Chain popping out of 11 tooth cog
Old 03-22-11, 10:50 AM
R900
Double Secret Probation
R900's Avatar
Bikes: Madone 6 series SSL, Cannondale CX9, Trek TTX, Trek 970, Trek T2000
Liked 4 Times in 4 Posts
I switch it a 11/25 cassette, problem is the chain wants to pop out, not continually, but maybe every 100+ feet or so. It's a 7900 cassette, 7800 RD, 7800 shifters, 7800 chain. Chain is still between .5 - .75 on the gauge, but does have a quick link. Any thoughts?
Time to Ride...
R900 is offline
Old 03-22-11, 11:34 AM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
It only pops out of the 11T cog? Probably a high limit screw adjustment issue. Look and see if the derailer is lined up underneath the 11T when in that gear.
FastJake is offline
Old 03-22-11, 11:52 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,354 Times in 861 Posts
smaller they are the faster they wear, because less teeth share the load..
fietsbob is offline
Old 03-22-11, 12:03 PM
ultraman6970
Shimano has a smaller lockring for 11T cassettes as campagnolo does?
ultraman6970 is offline
Old 03-22-11, 01:06 PM
Al1943
Liked 7 Times in 6 Posts
Yes, if you don't have the special 11 cog lockring that is the problem. You're probably ready for a new chain also.
Al1943 is offline
Old 03-22-11, 02:26 PM
mas-az
Bikes: Bruce Gordon, SOMA Stanyan
What quick link? connex can have this problem if installed backwards.
mas-az is offline
Old 03-22-11, 05:58 PM
R900
R900's Avatar
I'm not sure, dealer installed. I usually just use a pin. Lock ring is ok, I adjusted the limit, but didn't seem to change anything. I'll put the new chain on. Thanks!
Time to Ride...
R900 is offline
Old 03-25-11, 09:44 AM
hardyt
+1 for checking the RD. See if everything is properly adjusted and there's not much play. If there is play, when you stand up, you add extra tension. That could cause play in the RD to increase, changing its position slightly and causing a skip.
You could also check to make sure the RD cable is lubed in the bend by the BB.
I've had this problem maybe three times on two different bikes. It's been something with the RD every time.
hardyt is offline
Old 03-25-11, 03:55 PM
zzyzx_xyzzy
headtube.
zzyzx_xyzzy's Avatar
Liked 3 Times in 3 Posts
Like clockwork, every 100 feet, make 7 crank revolutions - pop - 7 crank revolutions - pop? Sticky or worn chain link. See if you can time it so you stop right as it pops, maybe you'll catch it with the quicklink right over the 11t cog.
zzyzx_xyzzy is offline
Winblows
Bicycle Mechanics
13
07-06-18 06:21 AM
jitteringjr
Bicycle Mechanics
8
05-01-18 09:39 PM
thingsthatgo
Bicycle Mechanics
6
06-18-17 05:43 PM
ljsense
Bicycle Mechanics
24
08-07-16 02:49 AM
GriddleCakes
Bicycle Mechanics
21
10-04-14 10:05 AM
