Grips worn off of tools
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Like a lot of people I have used tools. Some of these are many years old and the rubber they put on the grips/handles at the factories has either peeled off or cracked. I had seen threads before that described this problem and what had worked or not worked. I just can't find those threads. I'd like to find a product that I can use to coat the grips/handles and rather than just randomly testing different products until I find one, I figured I'd ask if anyone has had any successes and can recommend any specific product.
Example
s:
Example
s:
Quoted: 1609 Post(s)
Liked 2,590 Times
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
PlastiDip. Never used it but they make some products that have some cult like followers.
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
I've used electrical shrink tubing over the old coating to preserve the original. You could also just cover tool handles with it.
Likes For Desert Ryder:
WGB
Liked 2,334 Times
Thank you all.
I'll start with the Plasti-dip (not sure if the shrink wrap would provide any protection from a rough/sharp edge? )
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
The Plasti Dip stuff will probably require several coats to soften those edges. That will help use up the stuff, the remainder of which will harden up in the container and wind up being tossed years later.
Likes For thumpism:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Auto parts store and appropriate diameter fuel line hose by the foot.
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...I have used Plastidip on tool handles. It works, sort of. It's not especially durable, but you can get better results with several coats, letting them dry in between.
Home Depot and Lowes (and probably the other hardware stores now), sell vinyl tubing in various sizes, by the foot. If you take the tool you want to cover along, you can usually find a size that you can slip over the handles, as a cushion. This works pretty well to ease the strain on your hands, but it's not as colorful as Plastidip. I guess you could then dip the tubing covered handles, but I've never tried that.
Quoted: 2604 Post(s)
Liked 1,928 Times
Plasti-dip was my first choice, but as 3alarmer notes, it's not particularly durable.
So have you thought about self-sealing silicone tape (e.g., Gardner Bender Blue Self-Sealing Repair Tape 1 in x 10 ft in the Electrical Tape department at Lowes.com)? Wrap it like you would bar tape, overlapping wraps, to build up some extra thickness.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Are you talking about the spray version? I agree that is not durable for tool handles but found this version quite good.
A friend uses wheel well/truck bed coating. I cannot say I know his results but sounds like a possibility
Likes For etherhuffer:
Liked 1,928 Times
The can I tried looked a lot like this, except the plastic was blue. I don't remember which tool I put it on first, except that it was one I used a fair bit, and the plastic peeled off within a few months. I also figured, while I had an open can, I'd dip the 15 mm side of some dual-ended cone wrenches. That's lasted for some years, but then again, I only use them about once a year.
WGB
Liked 2,334 Times
I live in Canada and most of the stores are out of stock.
Next trip to Buffalo I'll hit either Lowes or Home Depot.
Fyi in Canada the Plasti Dip spray cans are $25ea. So I will try for the dip.
These tools are things like VAR and Hozan stuff I no longer use so it's more for aesthetic reasons. I like the idea of the tape or shrink wrap for working tools
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
This is one place I can recommend a Dremel tool. Take it and soften the edge of the tool handle then use plasti-plasti-dip.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
