Good CX Rims?
Good CX Rims?
I'm looking for a good rim. These are the features I want:
--Bombproof- I'm about 180 pounds, and these rims will take a beating
--Eyeleted- I'm not interested in having a nipple rip out on me or tearing up the rim trying to true it
--36 hole possibility- I'm lacing it 36h
--Cost is not really important, bikes are really the only thing I spend money on haha, and I am a firm believer in buy it nice or buy it twice
--Width- I want to be able to fit some 28 (or even 25) tires on there if I feel like riding around the city
--Weight doesn't really matter to me
I was considering the following, but let me know if I should look at something else:
-Salsa Delgado
-Mavic A719
-DT TK540
Input is greatly appreciated!
-Salsa Delgado
-Mavic A719
-DT TK540
It's not eyeleted, but the Velocity Synergy (o/c rear) is Grant Petersen- and Peter White-approved. It's what I would choose for a "bomb-proof" country bike wheel.
https://www.rivbike.com/products/show...nd-700c/18-224
I've had good luck with the delgado cross. My next wheels will be built with Velocity A23s most likely, which a guy from velocity told me can easily be run tubeless with a stans kit. I don't know how hard you tend to be on rims, as it is a little bit lighter option (relatively) but it is available in 36h.
Bikes: Kona Zing Supreme, Giant Anthem X2, Specialized Langster, Surly Cross Check
Though naysayers may abound to this response, I would recommend checking out the Mavic Open Pro for cross. It's a little lighter than the rest of those options, and works great for 32c as well as 23c tire diameters. I weigh around 190 pounds and raced cross on these for several season and the only time I ever did any damage was hitting a tall rock at about 20 mph on a descent. It's an eyeleted rim, available in 36h drilling, and is also available in the slightly stronger Mavic "CD" finish, I believe.
Check it out, I'm a proponent.
Double Secret Probation
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
Get tubulars.
Time to Ride...
Time to Ride...
In the top 42%
Bikes: Salsa CCC
Here they are. https://www.c-4bicyclecomponents.com/...ml?st=menuJump
If you're willing to go the tubular route, Velocity Major Toms have been getting pretty good reviews as a bomb proof and affordable tubular rim. I'm looking at a pair for next season. If you're 180 pounds It'll let you use lower pressures. I don't weight much so I can get away with 28psi on clinchers, but it's still pretty risky at my weight.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Velocity A 23. These are 23mm wide but will take a wide range of tire sizes from 23mm to 38.
I Love My Dream
i personally saw one on a ride this summer with a nipple ripped out and a few other spoke holes that were cracked. just because a rim has eyelets doesn't mean it cant happen.
Race wheels ? Tubulars are where the action is and has been for Decades.
and the traditional double Eyelet Box section rims are plenty strong.
Pros on Paris Roubaix cobbles Go to those for that race , [unless they have a rim/wheel sponsor
which pays their bills by having them demontrate their product worked on that race.]
Just get a couple sets .. as the tire Gluing takes a while, so cannot be done out on the course ,
then you just put another wheel on in the pits.. or jump on your spare bike and get back out there ..
Wheelsuck
Bikes: Ridley X-fire (Chris King tubies/Rival), Specialized Tarmac (Zipps/Dura-ace)
Velocity A23 - Clincher
Velocity Major TOM- Tubular
Build them 36 in the rear and 32 in the front triple cross and nothing will stop you
Here are some specs for several rims.
Velocity A23
19.5mm high
23mm wide
426g
601mm ERD
V-cross section, non-eyleted
Velocity Dyad
27mm high
24mm wide
480 g
596mm ERD
V-cross section, non-eyeleted
Velocity Synergy
18mm high
23mm wide
496g
604mm ERD
Box cross section, eyeleted
also available as O/C rear
DT Swiss TK540
20.2mm high
23.6mm wide
540g
600mm ERD
I've built with, and handled, all but the A23. The DT Swiss rim is built to perhaps the highest standard, not that the Velocity products are lacking. Their products have a well earned rep as being perfectly round, and easy to build, which will result in a very evenly tensioned wheelset. Coming from a set of worn out Open Pro's, the wear dimples on the DT's are a nice touch. The TK540 is heavy though, more of a touring rim, although, I'm sure it would be the most bomb proof of the above.
The Synergy and Dyad are more than decent runner ups. I thought initially, just from specs, and the off-center rear, that the Synergy would be the clear winner. The O/C rear is less important on a 135mm rear and/or a shimano setup. There is a touch more offset in a 130mm Campy rear, were it would begin to be more important. With 36 spokes, there is plenty of history to suggest and off-center design is not critical. The Synergy is more squat in cross-section, and requires more material/weight to achieve the same stiffness as the Dyad. The Dyad is Velocity's sleeper rim. Available in many drillings, relatively light, and plenty tough, even without eyelets. Easier to source on discount too. It will build better if you put a dab of nickel anti-seize in the spoke hole, or on the nipple flange, before building.
The specs on the A23 suggest more of a road wheel, and at 180lbs, you may be pushing it for cyclocross. That said, building it 36h might tip the balance in your favor. Out of all the listed rims, the A23 would win my vote as the one most likely to suffer a nipple pull through.
Agree on the advice to go 36h rear/32h front. Most important point for longevity is full (~110kgf front and DS, NDS will be a bit less) and even spoke tension.
If you are serious, consider the Velocity Major Tom tubular route. They Dyad would be my second choice.
Velocity A23
19.5mm high
23mm wide
426g
601mm ERD
Velocity Dyad
27mm high
24mm wide
480 g
596mm ERD
Velocity Synergy
18mm high
23mm wide
496g
604mm ERD
DT Swiss TK540
20.2mm high
23.6mm wide
540g
600mm ERD
mstateglfr
Bicycle Mechanics
31
04-11-16 03:00 PM
lukasz
4
04-18-10 07:41 PM
