Limongi excell tubing
I have a Limongi frame built from Mexico excell tubing. Just looking for more information about Limongi frames and bikes in general. Mine has a cinelli BB shell. The frame as a really interesting pattern pressed in the tubing.
i have phots on my gallery if someone could copy and post below.
thanks !
thanks !
Quoted: 4722 Post(s)
Liked 3,036 Times
Photo assist..
Likes For T-Mar:
Liked 3,036 Times
Guiseppe 'Pepé' Limongi is a very revered framebuilder. A Frenchman of Italian descent, he apprenticed in Paris under René Herse before setting up his own shop. Sometime in 1970s he moved to the USA where he built frames for Paris-Sport. Later, prompted by Guiseppe Marinoni, he moved moved to Canada, setting up shop in Trois-Rivières. Reportedy, in the mid-1980s he built several of the frames used by the Renualt-Elf pro team.
Excell was a French company. Based on a 1988 tubeset guide in cycling magazine, Excell employed high strength nickel-chromium steel. The seven listed tubesets are all plain gauge, ranging in thickness from 0.3mm to 0.6mm. They also produced oversize sets and a couple with a carbon fibre and Kevlar reinforcement on the inside of the tube, so it could be brazed or welded. The Mexico set is not listed in the guide, so the subject frame should be no older than 1989. Limongi was living in Canada by that time. I have seen a couple of other frames manufactured with the Mexico tubeset and they had the same impressions, so they should be representative of the tubeset and not additional work performed by Limongi.
Quoted: 3487 Post(s)
Liked 2,905 Times
That's a Cinelli Spoiler bottom bracket. Sort of an iconic bit of framebuilding lore.
Quoted: 3464 Post(s)
Liked 2,826 Times
Alberto Masi used the "string of pearls"
tubsets as well, on the Prestige and the Volumetrica.
there was one on eBay recently
those tubes have appeared elsewhere from time to time.
I missed out on a Limongi, unsure of from what time, I suspect France.
cannot buy them all.
Quoted: 1813 Post(s)
Liked 1,692 Times
My Limongi has that same bottom bracket. It was built in Trois-Rivières. It has full Mavic components. Unfortunately, when I acquired it it had been converted to flat bars so the original brake levers were long gone. In order to ride it I bought a pair of inexpensive Tektro levers. They work so well that I will leave it as is. The only other modification I made was to change the 52 42 chainrings to 50 38 and install a 12 26 freewheel that came from my Raleigh Professional
Thanks for posting the pictures and for all the information!!
would you think building this out with all french components would be best?
awesome bike!
im leaning towards full mavic set up. are those the original wheels do you think? picking a colour will be tough too, ive read alot of limongi bikes were bright and colourful.
thanks!
thanks!
Quoted: 4221 Post(s)
Liked 2,942 Times
That is a very interesting frame
