pant stirrups?
Quoted: 95 Post(s)
Liked 50 Times
I have some. They're kind of hot though, but for awhile they were the only thing that did the job. But then they came out with these, even cheaper. They stretch (essential) and are very reflective. Recommended
I think I will ADD the reflective bands you link to above. I read somewhere recently that neon yellow clothing is not really all that effective at night, and that reflective material, especially for the side of the bike and rider, are key. Certainly in the winter, my commute is in the dark on both ends. Thanks.
Quoted: 5224 Post(s)
Liked 3,581 Times
wow, ok, thanks for this link. I want those as well. I wear the leg protector because, for some reason, my tights get chewed up in the winter, and...my right leg gets chewed up in the summer, if I only use some sort of cuff band. between the front derailleur and the outer ring itself, I end up with grease and cuts on my legs\tights. Maybe it's my city riding style.
Liked 3,581 Times
if you consider ankle wraps / leg protectors clothing
but on that topic, I have added reflective tape to clothing w/ pretty good results. nothing that I would wash, just outer garments specifically for commuting in foul weather
snow pants
rain jacket
snow pants
rain jacket
Quoted: 2494 Post(s)
Liked 738 Times
The thing with ankle straps ... calves taper. No matter where on your shin you place the strap, it WILL start to slide down no matter how tightly you affix it. I have only found one strap that is elastic enough that it will continue to grip after adjusted to size with the velcro fitting. The Leg Shields straps I linked earlier. Those metal clips probably would work too, but they are NOT reflective. And they probably are NOT $8.99 for a pair. So why not get a set of ankle bands that are 2" wide, elastic AND reflective as Hell? I can't think of a reason not to have a set near where you keep your helmet, shoes, gloves and other gear.
Likes For Leisesturm:
Liked 3,581 Times
this worked out pretty well tonight
funny how high up the leg the chain ring has access to. it's not just the ankle
Likes For rumrunn6:
Liked 738 Times
Maybe that works for you, but I'm pretty sure this thread exists because that doesn't work for everyone. In fact there are a couple of pictures in this thread where the poster is wearing their 'ankle' straps about where I do, in fact, where most people do: just below mid-calf, i.e. just above the ankle. Any lower and the cuff usually pulls out and the strap falls. Not that it matters. I've found something that works for me. Works so well that I actually chortled out loud about your attempt at sarcasm at my expense. You have no idea ...
Liked 3,581 Times
used the knee brace again. this time didn't try to cover the top of the boot. this seemed to work even better
altho, since yesterday was so mild I could have just used my cycling pants instead of these winter pants
but it was OK, I wasn't too hot
Likes For rumrunn6:
Liked 3,581 Times
fwiw- using these again this winter. they really do work well on the drive side, pant leg bottom
Quoted: 4802 Post(s)
Liked 3,922 Times
And to the topic - our bodies vary so much and so do our types of riding that no solution is going to work for all. The discussion of leg taper. Yes, virtually all our legs taper but how much is all over the place. Where pant legs end relative to boot tops and ankles probably even more so. I've had many stretches where I've struggled to find pants long enough that aren't several inches too big at the waist. Pants/leggings that go over boot tops and not ride up? I spoke early on in this thread that I used to have a fella in the industry sew extensions on to my foul weather pants in my boatbuilding/racing days.
And for that "wool" kneewarmer approach - if you like it enough and have a similar buddy with sewing skills, consider slitting it up the side and installing a zipper or velcro. It will save you needing to pull it on over your foot or shoe, allow you to boot up first then "oh yeah, I need the sleeve" and will, almost certainly, extend the life of the sleeve by sparing it of all the stretches.
Liked 3,581 Times
I took one look at this photo and thought "That's Massachusetts!" (The trees, the rock you are standing on, the winter light ...) Look at your location. Yup. Boston. Where I was born. Grew up in Milton. Know those rocks really well.
ha! are your rocks so different now?
this was at Spy Pond, Arlington, MA
good ideas!
I use these pants for cold weather walking as well & I like the way they drape, as-is, for walking
although they are short waisted & not snug at the waist. consequently I have to use suspenders to keep them up, haha
but you are perceptive! 1 ride I put the knee warmer on before my shoes, smart
the very next day, I did not & had to ask Wifey for help getting it over my shoe, haha
washed & dried the pants & tucked the warmer into a pocket. these things are so small & easy to lose, eek
