Bikes: 1987 Cannondale SR600/BioPace, 1991 Cannondale Road Tandem,1994 Giant Iguana MB, 2009 Airnimal Chameleon, 2016 Dahon Vybe C7A
Quoted: 121 Post(s)
Liked 100 Times in 63 Posts
I don't see removing the front wheel a detriment. On the contrary I feel a lot better leaving my Chameleon unattended in the vestibule area of the train while I grab a comfortable seat for the ride and store the tire in the rack above the seat.
kayakindude is offline
Old 01-18-22, 12:48 PM
Jipe
Quoted: 800 Post(s)
The T-line:
Jipe is offline
Old 01-18-22, 12:52 PM
CEBEP
Quoted: 226 Post(s)
The T-line:
Next update will cost £5k
CEBEP is offline
Likes For CEBEP:
