Help! Jagwire Cable Routing Tool Part Lost in Top Tube
Hi All,
I just bought my first frame that uses internal cable routing and a Jagwire Pro Internal Routing Tool. I screwed the little magnetic dealie onto the end of my brake cable, and stuck it in the first hole. I tried to catch it at the back end, and discovered that it had detached itself from the cable and was now sitting inside the top tube! I've tried to catch it with the extendable magnetic part—and it does stick, but I can't get the little sucker to emerge from the hole! I will continue to try but the hole is barely large enough to pass the thing.
Has this happened to anyone else and, if so, what did you do?
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...I haven't used one of those, but in other instances where something small gets stuck inside a hollow space, I turn the piece with the hollow space so the hole is facing downward, and slide the tiny piece back and forth, until it eventually falls out of the hole (or gets stuck partly out of the hole) using gravity assist.
Thanks, 3alarmer, that worked.
I took off the wheels and saddle, and started shaking the frame around. The dingus ended up going into the down tube, and I was able to get it out through the opening where the derailleur cables come out near the bottom bracket.
Mark
Mark
Likes For mpemburn:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Ah, the joys of internal cable routing.
Likes For JohnDThompson:
