Racer Tech Thread
#3326
W**** B*
Bikes: Several
Quoted: 103 Post(s)
The last time I looked, QBP had an ETA of April 30 for eTap. My guess is that orders will be filled in the order they were received. I don't know of a "priority" system (which doesn't mean it doesn't exist). Another guess is that they won't have enough stock to fill all outstanding orders, but I'd like to be pleasantly surprised.
How did you look/check availability? Assume you need a log in?
#3328
Bikes: i may have bike(s)
Quoted: 46 Post(s)
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I work at an LBS and we have an account with QBP so I can access that info. Having written that, I'm off until the week after next, so I can't check until then.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#3334
Quoted: 693 Post(s)
i'm not seeing *any* ETA. there is a note that says any orders received after 3/9 will not ship until may.
#3336
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
put a mirror on your front brake boss and then you can ride with your head down the entire time.
#3337
Quoted: 98 Post(s)
commu*ist spy
what about a pair of virtual reality goggles paired up with a super aero action cam via bluetooth, with a robotic arm being controlled by a mini toggle stick right next to the shift lever? totally worth it.
#3342
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
BTW - for the others that PM'd me about a mirror - Sprintech is the one you want. I expect others are good, but some are not.
#3345
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,479 Times
I like the idea of creating more range of visibility on the bike without turning ones head or looking under the arm notwithstanding that both of those techniques work. I do not like an addition to the end of the handlebar that comes to a point with glass on one side. It strikes me it is only a matter of time until a racer suffers a serious injury.
#3346
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
Anyone here using a Pioneer power meter? I'm curious as to what would happen if the right side were separated from the left - ie on two different bikes. I know the left can work alone.
Also, what makes the left side only better than Stages? Other than you know, not taking on water or dying every 5 minutes.
#3348
#3350
fuggitivo solitario
How easy is it to convert a mechanical only frame to Di2? May finally go tron on the road bike as well
Current bike has internal routing, and i think the downtube cable entry area is wide enough to fit the wire through. I guess the hardest part would be to somehow drill a hole somewhere to connect FD to the junction box?
