Fork steerer and bottom headset issue - vintage
Veteran, Pacifist
Quoted: 3740 Post(s)
Liked 4,396 Times
Need advice on a fork to headset concern, never experienced before.
Bike is an early '70s Holdsworth Pro with (supposedly) original fork, although the frame and fork serial numbers do not match.
The bottom headset race does not seat onto the fork steerer.
Picture worth 1,000 words. I gently filed the top of ridge to show it better in the pic.
The fork steerer has a 'ridge' where it joins the fork crown that prevents the headset from seating properly. The steerer (above the ridge) is 25.4mm and 26.4mm at the crown. Only a 1mm increase.
Have tried a '70s Campa headset and a new one but neither seat onto the fork crown.
What to do?
What to do?
Quoted: 4040 Post(s)
Liked 3,475 Times
The "ridge" is the fork crown race seat. It should have been both machined round to a 26.5mm diameter (allowing for a 0.1mm interference fit with the headset's race) and it's face/bottom flat/perpendicular by someone before the initial assembly. The .1mm interference fit will want a significant impact force to drive the race onto the seat. Best done with a tool which will evenly contact the race and slide on the fork's steerer, maybe extending above the top of the steerer which will let a hammer be used to create the impact. These tools resemble a length of pipe/tube with a fairly thick wall. Sometimes the amount of impact force is similar to driving a 10P nail into a chunk of hard wood.
What tool was used to try to install your race?
There are times when the race seat is not well machined or became ring notched by poor install/removal of a previous race (if the race cocks crooked a lot). Then a re-machining of the fork's seat is the good choice. Can this be done by a home "mechanic"? Sort of, but not with out care and skill with a hand file on the mechanic's side. These days few of us have had that kind of exposure to working to close dimensions with simple hand tools and if done poorly the race can end up sitting loosely and this is not good or right. I strongly suggest enlisting a shop (or well equipped home guy) to do this kind of work if at all possible.
As to the serial numbers not matching this is not uncommon for some factories back then. Frames and forks were often made in batches separate of each other and only combined when the F&F are painted. I have seen this with Holdsworthy and other English brands before. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Veteran, Pacifist
Liked 4,396 Times
Thanks @Andrew R Stewart
Have only fit them on loosely with no tools or hammering involved.
Serial number difference not a concern, but another Holdsworthy has matching serial #s, a 1980 model - so post bike boom.
I have assembled a number of framesets and never encountered the 'problem' to the extent of this one. Caution to get a correct fit and proper seat is understood and I will heed your advice.
Liked 3,475 Times
With more modern headset race and bearing designs the race is actually only a seat for the bearing cartridge, not also a ball track surface (as is with most "classic" loose ball designs). So the bearing seating ring could be either split or meant to fit onto a conical crown seat (so no interference fit). Really cheap "American" bikes sometimes have a very loose fitting crown race. Andy
AndrewRStewart
AndrewRStewart
Quoted: 460 Post(s)
Liked 569 Times
Conversely, I have never installed a crown race on a fork that didn't need to be "hammered" into place. That is why they make crown race setting tools. If your previous experience had the crown races just slipping on without force, you were dealing with poorly sized crown race seats on those forks.
Likes For KerryIrons:
biked well
Quoted: 139 Post(s)
Liked 154 Times
+1 to crown races being an interference fit onto the crown race seat, requiring tools to install and uninstall. A crown race that installs loosely, without tools, is a mismatch to the crown race seat, not the other way around.
Likes For well biked:
Liked 3,475 Times
With no knowledge of what previous bikes the OP was working on we can't be sure those other examples needed to be hammered down tight. I am quite sure the headset for this Holdsworthy will be an interference fit though. Andy
AndrewRStewart
AndrewRStewart
Liked 3,475 Times
Yet many 27.0 crown seats have been machined down to 26.4 (both are actually that .1mm larger, but that isn't a dimension listed in most all headset specs thus the race diameter spec being referenced) to allow for a replacement headset to work, for whatever reason why. Of course doing a non reversable procedure to a frame or fork is generally not one's first choice, sourcing the OEM spec headset is the better first choice. Andy
AndrewRStewart
AndrewRStewart
Quoted: 809 Post(s)
Liked 963 Times
This is one of the rare tasks that I'll take to a bike shop. They will have a special reamer tool to make the race round and the correct size and usually install your bearing race for you at the same time. Bring the headset with you that you will be using. Not really a difficult job to install the race but the shop ensures the steerer is machined properly.
biked well
Quoted: 139 Post(s)
Liked 154 Times
Quoted: 283 Post(s)
Liked 245 Times
What to do?
What to do?
Veteran, Pacifist
Liked 4,396 Times
Thanks for all the input.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3725 Post(s)
Liked 6,166 Times
Likes For SurferRosa:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 233 Post(s)
Liked 555 Times
I've got a couple of Holdsworths, both with original forks (matching numbers).
Fitted Tange Levin CDS JIS to both.
They were both hammered on at the local bike shop after I failed to install the Avanti race - don't have the correct diameter tubing (to use as a hammer).
If you get the right bike shop they won't charge
1961 Holdsworth Cyclone: crown race JIS 27.0mm, steerer diameter 25.4mm
1982 Holdsworth Avanti: crown race JIS 27.0mm, steerer diameter 25.4mm
.1982 Holdsworth Avanti: crown race JIS 27.0mm, steerer diameter 25.4mm
Veteran, Pacifist
Liked 4,396 Times
I used pvc once and it worked. But this one is tighter than I have experienced previously. I'm gonna let a shop handle it, got several to contact. This frameset I have high expectations for (ie, why I inquired here to get it properly right) - early '70s, perfect fit, original paint, orange&panels, chrome fork+socks, 531, bit 'o history. What more can I say?! (At least my minor/light filing did no harm.)
edit: I have always been under the impression that my English manufactured for Irish Harding distribution were produced under contract to the Holdsworthy company, that also produced Clive Stewart frames and others.
W. F. Holdsworth (nkilgariff.com)
i stand corrected if wrong
something like this - which may have been owned, possibly raced, by an Irish team, bitd. So, not Holdsworth branded, ever.
re-edit: Apologies, forgot this isn't C&V! thanks again for the headset advices.
Likes For Wildwood:
Quoted: 2916 Post(s)
Liked 2,475 Times
Liked 3,475 Times
