Rear wheel not spinning freely
Hi All, My rear wheel is off my road bike, a Bontrager Pro 3, rim brakes. The wheel will spin freely until I set the quick release skewer. I don't over tighten it, but once the skewer is set, the wheel will only spin freely for a couple of revolutions. Any thoughts will be greatly appreciated. Thanks.
Quoted: 529 Post(s)
Liked 255 Times
It is likely to be the nuts being too tight, resulting in too much pressure on the bearings.
Take the wheel off, loosen the nuts a little, put it back on, and see what happens.
Quoted: 1438 Post(s)
Liked 1,092 Times
If the wheel binds when the quick release is applied the bearing adjustment is too tight, or less likely, you have a broken axle.
Quoted: 4195 Post(s)
Liked 3,837 Times
Bontrager used a few different hub designs on their branded wheels. The least expensive has has common loose ball (cup and cone) type bearings which will be adjustable and, BTW, benefit from annual regreasing. The more expensive wheels typically use cartridge bearings (often poorly termed "sealed bearings"). This type generally has more robust axles (less likely to be broken/bent) and the bearing maintenance is to replace the cartridge completely.
Both designs can have issues that result in a poor wheel spin. I do agree that the likely version you have is the least expensive cup and cone type. If so then you will need cone wrenches (likely 15mm) and a wrench that fits the lock nuts (usually 17mm). This type really wants the RH lock nut and cone to be well tightened against each other before doing the adjustments from the LH side. Sometmes this means removal of the cassette lock ring to access the RH lock nut and cone. This procedure then also requires a cassette lock ring removal tool and a chain whip to hold the cogs from spinning while the lock ring tool is turned. These tools will likely cost close to the service being done by a LBS. It's generally the second home servicing that tool costs are a savings compared to the shop doing the work. Good luck getting these tools in today's pandemic shortage of parts and tools available for sale.
BTW with either bearing design if the wheel has seen enough miles in the "bad" adjustment they are likely in currently, expect some bearing surface damage to be happening. All the more reason to plan on a complete servicing and not just a simple adjustment. Andy
AndrewRStewart
AndrewRStewart
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Those wheels use Bontrager internals which are pretty similar to the DT 3 pawl freehub internals. They aren't adjustable. I believe the only way what the OP is describing could happen is if the freehub spacer isn't on the axle.
Quoted: 513 Post(s)
Liked 445 Times
This is heading toward the right direction. This is Bontrager's top-drawer road hub with press-fit sealed bearings.. Likely the schmoe who sold them to you took something apart and failed to put it back together properly. I can't tell you what's wrong with it without looking at the hub. Take it to a Trek dealer or a mechanic who has experience with these hubs.
Bikes: lots
Liked 2,932 Times
Quoted: 513 Post(s)
Liked 445 Times
None of this technical detail gets Andrew any closer to understanding why his wheel won't turn.
