Racer Tech Thread
#3551
Ninny
Quoted: 686 Post(s)
One thing I learned recently is that the printed grid lines on the bottom of the shoe are really meaningless, even between two pairs of the same model shoes. I've spent weeks now trying to dial in the cleat position on a new pair of shoes and it's still not quite there.
#3552
I chose the heel because I felt that the margin of error was much smaller if I based the cleat angle/position on a point further away from the cleat. If I tried to use the toe and I was off by 1mm then that would be probably 3-4mm of error at the heel. The fitter let me take the plate (for the Keo) home with me and I dropped them off a day or two later.
Same brand/size shoes, different model, just to be clear. With a different sole I'd still use the heel as a reference point but I'd look and see how my foot sits in each heel so I'm basing the cleat position on my foot, not on the outside of the different shaped soles.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
#3553
Ninny
Quoted: 686 Post(s)
I thought I was being clever and put the shoe against the corner of a room and traced the cleat position on a piece of paper. That seemed to work for fore/aft but the shape of the shoe is different enough that it didn't work for the rotation of the cleat, for the new shoes (Lake) the apparently identical cleat rotation ended up pointing my heels in more than the old shoes (Bontrager). I'm not sure how those template things could work either, unless they are somehow based on the actual position of your foot inside the shoe.
#3554
Bikes: Yes
Quoted: 9 Post(s)
damn, just as we enter the meat of the season around here i realize some pretty crucial stitching on my shoes is failing. hoping the big S will warranty them but either way having to adjust to new shoes/trying to replicate cleat position is going to give me so much anxiety.
#3555
yeah sworks, the older version with two boa dials. they've already been warrantied twice, but i love them nonetheless. unless i get hung up at work, i'm planning to stop by the shop tonight. i think mine are fine to last through KSR but if i could get new ones setup next week I'd be very very happy.
#3556
Quoted: 1851 Post(s)
Liked 675 Times
I'm kind of amazed by what Specialized will cover under their shoe warranty. A few years ago, my uppers separated from the carbon outsole on my BG Pros. The shoes were probably three years old and well worn, but Specialized replaced them.
Unfortunately, they had changed the shoe design a bit and the new ones never fit as well as the old. But I digress.
#3557
shop said they'd warranty the shoes. probably doesn't hurt that the head guy at the shop is a teammate. i was planning on buying new sworks shoes next year, but i'm not complaining about a replacement set this year! these shoes have definitely been worth the price.
#3558
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
I made the mistake of trying on some bonty xxx shoes last week. Made my old Shimano 132s feel like lead weights.
#3559
One of my dream thoughts is to get one of my older Sidis, cut the top off, and make a mold with the sole out of a carbon-kevlar combination (kevlar to keep things from disintegrating if things go south). I have two pairs of Aerolite shoes, from a brief period when they made them, and they're basically a sole that slips into a mesh "shoe" that has been dipped in something resembling Plasti-dip (to make the bottom somewhat durable). It could be an interesting project.
#3560
anyone tried the new vittoria tires with graphene? the old open corsa was my go to race tire. need to re-up my supply and it looks like they've been discontinued/replaced with the graphene version.
#3561
W**** B*
Bikes: Several
Quoted: 103 Post(s)
I've read all the "do you really want to trust your life to a $50 carbon handlebar from China yadda yadda" but has anyone actually bought one and used it?
I know it's hard to test sturdiness without crashing, but I'm really curious if you really do need to spend $150-250 on a carbon aero drop bar to get quality, or if you're just paying for a 3T, Zipp, Enve, etc decal.
#3562
Bikes: Canyon Aeroad, Ridley Fenix
Quoted: 22 Post(s)
I've bought a "branded" (Hylix. I also used a saddle from them and it didn't break under my 190lbs in more than 6 months. I trusted the brand enough to try the bars) chinese carbon bar (a 3T aeronova knockoff) and after a few months of using it, I noticed some cracks. I got sent a warranty replacement but I won't be using it. I decided I'll stick to alloy bars.
#3563
Blast from the Past
I like the GURU thingamajigs for that reason. I used the shoe heel as a reference point and lined everything up on that. This way I know that the cleat is in the same relative spot.
https://vimeo.com/9589645
https://www.stevehoggbikefitting.com...w-their-nails/
#3564
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I've started riding my new wheelset (HED Ardennes Plus, 25mm wide) with S-Works tubeless 700x24c tires. After a couple of weeks on the rims, the tires measure about 26.7mm wide on the front and about 27.2mm on the rear. I'm liking the way they work but have been wondering if there's a downside to having the rim and tire widths so close. For context, up until about a year ago I was running Michelin Pro4 Endurance tires that measured 27+mm on 19mm-wide rims...it just looks weird when I look down at the front wheel.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#3565
Liked 675 Times
I broke my Giro Synthe last week. I'm thinking of replacing it with a Kask Mojito or Protone. Anyone have any experience or thoughts on Kask helmets? The fit seems pretty good when I tried them on, but the Kask has a lot more padding than the Giro. I'm not sure if that is a good thing or bad thing in the long run. Basically all the reviews I've read online are extremely positive about all helmets.
#3566
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
#3567
Ninny
Quoted: 686 Post(s)
When you have a "bad style" valve extension, the kind that screws on to where the valve cap would be, and it's not quite sealed, and you pump it up and the pump gauge goes up as you pump and fades immediately because pressure is escaping above the actual valve, do you use the highest reading on the gauge (at the very end of the pump stroke) as the actual tire pressure?
#3568
Quoted: 60 Post(s)
It is also recommended to thread open the valve a little too far so it won't rattle closed on you. I recently switched from removable core extenders to the regular thread onto any tube style because it's a pain in the ass on the roadside if you need to remove a core.
#3569
Quoted: 60 Post(s)
I'm thinking hard about the $370 5700 stages unit on sale right now. Can you tell I'm home from work today?
#3571
Me too. I would be pairing it with a 5800 drive-side. I know the two are compatible, but does anyone have a sense as to whether there is a noticeable difference in the coloring of the silver 5700 v. 5800?
#3573
Quoted: 693 Post(s)
for context, the Corsa was not a long-wearing tire (~1,200-1,500 miles on a rear; i'd often replace race tubulars before then, though). i'd flat on them very rarely -- and mainly if the tire was near the end of life.
my expectation was that the graphene version would offer similar life. i was curious if it would have lower rolling resistance and/or better traction in the wet. i put ~500 race miles on a set on my east coast trip + a bunch of other miles, and they're about what i expected--pretty solid, but a couple incidental (~1-2mm) nicks in the tread.
i haven't tested the rolling resistance, at least not yet. i think vittoria's claims are probably overstated, but again if they come in at least as good as the Corsa i'm fine with that.
cornering...they are great in dry conditions. i haven't been in them in the rain yet; the non-graphene Corsas left a little something to be desired there compared to other tires.
i'd buy more...for racing.
#3574
Quoted: 693 Post(s)
with vittorias i have learned their limits in terms of my riding, my roads and their wear. if i let them wear too far, then i would get flats in bunches. i learned when to just toss the tire vs drop in a new tube.
vittorias offer better wear than the turbo cottons IME. i liked the ride quality of the turbo cottons (subjective) and the objective lower Crr, but i had some issues with the construction (tread separation).
#3575
commu*ist spy
anybody have experience with garmin 500 and 520? healthpack was very kind to let me use her extra 510, and I'm really digging the upgraded features, except the touch screen. The 520 doesn't cost that much more than the 510, and is more refined in just about every way, especially the map feature, which I like to use for training. After some research, I'm considering it.
A couple of questions:
how much does the battery life differ? with/without bluetooth? If it drains significantly more battery, it uses up more cycles, and the capacity depreciates faster.
any weird function quirks? my 500 sometimes is slow at switching screens, and sometimes saves rides really slowly. There are other quirks, which I can only assume has to do with the firmware, not the hardware, but not certain. what quirks does the 520 have?
