Are all Presta cores the same quality?
Old 09-21-23, 04:32 PM
stratman
Quoted: 27 Post(s)
Liked 7 Times in 5 Posts
A while ago one of my Presta valves failed. The thin inner rod broke. I suspect I have been a little careless in the past with how I put the pump head on (it's the first bike I've had with Presta tubes). I'll try to do better. That was a non removable core, so I had to throw a perfectly good tube away.
Both tyres now have removable cores, so I thought I'd get some spares. I'll probably replace the core on the non new tyre anyway, in case I've damaged that.
But there seems to be a huge difference in price. 4 x Schwalbe cores are something like £14 (UK). Whereas a pack of 12 unknown-make are £7. Is there much difference in quality? I assume they're all the same size. And I don't really need 12.
Thanks.
stratman is offline
Old 09-21-23, 04:42 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 25609 Post(s)
Liked 9,553 Times in 6,645 Posts
...I don't know about the aftermarket replacement cores, but the ones that come in tubes definitely vary in quality. I have had to replace many in the past couple of years. Rarely had a problem before that.
3alarmer is offline
Likes For 3alarmer:
Old 09-21-23, 05:30 PM
Troul
Troul's Avatar
Liked 2,775 Times in 1,793 Posts
yes, as well as not all being interchangeable.
-Oh Hey!
Troul is offline
Old 09-21-23, 06:38 PM
veganbikes
Clark W. Griswold
Quoted: 4012 Post(s)
Liked 3,538 Times in 2,364 Posts
Get the correct cores for your tubes. However if I was going for tubes I would try to get Schwalbe or Continental when possible and then Specialized or Teravail if not. There are differences in tube quality hence different price points. Good quality tubes cost a little more but I think are worth it unless you are just running crap tires and subject to tons of flats but I wouldn't; run crap tires unless in an emergency.
veganbikes is offline
Old 09-22-23, 04:12 AM
stratman
Quoted: 27 Post(s)
Oh, right. That's a pain. I assumed they were interchangeable. Is it that they are supposed to be, but sometimes aren't?
Anyway, the tubes are Schwalbe (I think) so if I get Schwalbe cores (as spares) all should be OK. With more care hopefully I won't be damaging them too much.
Thanks.
stratman is offline
Old 09-22-23, 06:25 AM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 800 Post(s)
Liked 317 Times in 235 Posts
In my experience the Schwalbe tubes have been notorious for coming with faulty cores. I have been replacing them with no-name cores from AliExpress, that both looked better by eye and operated without problems. I hope the replacement cores marketed by Schwalbe are of a better quality than those in the tubes they market.
2_i is offline
Likes For 2_i:
Old 09-22-23, 07:55 AM
Crankycrank
Quoted: 809 Post(s)
Liked 962 Times in 686 Posts
My own experience has been different. I have used at least 30 Schwalbe tubes that get pumped at least twice a week and get used for 3+ years most of the time. (I patch rather than replace). Never had a PV go bad but I rarely have an issue with any brand Presta valve. To the OP, maybe you don't need to get spares yet. If you already have some spare tubes just use the valve from one of them and when you toss an old tube, save the PV for spares. I'm a bit frugal that way but always have spares for friends and people who have destroyed. theirs on the side of the road with ham fisted pumping after a flat.
Crankycrank is offline
Old 09-22-23, 08:40 AM
stratman
Quoted: 27 Post(s)
Thanks. Yes, that sounds like a plan. Get a couple of spare tubes with removable cores. I get very few punctures, because of the tyres I use.
As I said, this being the first bike I've had with Presta valves, I think I was a bit clumsy with putting the pump head on and off. I keep toying with the idea of getting one a Silca Hiro pump head but they are a bit non-cheap.
Hopefully with more care, now I understand how Presta valves work, I won't break another one.
stratman is offline
Old 09-22-23, 09:42 AM
2_i
Quoted: 800 Post(s)
In the several Presta tubes I bought for Brompton, half of the valves leaked. Just in case, I replaced those cores that did not leak too, just in case, not wanting to wait for a mishap at an importunate moment. DO NOT reuse cores from tubes that ran their life course. The cores have rubber seals that deteriorate with time, just like any rubber.
Not sure about the Hiro head but Hirame, of which Hiro seems to be a copy, is certainly great. It also comes in the Schrader version which is a good investment too.
2_i is offline
Old 09-22-23, 10:24 AM
smd4
Quoted: 2909 Post(s)
Liked 2,469 Times in 1,484 Posts
Luckily, however, they're a bit worth-every-penny.
smd4 is offline
Old 09-22-23, 10:34 AM
stratman
Quoted: 27 Post(s)
Thanks both of you. Yes, the reputation of the Hiro is stellar. I'm tempted, very tempted. Also tempted to start using tyres with smooth valves, I hate that forcing it on feel. Thought, does anybody make half and half valves, bottom part threaded, top smooth?
Anyway, I saw this:
Hiro vs Hirame chucks.
I think I'd be using as in the Hirame example, as replacement for the current chuck. Is it not possible to do that with the Hiro? With a hose clamp or something?
Thanks.
stratman is offline
Old 09-22-23, 10:36 AM
squirtdad
squirtdad's Avatar
Quoted: 2209 Post(s)
Liked 2,567 Times in 1,406 Posts
couple of comments
1) make sure you tighten the core, I have found some tubes come from the factory with the core not well tightened.
2) the park valve tool is worth the cost
3) if you use sealant in tubes, get extra cores as they tend to get clogged up
4) I do not understand the comments about not interchangeable, I have never seen this
squirtdad is offline
Likes For squirtdad:
Old 09-22-23, 10:40 AM
smd4
I have a Silca Pista Plus pump, that came with a screw-on Shrader chuck at the end. So all I needed to do is screw the Hiro into it. If I ever need to pump up anything with a Shrader, I can easily unscrew the Hiro.
The Hirame would be essentially permanent.
smd4 is offline
Old 09-22-23, 10:44 AM
stratman
Quoted: 27 Post(s)
Anyway, I saw this:
Thanks.
Ah, wait a moment. The Hiro can screw into a threaded Schrader chuck. Or maybe that's the only way to attach it? In which case I'd have to buy a threaded Schrader chuck, but I would then have both options (I've got some bikes with Schrader). Whereas with the Hirame it would be a little neater (less ironmongery) but no way of pumping Schrader valve with the same pump.
stratman is offline
Old 09-22-23, 10:50 AM
Rick
Quoted: 517 Post(s)
Liked 315 Times in 210 Posts
I use the Schwalbe tubes and tires. I had tube failures prior to using them. I have a silca floor pump that I purchased in the 90s. I saw a YouTube video that demonstrated the Hiro pump head. I no longer worry about how careful I remove the pump head. The Hiro needs very little valve hanging out to work.
Rick is offline
Old 09-22-23, 10:51 AM
stratman
Quoted: 27 Post(s)
Thanks. Apologies, we cross posted, but you've confirmed what I thought. This isn't for a Silca pump, by the way, it's for the SKS Rennkompressor. So Hiro plus threaded Schrader chuck of some description (probably Silca) is probably the best course for me.
Presumably all pump hoses are the same internal diameter? Or close enough that lubricant/hose clamp will make it all work together.
stratman is offline
Old 09-22-23, 01:01 PM
2_i
Quoted: 800 Post(s)
I use light alu QR pneumatic couplers (from Zoro) and switch between my 2 Hirames and one other chuck that I like before I can blink an eye.
2_i is offline
Old 09-22-23, 01:16 PM
Crankycrank
Quoted: 809 Post(s)
True, but I have re-used plenty of cores and just eyeballing them you can usually see if any of the seals are old or damaged.
Old 09-22-23, 05:24 PM
Kontact
Kontact's Avatar
Quoted: 3715 Post(s)
Liked 1,036 Times in 693 Posts
Go to a bike shop and ask them if they have blown tubes that you could steal the cores out of.
Kontact is offline
Old 09-22-23, 05:52 PM
Troul
Troul's Avatar
Originally Posted by squirtdad
couple of comments
there are alternative core tightening tools other than park.
it doesnt surprise me that i found the unfortunate design. not sure who the make was. just tossed them out & never looked back.
-Oh Hey!
Troul is offline
Old 09-22-23, 06:14 PM
squirtdad
squirtdad's Avatar
true, I use park, but "good quality core tool of any kind" is a good substitution.
also to note is that deflating tire before removing valve will keep it and the tool from becoming rockets and taking an eye out
your not compatible cores could have been dunlop (aka woods)
Old 09-22-23, 07:17 PM
Troul
Troul's Avatar
no, they came with extenders from unknown brand
-Oh Hey!
Troul is offline
Old 09-23-23, 02:07 AM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 951 Post(s)
Liked 1,123 Times in 649 Posts
I bought some no-name valves and the top nut spun right off the first time I tried to open it to put air in. That allowed the rest of the inside parts slide all the way down and into the tire. The other 3 from the same batch seemed to work fine, but I couldn't trust them and bought a different kind of core. I don't know which brands are better than others, or how many factories there are serving the many brand labels, but I now check the core before installing it.
It's like riding a bicycle
urbanknight is offline
Old 09-23-23, 04:47 AM
Jeff Neese
Quoted: 1053 Post(s)
Liked 656 Times in 424 Posts
I only use Schwalbe and Continental tubes. Both of those brands individually test their tubes and I've never had a bad one out of the box. HOWEVER -
I bought four Schwalbe tubes last year and the first two had leaky valves. I bought a pack of the valves linked below and compared them under a microscope. The difference in quality was obvious. The rubber seals were larger and more even on the new ones, the metal parts are better material and more finely produced, even the knurling on the knob was more even. My theory is that Schwalbe tests their tubes first, and then installs the cheapest valves they can buy.
I still use mostly Schwalbe tubes, but now I swap out the presta valve automatically, and keep a supply of these valves. There are a lot of different ones for sale but I can vouch for these.
Presta Valve Core - 10 Pack
Jeff Neese is offline
Likes For Jeff Neese:
Old 09-23-23, 10:22 AM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 695 Post(s)
Liked 982 Times in 529 Posts
you can mount a Silca Hiro on any hose, you just need the little hose barb that looks like this (below)
Use a hose clamp, or, style points will be awarded if you use an Oettinger clamp, which is used for automotive fuel injection lines. See pic #2. You can then thread the Hiro chuck onto your hose.
The Hiro and the Hirame are equivalent, I have both. HOWEVER the Hirame rubber inserts are nearly impossible to get, and they do wear out, The Silca ones are available from ... Silca.
no doubt some intrepid soul will interject that "they found 'em on Amazon". Good luck with that !
/markp
mpetry912 is offline
