Repurposing dropout hanger hole.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 982 Post(s)
Liked 631 Times
So, when using a frame with a rear dropout incorporating a derailleur hanger, but not using a derailleur (SS, fixed gear or IGH), I see bikes often with just to hole sitting there -- or, worse, hacked off. So, I was thinking, is there an alternative? What comes to mind is a place to mount a taillight, even if in many countries it is on the wrong side (I'd think from 50' away or more, still readily visible). A bracket should be straightforward enough to fabricate -- but attaching it? My old Sutherland's guide says a Campagnolo hanger is 10mm x 26TPI, close to 10mm x 1.0; so is that a M10-1 bolt? Like for instance BOLT ? Anyone try this? Or, I guess, try to locate an unwanted Velox RD and cannibalize the mounting bolt.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For oneclick:
Quoted: 3809 Post(s)
Liked 6,684 Times
Streamers?
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Good spot to mount a chain cleaner.
or a 1st aid kit for reattaching fingers chopped off attempting to re-mount a dropped chain on the fixie.
Quoted: 4510 Post(s)
Liked 6,377 Times
But not really a concern for me as I will never have a 1 speed/fixie anything so....
52psi
Quoted: 790 Post(s)
Liked 802 Times
Derailleur hangers never bothered me on SS builds. They're out of the way and relatively inconspicuous.
Brazed-on shifter bosses, on the other hand, are completely unacceptable and a non-starter for any SS project.
Which has nothing to do with this discussion. I'll move along now.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
I have drewed off shifter bosses - on a beater fixie... it was an appropriate look.
Nicer conversion got some jewelry.
The derailleur hanger stayed though, on all of them.
You could probably figure out a way to mount a light or action camera to it though. Not sure what else it would be good for.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Alternate response, in an attempt to offer something useful:
Instead of repurposing the hanger, just get yourself one of these oh-so-sexy White Industries freewheels to divert your attention...
Ooooooohhhh... shiny!
Quoted: 982 Post(s)
Liked 631 Times
Still not comfy with what bolt would be a best option. And on eBay, a used Velox RD with the nice bolt (red "C" center) starts at $40, a lot for just a bolt.
That sounds so 1930's in terms of aesthetics! I like it; presumably a tensioner comes with a mounting bolt.
So that got me looking at chainring and other crank bolts online -- alas, none seem to be M10. But it was worth checking!
I could imagine a clever engineer could devise a backward-swinging kickstand to mount in that hole. On urban bikes -- curb feeler?
Shiny is always a winner. My current project is IGH so I don't need a freewheel, the sprocket is shiny silver but not exceptionally so. I am just not sure I want to drag it off to the chrome $hop.
Quoted: 1819 Post(s)
Liked 1,693 Times
Likes For alcjphil:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Likes For P!N20:
Quoted: 809 Post(s)
Liked 1,022 Times
On the derailleur hanger when not using a derailleur, I agree that an empty hole does not look finished. Just filling the hole with a decent looking plug would be better than an open hole and repurposing the hole for something like a light might be a good solution.
If you were a machinist with a lathe, making an aluminum screw that is 10mm diameter with a 26 tpi thread should be doable. You could just cut a screwdriver slot in the head or get fancy and broach a hex into it. Then polish the aluminum to make it look like it belongs. But that is a fair amount of work for this endeavor, unless someone sets up to make a batch of them, and then how many could they sell? I'd love to have some just in case I ever need it, but with the cost of making an almost bespoke part and shipping, I don't know if I'd spring for it.
Then there is this hole cap from McMaster Carr. Metal Snap-in Panel Plugs
They are made for a 3/8" hole but should be able to fit a little larger hole at .394" , or at least that is what I'm thinking. I'd get the 9563K261 with nickel plating and for a thicker panel (like a derailleur hanger). Bending the tabs would enable it to fit the 10mm hole. This would look more finished than just an empty hole. Of course, you'd have to buy 50 of them for $16 plus shipping.
Likes For Velo Mule:
Quoted: 964 Post(s)
Liked 1,451 Times
Hmm... First thing to come to mind is a Suntour S1 chainrest.
Second thing that comes to mind:
truck nuts
But seriously, most rear axles will be m10x1. You could take one from your pile of broken rear axles and use that along with whatever hardware you need. Doesn't everyone have a pile of broken rear axles from all their friends who refuse to give up freewheels?
truck nuts
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Put in a classy earring. Maybe a pearl or even a nice stone with some facets.
Aside from that, it's a bad location anything other than a derailleur or a chain tensioner.
Quoted: 982 Post(s)
Liked 631 Times
I suspect that's true. Probably also true for "flag mount".
SE Wis
Liked 3,390 Times
Many of those links like Grainger have nationwide locations who sell over the counter. A lot of the AL ones appear to be Rice burner tuner shops. Any metro area should have some of these motorsport tuner shops.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
I'd be inclined to find a smooth head, slotless "locker" bolt for it. There also are friction-fit automotive type plugs if you prefer plastic over metal.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
