Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Swapping handlebars on 1997 Trek Multitrack 730 for Upright ride
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 06-06-15, 08:01 AM
cschwer
Bikes: 1997 Trek Multitrack 730
Hello, Way back in 1997 I bought a Trek Multitrack 730 bicycle. I rode it around Central Park in Manhattan for a year or so but never really used it much after that. I recently decided to dust it off and begin to use it here in upstate New York along the Erie Canal towpath trail. My problem is that a couple of years ago I seriously broke my left arm at the elbow. I have a steel plate and 6 long screws holding my elbow together. The handlebars on my bike force me to lean over and put quite a bit of pressure on my arms while riding. Is it possible to swap out the handlebars with something that would give me a much more upright position while riding? Is it possible to use the same shifters and brakes or do I need to swap those out as well? Thanks for your suggestions.
cschwer is offline
Old 06-06-15, 08:13 AM
MRT2
MRT2's Avatar
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 204 Times in 143 Posts
You can change out the handlebar and possibly the stem. I would suggest in addition to getting a bar with a little rise, also get a bar that puts your wrists in a more natural position. Thinking about the Nitto Albatross, Velo Orange Tourist, Jones Bend H bar, or the Soma Sparrow. Just make sure whatever you buy fits your stem.
MRT2 is offline
Likes For MRT2:
Old 06-06-15, 08:30 AM
cschwer
Thanks so much. I will check these out. I rode the bike last night and wasn't thinking at all about my elbow and when I got home It was clear that I have to make a change. Thanks again!
cschwer is offline
Old 06-06-15, 08:46 AM
MRT2
MRT2's Avatar
That is a fine bicycle that is worth putting a few bucks into. I have a virtually identical Bianchi Advantage from the same year that still rides great. I gave it to my son last year.
If those are the original tires, you might want to consider replacing. Even if the bike had low miles, the rubber in the sidewalls hardens over time.
MRT2 is offline
Old 06-06-15, 03:24 PM
cschwer
They are the original tires... I have ridden the bike twice in the last two days and so far so good but I may be riding on borrowed time. I do plan to replace the tires as well as the handlebar set up and maybe the saddle. My body is no longer the same shape as it was in 1997...
cschwer is offline
Old 06-03-22, 02:13 PM
tairy
Bikes: Peugeot Ventoux, Trek Multitrack 830 (ebike)
Quoted: 21 Post(s)
Liked 10 Times in 7 Posts
Hello, Way back in 1997 I bought a Trek Multitrack 730 bicycle. Is it possible to swap out the handlebars with something that would give me a much more upright position while riding? Is it possible to use the same shifters and brakes or do I need to swap those out as well? Thanks for your suggestions.
Did you end up swapping your handlebars? I have a Multitrack 730 and just seeing what kind of conversions others have done. Thanks!
tairy is offline
Old 06-19-22, 01:06 PM
nick_a
dingus
Bikes: 2020 New Albion Privateer, 1983 Schwinn Super Sport
Quoted: 17 Post(s)
Liked 13 Times in 10 Posts
Multitracks are ripe for updating/reworking. They've got great tire clearance and good compatibility for swapping out componenets. If you check out xbiking over on ****** you'll see loads of cool ideas. Drops, alt bars, bikepacking builds, the works.
nick_a is offline
Likes For nick_a:
globe9
Bicycle Mechanics
20
09-24-17 03:54 PM
SwampDude
Bicycle Mechanics
7
08-16-15 01:14 PM
iowafightfan
Fitting Your Bike
2
06-30-14 02:47 PM
woody66724
Hybrid Bicycles
4
05-22-13 11:02 PM
Nick M
Hybrid Bicycles
4
08-02-10 07:35 PM
