Where are the -17 degree stems in 3K carbon finish
Quoted: 1872 Post(s)
Liked 692 Times
From my research I've found:
Zipp and Ritchey in aluminum with -17D but none in 3K carbon
FSA in 3K but -6D
There have to be some out there but I can't find one. Anyone know of any?
FSA in 3K but -6D
2019 Salsa Warbird
2019 Salsa Warbird
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Thomson might still offer the X2 stem in -17degrees.
FTR, carbon stems are for fools.
Liked 692 Times
I'm definitely not interested in the fakes, I've seen those too.
Um because it looks good and matches my bike. The better ones from FSA and Ritchey are actually carbon wrapped aluminum so I'm not looking to save weight necessarily but to make the cockpit look good. So, do you have any suggestions for my criteria?
2019 Salsa Warbird
2019 Salsa Warbird
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
It's not what the OP wants, but it might interest others. You can achieve a CF effect with paint by starting with a black surface, and then using a rubber drawer liner as a mask for a single coat of silver. I learned this doing airbrush stuff, years ago.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
Pro Vibe carbon, first model, was done in 3k but is on 10degrees
https://www.ebay.com/itm/Shimano-PRO-...-/190923315679
Liked 692 Times
Has the 3K finish gone out of style? It kinda seems that way.
2019 Salsa Warbird
2019 Salsa Warbird
Here is the previous model bars that match the stem
https://www.ebay.com.au/itm/Shimano-P...0a9b5b4&_uhb=1
Veni, Vidi, Bici
Bikes: Colnagos (2005 Brera Art, 2007 President LdV, 2007 CF6)
Liked 8 Times
Not sure if the clamp size is right for you, but AX Lightness makes a -17º stem.
https://ax-lightness.de/radsport/bike...uten/rigid-17/
Liked 692 Times
Hmm I'm not liking the garish decals. I'm picky I know, thanks guys for pointing those out.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
Anyway I think I'm going to go with the Ritchey WCS alloy bars/stem combo in wet black to save a lot of money and the stem is -17D so it works out. Thanks guys.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: Ax Lighntess Vial EVO D (+ Paduano Fidia)
Have you seen the prices on Ax-lightness? Perhaps not and that might be for the better
All these German brands (handmade stuff) cost an arm and a leg. My guess is that is why Enve (except the wheels) and 3T are made in Asia.
MCFK weight is about 75 grams for a 100mm stem.
Liked 692 Times
Why not? It's what I've always used.
2019 Salsa Warbird
2019 Salsa Warbird
Desertrats97
Road Cycling
86
02-08-12 10:36 PM
G6612
Road Cycling
17
09-01-10 11:11 PM
