square taper crank bolt spec?
Quoted: 230 Post(s)
Liked 10 Times
I swear i am getting stupider as i age. I cant find any threads that reference a proper torque spec for a square taper bb. I could swear it was something like 35 ft lbs but wanted to be sure. Does any one know? Sugino AT cranks on a Tange Sekai seal bb if that matters.
Quoted: 4191 Post(s)
Liked 3,837 Times
I have used 30-35 ft lbs for tapered square arm retaining bolts for decades. IIRC older Euro ones often wanted a few lbs less as their alloys tended to be softer. When Hollowtech came out and their bolts called for 40ish I was surprised. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Park Tool's web-site info. for square taper cranks suggests a range of 34 Nm to 50 Nm ( 25 ft. lb to 37 ft. lb. ). That's with the bolt heads' undersides and threads lubricated with grease or anti-seize.
https://www.parktool.com/blog/repair...on-three-piece
Quoted: 114 Post(s)
Liked 119 Times
Park also lists torque specs for various fasteners and manufacturers: https://www.parktool.com/blog/repair...s-and-concepts
