Suspension stem? Wider tires? What else?
Hello! I'm a not very experienced but not total novice biker in NYC. My new commute is short but ROUGH. And I don't have the best back. I need a new bike, and I suppose I'll get another hybrid. I got one years ago that was not very good from the start. But I'm wondering what are all the embarrassing granny-biker things I can do to the bike to make the ride smoother that will actually make a difference. In the past I've gotten a super cushy seat and worn padded gloves to absorb some of the shock from the handlebars. What else? Do suspension stems make a difference? How wide are hybrid tires normally and what width would be cushier? Any specific bikes you'd recommend? What's a good bike shop in NYC where they won't laugh at me for my questions and will be thoughtful and helpful? THANK YOU!!
Quoted: 1364 Post(s)
Liked 1,677 Times
My wife's upright comfort bike has a suspension stem, a suspension fork and a padded seat with big springs. It does a pretty good job of isolating the bumps except the tires. While the tires are 26 x 1.75 they are stiff and sturdy even when inflated to the minumum psi.]. I put supple WTB Slick 26 x 1.85s on my MTB-based commuter and those would cushion even more, just remember to not inflate too much.
I also have been padding my bars with foam pipe insulation to help with "crampy" hands.
But FWIW, I myself do not ride upright bikes or suspended bikes. I commuted 9 miles each way for 28 years and found that riding on the brake hoods of a drop bar bike works best for me. Not so far forward that all the weight is on my hands, but a good balance between hands and butt. Also, using my hands and feet to support my weight and provide biomechanical suspension using my knees and elbows, like a jockey.
Even before I converted my MTB to drop bars, I used slightly up-swept bars and threw them forward to give me a more "road" posture. The only reason I converted to drops is that my hands no linger like straight bars.
Also, riding in a more forward position builds "core" muscles that help support the back. Twice a day for 28 years, and I rarely had back issues. Of course everybody is built differently and has different physical issues, but leaning forward and using my own legs and arms to cushion the ride works best for me.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
There are lots of comfort products and which or whether you shop will just have to depend on your pain. Good fit and just being used to saddle time helps most of all. Being fit also helps - this is something I definitely notice right now when I'm dieting, my pressure on the seat is just less.
Big soft seats are fine for shorter or infrequent rides. Really! You don't have to be shamed into buying a small firm seat that hurts even though you will never do enough seat time to "just get used to" it.
Some hybrids and some comfort bikes come with suspension forks. They can take a hit but on bikes under $1000 usually have no damping, just coil springs. They are pretty much just pogo sticks. Much is made of them being inefficient or heavy. The minimal loss in energy is what you take to get suspension, and the weight is about +3 lb at equivalent price level. Front suspension bikes also tend to have higher handlebars, to give the suspension room to work, so they sit a little easier.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 7348 Post(s)
Liked 2,465 Times
Wider tires go a long way. Finding the ideal pressure helps a lot, too. It might be lower or higher than you think.
Likes For noglider:
Bikes: 2014 Fuji track classic, 2021 Cannondale Topstone 4
I got a new bike for commuting this year (and because I wanted a new bike) and I went with a gravel bike for commuting. Wide tires, not so aggressive cycling position, enough gears to deal with hills but not so many that I either confuse myself or feel like I'm racing. I got my bike at King Kog in Brooklyn; they were great.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Not just wide tires, But good quality supple tires. The cheap 2" (50 mm) tires on my comfort bike are OK, but probably no better then supple 35mm tires.
Most of our weight is on the seat, so it is the next most important area to address. Start with a comfortable seat, then the seat post. A long small diameter carbon fiber unit goes a long way to reduce road vibration and small hits. Of course we often don't have a choice there, But there are some suspension seat posts that can make a big difference and are easy to install on most bikes. Some aren't cheap but might be worth every penny in the long run.
Suspension forks are the next step, But like seat post diameter may not be an option worth pursuing. Those suspension handlebar stems might be of benefit too, But I'd be careful they don't comprise handling or safety. I like the concept though and might check into them myself. Good handlebar grips and gloves could help too.
I like Giant's Roam hybrid bike for a situation like yours. It has 42mm low pressure tubeless tires , a suspension fork, and their D-Fuse vibration obsorbing seat post, as well as being a fine all-around hybrid bike. If you could even get one.
Quoted: 102 Post(s)
Liked 55 Times
Layering helps a lot in absorption. Obviously a full suspension MTB is going to provide the smoothest ride, but however bad the roads are I think 100mm travel is a bit overkill on a commuter bike, but my roads are that bad.
The wider the tire, the more volume, and if you keep the psi lowish, it takes the edge off road imperfections like small cracks and undulations in the tarmac. I run 50mm/2" as a max for road/single track commutes, a good compromise of comfort, grip and speed. For larger/deeper hazards like pot holes, I have the Thudbuster G4, which is great for a comfy ride on the tush, especially when combined with a good cushioned saddle like a Selle.
I also use the RedShift shockstop suspension stem which works pretty well. However, all these add weight to the bike, which may be an issue. I do think my carbon bike is also comfortable, but nothing like a full suspension bike!
When I started riding again after maybe 15 years of not riding, my hands and bum got mighty bruised on a 3 mile round trip commute. After maybe 2 months, my hands and bum were conditioned enough, and I was better able to absorb road shock with my body instead of having all be delivered to my contact points.
Padded handlebars, suspension fork and suspension seatpost will really smooth out those rough streets for you. I wouldn't recommend an overly padded saddle, it can cause problems by simply being too much everywhere.
Quoted: 1324 Post(s)
Liked 927 Times
I had a bike with a suspension stem and I hated that stem. Whenever I hit a big bump the stem made it feel as if I was about to go over the handlebar. I got rid of it. I think that a decent suspension fork, especially one with adjustable travel, is a far better choice. However that might require a new bike frame at least.
Cheers
Cheers
mosquito rancher
My advice depends on how long your commute is. If you've got a short commute, it almost doesn't matter what you do, as long as you're happy with it. If you've got a somewhat longer commute (say, 5 miles each way or more), efficiency becomes more of a factor. Fat, cushy saddles get in the way of efficient pedaling, and an upright position (like on a hybrid) actually makes it harder to unweight the saddle and use your limbs as springs when you're riding over rough stuff—which is the right way to deal with choppy asphalt, IMO.
Suspension stems are all over the place. I've got one from Redshift, and the effect is subtle. It's great on textured pavement. It won't help with bigger pavement imperfections.
High-quality fat slick tires would be your best bet for smoothing out bad pavement.
Adam Rice
Adam Rice
Thanks so much for your response! I also have bad forearms due to past repetitive stress injuries. I'll try some of your suggestions. Take care!
Quoted: 426 Post(s)
Liked 274 Times
Can't really add much from what other have already said. If slight vibration roads you could probably get away with flex stem and flex seat post. If you riding through/around major pot wholes from 3rd world country I would get the lightest full suspension bike with 32+ road tires on it.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Many BF posters refer to the benefits of "supple" tires. What is the difference between a "supple" tire and one that is not? How does a bicyclist looking for bicycle tires determine if one type of tire is more or less "supple" than another of the same size and inflation pressure? Are there any physical characteristics that a consumer can see or feel without mounting the tires and road testing?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
The saddle also isn’t a “seat”. You don’t “sit” on it like a chair. If you do, the bike is going to beat the crap out of you no matter how soft you make the saddle and grips. Try to hover over the saddle by using your legs to hold you up while you pedal. It’s a hard concept to grasp but once you do, you’ll find that mooshy saddle highly uncomfortable. My own saddles have only marginal padding or no padding at all. I ride Brooks leather saddles that have close to 20,000 miles on them. They have zero padding but I can ride on them for 1500+ of miles over weeks of daily riding on tours with zero pain.
I use a Brooks for most of my commuting as well. It has 20,000 miles on it and is just as hard as it was when it came out of the box. But I ride it “light”…i.e. support my weight with my legs and float over the saddle rather than sit on it.
Stuart Black
Stuart Black
Liked 2,465 Times
