How to service Wellgo MG-3?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
Back in 2017 I bought my wife a pair of Wellgo MG-3 pinned platform pedals off eBay for about $20. She put a lot of miles on them and they've been great.
But our most recent ride, the right pedal started squealing like the mandrake root in Harry Potter. Checking it by hand, both pedals spin super loose and rattly.
I watched some videos about disassembling platform pedals to clean and grease them up, and they all seem to be, hold the crank end still with one wrench, and take a hex bolt off the outside end with a thinwall socket.
But looking into the end of this one, it's not a hex bolt, it's just a round metal wide-brim-hat-looking thing, like a washer but with a cylinder in the middle, maybe crimped/pressed onto the end of the spindle?
(a) how do I get that thing off, and
(b) does that mean these 'wellgo' pedals are counterfeit?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
Are you saying dispose of the bearings and swap in new sealed bearings? Or dispose of the pedals?
Quoted: 4027 Post(s)
Liked 3,447 Times
I read the pedal internals' description as being a bearing/axle design that has had the axle end peened over (instead of being threaded) to keep all together. This type of assembly is not meant to be serviced other than dripping oil down and into the pedal axle. A sign of the lowest cost construction that has been the usual for inexpensive bike parts since the beginning.
Lay the bike on it's side and drip thick oil into the uncapped pedal end. When you see oil bleeding out the crank end of the axle stop and repeat for the other side's pedal. This will only be a stop gap and not a solution for worn bearings but doesn't cost much but time and a little oil.
When this periodic lubing becomes frustrating consider getting a higher grade of pedal, ones that can be taken apart. But please don't ignore them too for 6 years. Andy
AndrewRStewart
AndrewRStewart
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
Nice thanks. 'peened' seems like the right word that I didn't know to describe what I'm seeing. Dripping some chain lube into that area is what we actually did when we got home. Although we didn't wait long enough for the lube to make it all the way out the crank end, it did make a dramatic difference in smoothness of spinning on that pedal. I already expected that to be only a short-term mitigation, not an actual solution.
That pedal happens to have lost its dustcap (maybe why it got into worse shape). The left pedal I tried to dig out the dust cap, and leaned into it pretty hard, but only ended up gouging the plastic with a screwdriver. I guess I should keep digging.
If periodic oil drips stop working and these pedals get binned, it's ok. With the amount my wife rode them, I already got $20 worth. Proud of her for wearing stuff out!
Quoted: 283 Post(s)
Liked 244 Times
That model is aimed at light weight rather than long life. Wellgo make some pedals like the LU987 that have cr-mo axles, adjustable cup and cone bearings and replaceable grip pins (there are a couple of different models with slightly different shapes but those specs). They do tend to come from the factory over-tightened and under-greased, so you need to spend a few minutes putting that right, but then I find they last well in normal use.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
Friendship is Magic
Bikes: old ones
Quoted: 25575 Post(s)
Liked 9,521 Times
...super loose and rattly does not sound like a problem that oil is going to solve. Oil will make it quieter for a while. If there's no provision for new bearings or bearing adjustments, maybe just bite the bullet and find replacements.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
I did order a pair of Stolen thermalite pedals (20% off on Labor Day!), there's a question of whether her 5/10s on plastic pins will be grippy enough. If not, we'll roll the dice with these a while longer and buy some more metal.
Friendship is Magic
Bikes: old ones
Liked 9,521 Times
Clark W. Griswold
Quoted: 4001 Post(s)
Liked 3,505 Times
Welgo has always been a cheaper test ride type pedal maybe one notch up in some cases but more of a disposable item. If you want a good platform pedal look at Crank Brothers Stamps and you won't be disappointed. No they aren't cheap-o pedals and they do cost money but they are serviceable and long lasting and grip really nicely and for my larger feet they are super comfortable.
Likes For veganbikes:
Quoted: 283 Post(s)
Liked 244 Times
AIUI Crank Brothers pedals have a reputation for rapid bearing wear. I like their clipless mechanism but I've not tried the flats.
Clark W. Griswold
Liked 3,505 Times
They are my default everyday flat pedal, I have several pairs that work well, the right shape and good grip. Not the lightest, admittedly, but then neither am I.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,245 Times
So I tried this. After the stolen/thermalite pedals were put on, I stood the wellgos on a paper plate in the garage (empty cap-side up for one, crank-side up for the other, with the seal/gasket pulled up out of the way), and filled the cavity with chain lube (homebrew mix of bar/chain and oms). They've been sitting there for a week or two with a pool of standing oil. A few times I picked them up and spun the crank some to try to give it a chance to work its way down. Maybe a few drops got in there, but this morning I had to move them so gave up and poured the oil out.
