Should I bother servicing my free hub?
Hi friends, I've recently bought an old Lotus Classique from 1983; it's supposedly been sitting in an attic for the last 30 years, and except for the age, it's in pretty nice shape.
Anyhow, I am trying to do an overall service on it, and am now putting some fresh grease on the wheel bearings. I was planning on doing the same to the shimano freehub, but when I visited a nearby LBS (I don't have the two-lug tool for disassembly) I was advised that it's a pain in the ass job to do, and probably best left alone unless necessary.
And honestly, it doesn't seem necessary. The wheel bearings I serviced were super smooth, and so is the freehub. I don't think there would be a noticeable difference in how it feels after servicing. So, is it worth opening up this can of worms just to replace some 40-year-old grease?
Quoted: 5772 Post(s)
Liked 2,569 Times
The hub turns on greased bearings, but freehub internals should never be greased. Those call for a light oil, only thick enough to stay put.
Anyway follow the golden rule and don't fix what ain't broke.
FB
Chain-L site
FB
Chain-L site
Quoted: 18371 Post(s)
Liked 4,507 Times
I haven't done a lot of servicing below the freehub module level.
However, if your bike is a 1983. Then does it have a uniglide freehub with external threads? How many speeds? 6 or 7?
Those are getting more and more scarce, and could be a reason to crack it open.
Or you might choose to upgrade to a newer hyperglide with internal threads.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
As long as you were able to grease both bearings and you have a freehub so if it spins freely and does not slip you are good.
Last new bike 1991
Last new bike 1991
Likes For dmark:
It's a six-speed, cassette was held on by the threaded outer sprocket, so that sounds like uniglide. I guess at this point I'm leaning towards just letting it be.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
https://www.ebay.com/itm/18560731632...Bk9SR6qolLyFYQ
OP, when you rotate the freehub by hand, do you feel resistance? Even if you do, it's only creating drag when you're coasting. So if you're always pedaling, there's no ill effect. As imc said, seeping some oil in there can help significantly.
Liked 2,569 Times
Haven't seen that particular product, but not surprised.
As I said freehubs run on greased axle bearings. Or it might be a very light grease used to make a THIN FILM on the ratchet ring.
Understand the unique nature of freewheel units, which never have parts moving load. Therefore lubrication requirements are very low.
FB
Chain-L site
FB
Chain-L site
Liked 739 Times
Message meant for FBinNY... i promise to not argue with you. :-)
Quoted: 1943 Post(s)
Liked 2,164 Times
I’m not sure if the early Uniglide freehub bodies were removed with a 10mm Allen wrench. I know the UG/HG (except DA-74XX) are.
I’m in the remove the freehub and drip Phil’s Tenacious oil into it until you can hear it quiet down camp. If the rear of the body has a plastic seal, don’t try to remove it, just pinch it enough for the oil to get inside.
Grease the bolt threads and torque it to the hub.
I’d replace the bearings, grade 25, grease and put everything back together.
John
John
